Fading with LEDFader library?
Hi all having a little trouble with the bellow. When my pir input goes low, the led output remains static on its last value.
#include <LEDFader.h>
LEDFader led = LEDFader(3); // Create LED Fader on pin 1
const int pirPin = 2;     // the number of the pir pin
const int ledPin =  3;      // the number of the LED pin
int pirState = 0;
  pinMode(ledPin, OUTPUT);// initialize the LED pin as an output:
  pinMode(pirPin, INPUT); // initialize the pushbutton pin as an input:
  Serial.begin(9600);     // open the serial port at 9600 bps:
  pirState = digitalRead(pirPin); //Check pin state
    if (pirState == HIGH)
      led.update(); // Start cycle, update led
      Serial.println(led.get_value());//for debug
        if (led.is_fading() == false)
          if (led.get_value() == 255) //Check led value
            led.fade(0, 2500);// Fade from 255 - 0
            led.fade(255, 500); // Fade from 0 - 255
      Serial.println(led.get_value()); //for debug
      led.fade(0, (led.get_value() * 3)); //Return to zero from given led state
Seems the problem is in this line. Can anoyone advise?
Thanks in advance
Steve
Strange that the value 3 means pin 1.
Strange to use a hardware serial pin for the fader at the same time that you are using Serial.
Ah, i originally had the code on an attiny85 (digispark) and didnt edit the coments properly when moving it over to a nano.
Edit: The LedFader pin is D3 on the nano
