Fading why is this binking the led
It's binking I was using the fade code but it bink's no fade
// These constants used to give names
// to the pins used:
const int analogInPin = A0;  // Analog input pin that the PIR is attached to
int sensorValue = 0;        // value read from the PIR
int ledPin = 8;
   pinMode(ledPin, OUTPUT);      // sets the digital pin as output
  // initialize serial communications at 9600 bps:
  // read the analog in value:
  sensorValue = analogRead(analogInPin);
  // print the results to the serial monitor:
  Serial.print("sensor = ");
  Serial.print(sensorValue);
  Serial.print("\t output = ");
  Serial.println(sensorValue);
  if (sensorValue >= 500 )
   digitalWrite(ledPin, HIGH);
    // fade out from max to min in increments of 5 points:
  for (int fadeValue = 255 ; fadeValue >= 0; fadeValue -= 5) {
    // sets the value (range from 0 to 255):
    analogWrite(ledPin, fadeValue);
    // wait for 30 milliseconds to see the dimming effect
    delay(30);
  // wait 2 milliseconds before the next loop
  // for the analog-to-digital converter to settle
  // after the last reading:
  delay(200);
Pin 8 isn't a pwm pin, on a Uno anyway. Check the printing on the board, there's no ~ next to pin 8.
Thanks man I wasn't thinking it was hardware pwm That fixed it. fading is working but it's running the fade loop
What do you mean by
is that a question?
Kind of I guess the thing is just sitting and fading but i think i got it figured out
What does the sensor value say? that's what drives the fading or not
This is what im trying for if sensor value >= 500 the led stays on if it drops below 500 the led is to fade out.
Then stay off till the sensor value goes above 500
It read about 780 as long as there is something moving
Every time through loop() if the sensor's under 500 it does your 255 to 0 for loop: it doesn't know you only mean to fade once until it goes solid on with a >500 and then hits the new first <500 to fade later.
You need a flag, say a boolean called "goneHigh" which you set when the sensor is over 500, ie when you on the led. Then your test for under 500 needs to include a test to see if goneHigh is true. If it is high, do the dimming thing AND set goneHigh to false.
The PIR output is HIGH or LOW, just use a digital pin and check for HIGH or LOW.
edgemoron Thanks that was next on my list I was kind of testing it out last night to see if it works and what it pt out
it's going from 0 to around 3.8 volts so it would workout nice.
