I have this material :
https://www.amazon.fr/gp/product/B088LSTG9P
I Install :
Blynk library
In preference I past
https://arduino.esp8266.com/stable/package_esp8266com_index.json
In Tools I have correctly selected my [b]generic esp8266 module[/b]
My code:
Download latest Blynk library here:
https://github.com/blynkkk/blynk-library/releases/latest
Blynk is a platform with iOS and Android apps to control
Arduino, Raspberry Pi and the likes over the Internet.
You can easily build graphic interfaces for all your
projects by simply dragging and dropping widgets.
Downloads, docs, tutorials: http://www.blynk.cc
Sketch generator: http://examples.blynk.cc
Blynk community: http://community.blynk.cc
Follow us: http://www.fb.com/blynkapp
http://twitter.com/blynk_app
Blynk library is licensed under MIT license
This example code is in public domain.
This example runs directly on ESP8266 chip.
Note: This requires ESP8266 support package:
https://github.com/esp8266/Arduino
Please be sure to select the right ESP8266 module
in the Tools -> Board menu!
Change WiFi ssid, pass, and Blynk auth token to run :)
Feel free to apply it to any other example. It's simple!
/* Comment this out to disable prints and save space */
#define BLYNK_PRINT Serial
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "TOKEN";
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "NAME";
char pass[] = "PASSWORD";
// Debug console
Blynk.begin(auth, ssid, pass);
Blynk.run();
Error :
Arduino : 1.8.14 Hourly Build 2021/03/09 09:33 (Windows 10), Carte : "Generic ESP8266 Module, 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), dtr (aka nodemcu), 26 MHz, 40MHz, DOUT (compatible), 1MB (FS:64KB OTA:~470KB), 2, nonos-sdk 2.2.1+100 (190703), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
Executable segment sizes:
IROM : 247892 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 27928 / 32768 - code in IRAM (ICACHE_RAM_ATTR, ISRs...)
DATA : 1328 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 2236 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 25544 ) - zeroed variables (global, static) in RAM/HEAP
Le croquis utilise 279384 octets (29%) de l'espace de stockage de programmes. Le maximum est de 958448 octets.
Les variables globales utilisent 29108 octets (35%) de mémoire dynamique, ce qui laisse 52812 octets pour les variables locales. Le maximum est de 81920 octets.
esptool.py v2.8
Serial port COM1
Connecting........_____....._____....._____....._____....._____....._____.....____Traceback (most recent call last):
File "C:\Users\natfe\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.3/tools/upload.py", line 65, in <module>
esptool.main(cmdline)
File "C:/Users/natfe/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/esptool\esptool.py", line 2890, in main
esp.connect(args.before)
File "C:/Users/natfe/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/esptool\esptool.py", line 483, in connect
raise FatalError('Failed to connect to %s: %s' % (self.CHIP_NAME, last_error))
esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header
_
[pre]Normally I have to do as in the picture is insert the key at the same time but I don't have the impression that it works
and I have a feeling that it is not detected because on any place where I plug it. I only detect COM1[/pre]
