Fading not working for common cathode RGB LED
I’ve tried 5 or so codes I’ve found on blogs online to make my RGB LED fade from one color to another, but all of them end up having the same problem, the color will quickly swap from one color to another after a small amount of fading from green to yellow, or purple to blue. I’ve made sure to alter the code to have the correct pins for R, G, and B. I’ve included one of the example codes here that changes colors, but doesn’t fade as it should. Is there something I’m doing wrong?
// Assign LED Output PWM Pins
int Red = 11;
int Green = 12;
int Blue = 13;
//Set Initial Values
int RedVal = 0;
int GreenVal = 0;
int BlueVal = 0;
int fade = 10;  // Delay Time
// Colour Value 1 as each colour intensity (0-255)
int RedVal1 = 186;
int GreenVal1 = 0;
int BlueVal1 = 255;
// Colour Value 2
int RedVal2 = 9;
int GreenVal2 = 239;
int BlueVal2 = 26;
//Colour Value 3
int RedVal3 = 255;
int GreenVal3 = 120;
int BlueVal3 = 0;
//Colour Value 4
int RedVal4 = 0;
int GreenVal4 = 255;
int BlueVal4 = 78;
//Set initial mode (Colour Value Mode) to Colour Value 1
int mode = 1;
 //----------------------- Assign outputs
   pinMode(Red, OUTPUT);
   pinMode(Green, OUTPUT);
   pinMode(Blue, OUTPUT);
 //----------------------- Write Initial Values of 0 to outputs
   analogWrite(Red, RedVal);
   analogWrite(Green, GreenVal);
   analogWrite(Blue, BlueVal);
void loop()                            // Begin Main Program Loop
  while(mode == 1){
    if(RedVal < RedVal1){              // If RedVal is less than desired RedVal1
      RedVal ++;                       // increment RedVal
    } else if(RedVal > RedVal1){       // If RedVal is more than desired RedVal1
      RedVal --;                       // decrement RedVal
    } else if(RedVal == RedVal1){      // If RedVal is equal to desired RedVal1
      //Do Nothing
                                       // Repeated as above for BlueVal
    if(BlueVal < BlueVal1){
      BlueVal ++;
    } else if(BlueVal > BlueVal1){
      BlueVal --;
    } else if(BlueVal == BlueVal1){
      //Do Nothing
                                       // Repeated as above for GreenVal
    if(GreenVal < GreenVal1){
      GreenVal ++;
    } else if (GreenVal > GreenVal1){
      GreenVal --;
    } else if (GreenVal == GreenVal1){
      // Do Nothing
                                       // Now we have a new set of values, we write them to the PWM Pins.
    delay(fade);                       // Implement a bit of delay to slow the change of colour down a bit
    if(RedVal == RedVal1 && GreenVal == GreenVal1 && BlueVal == BlueVal1){ // If RedVal & GreenVal & BlueVal are all at the desired values
      delay(1500);                     // Delay to hold this colour for a little while
      mode = 2;                        // Change the mode to the next colour. Exiting this while loop and into the next one
  while(mode == 2){
    if(RedVal < RedVal2){
      RedVal ++;
    } else if(RedVal > RedVal2){
      RedVal --;
    } else if(RedVal == RedVal2){
      //Do Nothing
    if(BlueVal < BlueVal2){
      BlueVal ++;
    } else if(BlueVal > BlueVal2){
      BlueVal --;
    } else if(BlueVal == BlueVal2){
      //Do Nothing
    if(GreenVal < GreenVal2){
      GreenVal ++;
    } else if (GreenVal > GreenVal2){
      GreenVal --;
    } else if (GreenVal == GreenVal2){
      // Do Nothing
    delay(fade);
    if(RedVal == RedVal2 && GreenVal == GreenVal2 && BlueVal == BlueVal2){
      delay(1500);
      mode = 3;
     //break;
  while(mode == 3){
    if(RedVal < RedVal3){
      RedVal ++;
    } else if(RedVal > RedVal3){
      RedVal --;
    } else if(RedVal == RedVal3){
      //Do Nothing
    if(BlueVal < BlueVal3){
      BlueVal ++;
    } else if(BlueVal > BlueVal3){
      BlueVal --;
    } else if(BlueVal == BlueVal3){
      //Do Nothing
    if(GreenVal < GreenVal3){
      GreenVal ++;
    } else if (GreenVal > GreenVal3){
      GreenVal --;
    } else if (GreenVal == GreenVal3){
      // Do Nothing
    delay(fade);
    if(RedVal == RedVal3 && GreenVal == GreenVal3 && BlueVal == BlueVal3){
      delay(1500);
      mode = 4;
      //break;
  while(mode == 4){
    if(RedVal < RedVal4){
      RedVal ++;
    } else if(RedVal > RedVal4){
      RedVal --;
    } else if(RedVal == RedVal4){
      //Do Nothing
    if(BlueVal < BlueVal4){
      BlueVal ++;
    } else if(BlueVal > BlueVal4){
      BlueVal --;
    } else if(BlueVal == BlueVal4){
      //Do Nothing
    if(GreenVal < GreenVal4){
      GreenVal ++;
    } else if (GreenVal > GreenVal4){
      GreenVal --;
    } else if (GreenVal == GreenVal4){
      // Do Nothing
    delay(fade);
    if(RedVal == RedVal4 && GreenVal == GreenVal4 && BlueVal == BlueVal4){
      delay(1500);
      mode = 1;                                 // Set mode back to 1 to return to the original colour.
      //break;
Hi, for fading or colour mixing you must use the PWM capable outputs of your Arduino. If some or all are not PWM capable, you will get sudden colour changes.
Assuming you have an Uno (you don't say), then pins 12 and 13 are not PWM capable. Have a look at this page, which tells you which outputs you can use like this:
Paul
I am using an uno, thank you for the info about the pins, I'm using an lcd shield that has limited output pins available, I'll check the diagram and see if I have 8 and 7 available instead of 12 and 13.
oops, not 8 or 7, as they are not pwm compatible
