I have written a program for led fading . The program is as below
int value = 0; // variable to keep the actual value
int ledpin = 9; // light connected to digital pin 9
// nothing for setup
for(value = 0 ; value <= 255; value+=5) // fade in (from min to max)
analogWrite(ledpin, value); // sets the value (range from 0 to 255)
delay(30); // waits for 30 milli seconds to see the dimming effect
for(value = 255; value >=0; value-=5) // fade out (from max to min)
delay(30);
Now the problem is that when I change the ledpin from 9 to Analog pins , I am not getting the fading infact the led was not at all lit .
So , am I missing anything here ? Also can we give any other voltage except 0 and 5V using digitalWrite program .
Also can we use analog pins as PWM pins ??
Please reply ...
Analog pins are inputs. If you lack PWM pins, you can use the SoftPWM library to use any digital pin as a PWM (and the analog pins can be set to work as digital outputs).
But we can use analog pins as digital outputs also , right ? (using digitalWrite)
Can we use digitalWrite for assigning any value between 0 to 5V like in the case of analogWrite fn used in PWM pins ?
If you remember to set the pinMode for an analogue pin as OUTPUT, you can do an analogWrite to it, but it will only set the pin LOW if the PWM value you write is less than 128, otherwise, it sets it HIGH - it is not possible to do hardware-driven PWM on the analogue pins.
