I'm new when it comes to writing code, though have a reasonable understanding and some experience with circuitry and electronics. Wondering if anyone could help with part of a new project;
I'm trying to use the 'Millis' to fade and led up and down on a pwm pin but i'm having some difficulty, what happens is that the led fades up and down cleanly 2 or 3 times, then begins to 'stutter' and after a little while gets stuck at full brightness and flickers then seems to repeat the cycle. What am I doing wrong?!:
int led = 45; // the PWM pin the LED is attached to
int brightness = 0; // how bright the LED is
int fadeAmount = 5; // how many points to fade the LED by
unsigned long previousMillis = 0;
unsigned long interval = 30;
pinMode(led, OUTPUT);
unsigned long currentMillis = millis(); // grab current time
analogWrite(led, brightness); // set the brightness of ledPin:
if (currentMillis - previousMillis >= interval){
brightness = brightness + fadeAmount; // change the brightness for next time through the loop:
previousMillis = millis();
if (brightness <= 0 || brightness >= 255) { // reverse the direction of the fading at the ends of the fade:
fadeAmount = -fadeAmount;
