Fading LED with button control
Hi guys.
Just got myself a first arduino mega and sorry for the very amateurish question.
Basically, what I want to do is that the LED fades out to totally dark, and when the the button is pressed, the LED restarts fading out.
The circuit is quite easy: pin 12(pwm) -> resister -> LED -> ground; pin 8 -> push button -> pin2.
The problem is that LED fades out again and again, and the button is not working.
Thanks for any help
int pwmout = 12; //Pin 12 as PWM output pin
int out = 8; //Pin 8 as HIGH pin for interrupt
int brightness = 255; //variable for brightness
void setup ()
  pinMode(pwmout,OUTPUT);
  pinMode(out,OUTPUT);
  digitalWrite(out,HIGH);
  attachInterrupt(0,reset,RISING);
void reset ()
  brightness = 255;
void loop ()
  if (brightness != 0)
brightness = brightness-5;
analogWrite(pwmout, brightness);
delay(25);
