Hiya, I've got this project that's due very soon and I'm out of alternatives so I'm just asking for help now.
I've got a string of LEDs that need to run constantly at 50% and when a button is pressed and held down it will fade up to 100% in 1000ms and hold at 100% as long as the button is pressed, then fade back to 50% when the button is released again in 1000ms.
I tried modifying the code from this thread arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1265105743/2
but i just botched it
any help would be appreciated or point to sample code I can modify.
well i used this.
i really only need 1 LED fade but i didn't bother cutting out the second one.
i just don't quite understand where the "default LED brightness" is in the code. wherever it is it needs to be value 150 or so.
I've got the bank of LEDs running through a transistor, that works fine if i load "fading" to the arduino.
the other part of the mystery to me is where can i tell the code to HOLD the led level once the button is pressed.
any tips will be appreciated!
#define LED1 11
#define LED2 10
#define BUTTON 13
int val = 0;
int oldVal = 0;
int state = 0;
void setup(){
pinMode(LED1,OUTPUT);
pinMode(LED2,OUTPUT);
pinMode(BUTTON,INPUT);
void loop(){
val = digitalRead(BUTTON);
//Serial.println(val);
if((val==HIGH)&&(oldVal==LOW)){
state=1-state;
delay(10);
oldVal=val;
if(state==1){
digitalWrite(LED1,HIGH);
delay(3000);
fading();
state=0;
else{
digitalWrite(LED1,LOW);
void fading(){
int max1=0;
for(int i = 255; i >= 0; i--){ //fade out 1st LED
analogWrite(LED1,i);
delay(10);
max1=i;
Serial.println(max1);
//I know I can't get to max1 outside the loop, thats why its not working
if(max1==128){
for(int i = 255; i >= 0; i--){ //fade out 2nd LED
analogWrite(LED2, i);
delay(10);
Disclaimer: I have not tried this and it looks a bit clunky but maybe it will give you the idea. I think it will probably give odd results for quick button pushes.
#define LED1 11
#define BUTTON 13
int val = 0;
int oldVal = 0;
void setup(){
analogWrite(LED1,128);
void loop(){
fadeup();
else if((val==LOW)&&(oldVal==HIGH)){
fadeback();
oldVal=val;
void fadeup(){ //go from 128 to 255 in 1000 ms
for(int i = 128; i <= 255; i++){ //fade in 1st LED
delay(8); //8*(255-128)=1000-ish
void fadeback(){ //go from 255 to 128 in 1000 ms
delay(8);
oops the fade to 0. right near the beginning of fadeback you can change that to 128,
The code in setup uses analogWrite to turn the led on half power. It will stay that way til something changes it.
every time you go into loop it checks button. If it's gone from low to high, it calls fadeup to analogWrite the led up from halfway to full - 255. If it's gone from high to low it does the reverse.
woo!
pretty close! i needed closer to 50 it seems, came out perfect!
thanks a bunch! and i have a little better understanding as well.
#define LED1 11
#define BUTTON 13
int val = 0;
int oldVal = 0;
void setup(){
analogWrite(LED1,50);
void loop(){
fadeup();
fadeback();
oldVal=val;
for(int i = 50; i <= 255; i++){ //fade in 1st LED
for(int i = 255; i >= 50; i--){ //fade out 1st LED
delay(8);
okay, so after pulling my hair out and having 2 professional programmers look at the code i had one of them clean it up as much as possible. but the problem still existed that when the button was pressed the LEDs faded up, then faded down even though the button was held down. after both programmers picked it apart we finally figured out it wasn't software, it was hardware.
pin 13 of the arduino board is hard wired to an LED, it was causing the problem. moved the digital pin to pin8 and BOOM fixed
bottom line.. RTFM.. lesson learned though.
here be the final code for whoever is interested.
#define LED1 11
#define BUTTON 8
int val = 0;
int oldVal = 0;
void setup(){
void loop(){
if(val==HIGH&&oldVal==LOW){
fadeup();
oldVal = val;
if(val==LOW&&oldVal==HIGH){
fadeback();
oldVal = val;
delay(8);
