Fading RGB with speed change
I had a look at the context of the project. What they mean is: The duration of the fading proces is linked to the time a button is pressed. for example, If the button is pressed for 2 seconds then the fading proces takes 2 seconds.
This is the code I currently have
  Fading
  This example shows how to fade an LED using the analogWrite() function.
  The circuit:
  - LED attached from digital pin 9 to ground.
  created 1 Nov 2008
  by David A. Mellis
  modified 30 Aug 2011
  by Tom Igoe
  This example code is in the public domain.
  http://www.arduino.cc/en/Tutorial/Fading
int ledR = 9;    // LED connected to digital pin 9
int ledG = 10;
int ledB = 11;
  // fade in from min to max in increments of 5 points:
  for (int fadeValue = 0 ; fadeValue <= 255; fadeValue += 5) {
    // sets the value (range from 0 to 255):
    analogWrite(9, fadeValue);
    // wait for 30 milliseconds to see the dimming effect
    delay(30);
  // fade out from max to min in increments of 5 points:
  for (int fadeValue = 255 ; fadeValue >= 0; fadeValue -= 5) {
    analogWrite( 9, fadeValue);
    delay(30);
    analogWrite(10, fadeValue);
    delay(30);
    analogWrite( 10, fadeValue);
    delay(30);
    analogWrite(11, fadeValue);
    delay(30);
    analogWrite( 11, fadeValue);
    delay(30);
