Yes, because in the coding, I switch off everything except that.
Ok and the wire length?
approximately 80 cm for the lcd and 50 cm for both sensors
Well that is a big problem.
I2C was not designed to drive long wires, or multiple long wires and those long wires are also quite susceptible to EMI
ohhh I just found that out, thank you for the knowledge sir, later I will try to shorten the cable.
if there are still problems later I will reply again in your comment hehehehe
In general a good idea.
You also might try slowing down the I2C clock
Wire.setClock(10000)
