Fading Neopixels consecutively on
I have the following code which is used to consecutively turn neopixels on in my strip. Problem is I would like to try and have it so the pixels slowly fade in.
Can anyone recommend what is the best way to try and do this.
Thank you
#define PIN 8
#define NUM_LED 6
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LED, PIN, NEO_GRB + NEO_KHZ800);
const uint32_t RED = strip.Color(255, 0, 0);
const uint32_t OFF = strip.Color(0, 0, 0);
unsigned long startTime = millis();
boolean isFiveSecondsElapsed = false;
uint8_t index = 0;
  strip.begin();
  strip.setBrightness(64);
  SetAllPixelsToOff();
  strip.show(); // Initialize all pixels to 'off'
  if (millis() - startTime >= 5000)
    isFiveSecondsElapsed = true;
  if (isFiveSecondsElapsed)
    strip.setPixelColor(index, RED);
    strip.show();
    index++;
    if (index >6)
      index = 0;
void SetAllPixelsToOff()
  for (uint8_t i = 0; i < NUM_LED; i++)
    strip.setPixelColor(i, OFF);
  strip.show();
What is the point of using a boolean isFiveSecondsElapsed? It's completely redundant. Instead, just:
    strip.show();
    index++;
    if (index >6)
      index = 0;
Okay thanks. (Still learning)
Do you have any idea how to go about the fade on?
