fading led for time amount
I want to fade an LED/s on & off for say 10-40 secs
then switches off
After that another led switches on
int ledPin = 9;    // LED connected to digital pin 9
void setup()  {
  // nothing happens in setup
pinMode(3, OUTPUT); //added this code
void loop()  {
  // fade in from min to max in increments of 5 points:
  for(int fadeValue = 0 ; fadeValue <= 255; fadeValue +=5) {
    // sets the value (range from 0 to 255):
    analogWrite(ledPin, fadeValue);
    // wait for 30 milliseconds to see the dimming effect
    delay(30);
  // fade out from max to min in increments of 5 points:
  for(int fadeValue = 255 ; fadeValue >= 0; fadeValue -=5) {
    delay(30);
After this fading goes for 10-40 secs it switches off then turns on another LED
that's all
Permission granted.
Why not make the fading for loop into a function and pass it the pin number to use. Once it is finished doing say pin 9 pass it another pin number.
Each loop takes about 1.5 seconds (255/5*30=1530 mSec) so about 3 seconds for a full cycle. Run that cycle 10 to 13 times (30 to 39 seconds). Repeat with the other LED.
thanks for the replies
well I'm stumped
I actually repeated the cycle but for some reason the led stops dimming half way through after the code runs through
and the other LED doesn't lite up to full brightness either
could there be some sort of 'bug' or limitation for the Arduino (UNO R3) ?
If only we could see the program you have the problem with ........
yeah ok don't laugh I thought this would do though..for starters
int ledPin = 3;    // LED connected to digital pin 3
int ledPin2 = 5;    // LED connected to digital pin 5
void setup()  {
  for(int fadeValue = 0 ; fadeValue <= 255; fadeValue +=8) {
    delay(30);
  for(int fadeValue = 255 ; fadeValue >= 0; fadeValue -=44) {
    delay(30);
    delay(30);
  for(int fadeValue = 255 ; fadeValue >= ; fadeValue -=44) {
    delay(30);
  for(int fadeValue = 1 ; fadeValue <= 255; fadeValue +=8) {
    delay(30);
  for(int fadeValue = 255 ; fadeValue >= 1; fadeValue -=44) {
    delay(30);
    delay(30);
    delay(30);
    delay(30);
    delay(30);
    delay(30);
    delay(30);
    delay(30);
    delay(30);
    delay(30);
    delay(30);
    delay(30);
    delay(30);
    delay(30);
    delay(30);
    delay(30);
    delay(30);
    delay(30);
    delay(30);
  {analogWrite(ledPin, LOW);}
  //{analogWrite(ledPin2, LOW);} //this is for blue leds on always
  {analogWrite(ledPin2, HIGH);} //this is for blue leds on always
void loop()  {
I'm not laughing but I did get bored reading
    delay(30);
    delay(30);
12 times, or was it 11 or maybe 13.
Read up on and use a for loop to run that block of code several times.
Making the comments match the code is always a good idea too to help with understanding it.
As to your problem. Print the value of fadeValue during the fades. Is the value what you expect ?
How is the LED wired ?
Adding a pinMode() command to the code could be helpful.
sorry for that, yeah my code sucks
I will try your suggestions, but it will take a while for me to catch up
the LED is with a 180k resistor in series
thanks for the suggestions I better get to work
cheers
Do you really mean that ?
bah ,
180 Ohms
Hey, You didn't use pinMode(); command to declare pins. How is it working?
I just added it to the code above
there is no difference
I'm still trying to figure how to add a counting method & use it in void loop
I have lost track of what code you are referring to. Please can you post the complete program as it is now ?
void setup()  {
pinMode(5, OUTPUT);
void loop()  {
    delay(30);
    delay(30);
    delay(30);
    delay(30);
    delay(30);
    delay(30);
    delay(30);
    delay(30);
    delay(30);
    delay(30);
    delay(30);
    delay(30);
    delay(30);
    delay(30);
then the program exits the loop and lights an LED
I'm trying to figure that part out
Should the fades repeat or happen only once ?
Do you really mean to turn off ledPin2 then immediately afterwards turn it on ? Why are the braces there ?
In your program suggest that the first thing to do is to tidy up the fading code. Maybe something like this
const byte ledPins[] = {10, 11};
const byte numLeds = sizeof(ledPins) / sizeof(ledPins[0]);
  for (int led = 0; led < numLeds; led++)
    pinMode(ledPins[led], OUTPUT);
    showLed(led);
void showLed(int led)
  for (int level = 0; level <= 255; level +=5)
    Serial.println(level);
    analogWrite(ledPins[led], level);
    delay(100);
  for (int level = 255; level >= 0; level -=5)
    delay(10);
It would be even better without delay()s but you can fix that later.
sorry I've taken a while to reply
the code runs once as you see it but there should be more lines
the problem is that posting the code in the forum will not allow more lines of code
but that looks like garbage anyways after seeing proper coding which I will now attempt
as per UKHeliBob's suggestion
for some reason the Arduino doesn't switch off the leds after the code is completed
So I put in those codes to force the hardware to shut off the leds
I will now work on tidying it all up as suggested
thanks UKHeliBob and everyone
this may take some time for me to learn this proper way to code
Cheers :slight_smile:
