Fading Troubleshoot
Hey there!
I am trying to run a LED strip with external power and a BD243c (Data sheet: http://www.bucek.name/pdf/bd243.pdf).
The Arduino is fading nice between 0 and 5V but the LED strip is only doing weird stuff. No clear pattern visible. I tried a 550Ohm resistor bevor the base but no effect.
Transistor should be wired correctly, changing Emitter and Collector had no effect either.
Any help? Thanks a lot
Did you remember to connect the grounds?
Yes, all common grounds
Not a very good transistor for a LED strip, unless the strip is very short.
Low gain, high saturation voltage.
Better get a logic mosfet.
What is the current draw of the strip.
Leo..
