Hi, i try to setup my brand new Uno Wifi Rev.2 with new Braccio but i'm not able to upload. I followed the Guide and tried:
-checked port
-checked Board
-Reinstalled Drivers
-try uploading blank sketch
-try blink preset
- dif usb ports
- dif usb cable
-dif computer - Reset before and after pressing upload in div time frames
- disconnecting all BT or Wifi sticks
- deinstalling older Adeept related IDE
- Reinstalling Arduino IDE
What am i missing here? I'm completely new to this so it's prob my fault...
please help
Sofie
My Setup:
Uno Wifi Rev.2
Connected via usb cable -
Win 10 Pro 64 20H2
Build:19042.804
(i never was able to upload to this Uno)
Der Sketch verwendet 924 Bytes (2%) des Programmspeicherplatzes. Das Maximum sind 32256 Bytes.
Globale Variablen verwenden 9 Bytes (0%) des dynamischen Speichers, 2039 Bytes für lokale Variablen verbleiben. Das Maximum sind 2048 Bytes.
C:\Users\sofie\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\sofie\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM6 -b115200 -D -Uflash:w:C:\Users\sofie\AppData\Local\Temp\arduino_build_867742/Blink.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\sofie\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM6
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xf9
avrdude done. Thank you.
Problem beim Hochladen auf das Board. Hilfestellung dazu unter http://www.arduino.cc/en/Guide/Troubleshooting#upload.
