alright....I have a working code for my multiple sensors (Parallax PIR and a PING):
int pin = 7;
unsigned long duration;
int ledPin = 13;
int ledPin2 = 12;
int ledPin3 = 11;
int ledPin4 = 10;
int sensorValue = 0;
int val = 0;
pinMode(sensorValue, INPUT);
pinMode(ledPin, OUTPUT);
pinMode(ledPin2, OUTPUT);
pinMode(ledPin3, OUTPUT);
pinMode(ledPin4, OUTPUT);
void getAdistance(){
pinMode(pin, OUTPUT);
digitalWrite(pin, LOW);
delayMicroseconds(5);
digitalWrite(pin, HIGH);
pinMode(pin, INPUT);
duration = pulseIn(pin, HIGH);
getAdistance();
Serial.println(duration, DEC);
val = duration;
if(duration < 2000)
digitalWrite(ledPin2, HIGH);
if(duration < 1000)
digitalWrite(ledPin3, HIGH);
if(duration < 500);
digitalWrite(ledPin4, HIGH);
digitalWrite(ledPin2, LOW);
digitalWrite(ledPin3, LOW);
digitalWrite(ledPin4, LOW);
sensorValue = analogRead(0);
Serial.println(sensorValue, DEC);
if((sensorValue) == 0){
pinMode(0, INPUT);
digitalWrite(ledPin, LOW);
delay(5);
else if((sensorValue) > 1){
pinMode(0, INPUT);
digitalWrite(ledPin, HIGH);
I also found a great fade/pulse code:
// Fading LED
// by Spiffed http://spiffie.org/;
// original by BARRAGAN http://people.interaction-ivrea.it/h.barragan;
int value = 0;
int rep = 0;
int ledpin = 9;
int count = 0; // light connected to digital pin 9
pinMode(ledpin,OUTPUT);
for(value = 4 ; value <= 250; value++) // fade in (from min to max)
for(rep=0;rep <= 10;rep++){
digitalWrite(ledpin, HIGH); // sets the value (range from 0 to 255)
delayMicroseconds(value); // waits for 30 milli seconds to see the dimming effect
digitalWrite(ledpin, LOW);
delayMicroseconds((255-value));
Serial.println(count);
count++;
for(value = 250; value >=4; value--) // fade out (from max to min)
delayMicroseconds(255-value);
Now, I want to put those two together to make all my signals fade....but it's not working, I get multiple errors and I'm starting to go crazy....any ideas anyone?!
int pin = 7;
int rep = 0;
int ledPin = 13;
int ledPin2 = 12;
int ledPin3 = 11;
int ledPin4 = 10;
int val = 0;
int count = 0;
int value = 0;
void fade(){
digitalWrite(ledPin2, HIGH); // sets the value (range from 0 to 255)
count++;
getAdistance();
val = duration;
if(duration < 2000)
digitalWrite(ledPin2, fade());
if(duration < 1000)
digitalWrite(ledPin3, fade());
if(duration < 500);
digitalWrite(ledPin4, fade());
pinMode(0, INPUT);
delay(5);
pinMode(0, INPUT);
digitalWrite(ledPin, fade());
error: invalid use of void expression
In function 'void loop()':
error: invalid use of void expression At global scope:
In function 'void setup()':
