Failed Bootloading Arduino Duemilanove  using MEGA
Hey, I'm trying to burn Bootloader on Arduino Duemilanove using Arduino MEGA. Tried the following: 1. Followed arduino.cc / en / Tutorial/ ArduinoISP with the only difference that my Programmer board is MEGA. (Used the same pin numbers for the connections and chose the boards accordingly)
  1. Followed : benjohansen [dot] com/ archives/ 755 Getting the following error:
avrdude: stk500_program_enable(): protocol error, expect=0x14, resp=0x50 avrdude: initialization failed, rc=-1 * Double check connections and try again, or use -F to override* * this check.* avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
Can some one help???
I dont think the MEGA has the same SPI pins as the Duemilanove.
IIRC, someone asked something similar not a long time back.
