I’m trying to use dweet.io trough an ESP8266 ESP-1 module connected to an Arduino Uno board.
The problem is that I’m able to make a connection trough AT+CIPSTART when using AT commands directly on the ESP8266, but i’m unable to do the same throughout an Arduino sketch via SoftwareSerial!
I used my own web server to see why it fails, and the direct AT commands that worked are these:
AT+CIPSTART=0,"TCP","homepages.myownsite.com",80
AT+CIPSEND=0,70
GET /docs/TestDocument.pdf HTTP/1.1
Host: homepages.myownsite.com
AT+CIPCLOSE=0
However, this sketch with the same AT commands fails:
#include <SoftwareSerial.h>
#include <stdlib.h>
// RX ESP -> TX Arduino
// TX ESP -> RX Arduino
SoftwareSerial ESPSerial(10, 11); // RX, TX
// this runs once
// enable debug serial
// enable software serial
ESPSerial.begin(115200);
delay(2000);
Serial.println("AT+CIPMUX=1");
ESPSerial.println("AT+CIPMUX=1");
// the loop
delay(2000);
Serial.println("AT+CIPSTART=0,\"TCP\",\"homepages.myownsite.com\",80");
ESPSerial.println("AT+CIPSTART=0,\"TCP\",\"homepages.myownsite.com\",80");
delay(2000);
Serial.println("AT+CIPSEND=0,70");
ESPSerial.println("AT+CIPSEND=0,70");
delay(2000);
Serial.print("GET /docs/TestDocument.pdf HTTP/1.1\r\nHost: homepages.myownsite.com\r\n\r\n");
ESPSerial.print("GET /docs/TestDocument.pdf HTTP/1.1\r\nHost: homepages.myownsite.com\r\n\r\n");
delay(6000);
//Close connection
Serial.println("AT+CIPCLOSE=0");
ESPSerial.println("AT+CIPCLOSE=0");
To monitor the response of my Web server I used the command sudo tail -f /var/log/apache2/access.log
. I noticed that with the direct AT commands I always get a response, even when it was a 400
response. However, with the sketch there isn’t any response, and yes I also tried with a bigger sketch where all the connections are established, including AT+CWJAP
, and everything works just fine until the GET
command, it looks like the SoftwareSerial is unable to post HTML commands like GET
It would be helpful to see the Serial ESP8266 response to the sketch commands, but I don’t know how to do it, I’m only able to monitor the Arduino Serial (9600) when commanding the board trough a sketch!
Any suggestions?
Thanks
