Failed to copy the image from fingerprint sensor 1 to fingerprint sensor 2
#include <Adafruit_Fingerprint.h>
#define mySerial1 Serial1 // Use Serial1 for Fingerprint Sensor 1
#define mySerial2 Serial2 // Use Serial2 for Fingerprint Sensor 2
Adafruit_Fingerprint finger1 = Adafruit_Fingerprint(&mySerial1);
Adafruit_Fingerprint finger2 = Adafruit_Fingerprint(&mySerial2);
// Simulated database for storing fingerprint data
#define MAX_FINGERPRINTS 10 // Adjust this number based on your needs
uint8_t fingerprintDatabase[MAX_FINGERPRINTS][512]; // Array to hold fingerprint data
// Function declarations
uint8_t getFingerprintEnroll(uint8_t id);
void copyImageToSensor2(uint8_t id);
uint8_t readnumber(void);
void registerFingerprint();
void verifyFingerprint();
    while (!Serial);  // Wait for Serial to initialize
    Serial.println("Fingerprint System Initialized");
    // Set the data rate for the sensor serial ports
    finger1.begin(57600);
    finger2.begin(57600);
    if (finger1.verifyPassword()) {
        Serial.println("Found fingerprint sensor 1!");
        Serial.println("Did not find fingerprint sensor 1 :(");
        while (1); // Halt if sensor is not found
    if (finger2.verifyPassword()) {
        Serial.println("Found fingerprint sensor 2!");
        Serial.println("Did not find fingerprint sensor 2 :(");
uint8_t readnumber(void) {
    uint8_t num = 0;
    while (num == 0) {
        while (!Serial.available());
        num = Serial.parseInt();
    return num;
    Serial.println("Press 1 to Register or 2 to Verify:");
    int choice = readnumber();
    switch (choice) {
        case 1:
        case 2:
        default:
            Serial.println("Invalid choice. Please press 1 or 2.");
void registerFingerprint() {
    Serial.println("Ready to enroll a fingerprint!");
    Serial.println("Please type in the ID # (from 1 to 9) you want to save this finger as...");
    uint8_t id = readnumber();
    if (id == 0 || id >= MAX_FINGERPRINTS) { // ID #0 not allowed, try again!
        return;
    Serial.print("Enrolling ID #");
    Serial.println(id);
    if (getFingerprintEnroll(id)) {
        Serial.println("Enrollment successful!");
        copyImageToSensor2(id); // Copy the image to Sensor 2
        Serial.println("Enrollment failed.");
uint8_t getFingerprintEnroll(uint8_t id) {
    int p = -1;
    Serial.print("Waiting for valid finger to enroll as #"); Serial.println(id);
    while (p != FINGERPRINT_OK) {
        p = finger1.getImage();
        switch (p) {
            case FINGERPRINT_OK:
                Serial.println("Image taken");
            case FINGERPRINT_NOFINGER:
                Serial.print(".");
            case FINGERPRINT_PACKETRECIEVEERR:
                Serial.println("Communication error");
            case FINGERPRINT_IMAGEFAIL:
                Serial.println("Imaging error");
            default:
                Serial.println("Unknown error");
    // OK success!
    p = finger1.image2Tz(1);
    if (p != FINGERPRINT_OK) {
        Serial.println("Error converting image to template");
        return p;
    Serial.println("Remove finger");
    delay(2000);
    p = 0;
    while (p != FINGERPRINT_NOFINGER) {
    Serial.print("ID "); Serial.println(id);
    p = -1;
    Serial.println("Place same finger again");
        switch (p) {
                Serial.print(".");
            default:
    // OK success!
    p = finger1.image2Tz(2);
        return p;
    // Create a model
    Serial.print("Creating model for ID "); Serial.println(id);
    p = finger1.createModel();
        Serial.println("Error creating model");
        return p;
    // Store the model
    p = finger1.storeModel(id);
        Serial.println("Error storing model");
        return p;
    Serial.println("Stored!");
    return FINGERPRINT_OK;
void copyImageToSensor2(uint8_t id) {
    Serial.print("Copying image to Sensor 2 for ID #");
    Serial.println(id);
    // Load the model from the simulated database
    if (fingerprintDatabase[id][0] != 0) { // Check if there's data
        // Store the model in Sensor 2
        int p = finger2.storeModel(id);
        if (p == FINGERPRINT_OK) {
            Serial.println("Image copied to Sensor 2 successfully!");
            Serial.print("Error storing image in Sensor 2: ");
            Serial.println(p);
        Serial.println("No data found for this ID in the database.");
void verifyFingerprint() {
    Serial.println("Please place your finger on either sensor for verification...");
    int p = -1;
            Serial.println("Image taken from Sensor 1");
        p = finger2.getImage();
            Serial.println("Image taken from Sensor 2");
            Serial.println("Failed to convert image from Sensor 1");
            return;
        p = finger2.image2Tz(2);
            Serial.println("Failed to convert image from Sensor 2");
            return;
        p = finger1.fingerFastSearch();
            Serial.println("Fingerprint verified with Sensor 1!");
            p = finger2.fingerFastSearch();
                Serial.println("Fingerprint verified with Sensor 2!");
                Serial.println("Verification failed.");
I am trying to send and upload the image data from registering on fingerprint sensor 1 to fingerprint sensor 2 and use either of it for verifying fingerprint.
I even try hex it is sending but when I try to verify my fingerprint on sensor 2 it is not reading.
Post an annotated schematic showing how you have wired this and links to technical information on the sensors.
Post here in the forum
