Fading a bank of LED's
So for the current project I'm working on, I need to use the arduino to fade in a bank (~20) of parallel LED's. Obviously this is more current than the arduino itself can source, so I need to have the Arduino controlling a transistor that controls the LED's (which are being powered by an outside source).
My question - it seems to me that the PWM used to fade a single LED will no longer work when applied to LED's controlled by a transistor, because the transistor will just be rapidly pulled high and not create a fade...
Does anyone have any help on how I might circumvent this?
(Or am I wrong, and can PWM be used to fade a transistor?)
Quick google searching on how to fade an LED without using PWM brings up this circuit:
http://ourworld.compuserve.com/homepages/Bill_Bowden/page6.htm#eyes2.gif
Which I suppose could be made work using digital outputs alone... But I would like to avoid as much extraneous circuit building as possible.
So If anyone has any ideas on how to make it happen in a simpler fashion- I would love to hear them.
I have used PWM to control the speed of a DC motor controlled through a transistor without any problems, so it should be possible.
Beautiful. I'll give it a shot. Do you know what type of transistor you were using, by any chance?
PWM will work fine through a transistor. Even the cheapest transistor can switch on and off in microseconds.
Try this schematic:
http://www.arduino.cc/playground/uploads/Learning/multiple_leds2.jpg
If uyou use a TIP102 with a small heatsink, you can easily control 50 leds drawing 20ma each.
D
I was using a TIP120, but you are probably better of following Daniels advice and use a TIP1023 wit a heat sink
Where would the TIP1023 go? Would it replace the 2n2222 in the diagram?
See how PWM works:-
http://www.thebox.myzen.co.uk/Tutorial/PWM.html
yes
