#include "DHT.h" // Including DHT22 library
#include "LiquidCrystal.h" // Including LCD library
#define DHTPIN 6 // Declaring pin 6 for communicating to DHT22 sensor
#define DHTTYPE DHT22 // Declaring the type of DHT sensor we are using (DHT22 or DHT11)
DHT dht(DHTPIN, DHTTYPE); // Declaring DHT connection and type
LiquidCrystal lcd(12,11,10,9,8,7); // Declaring LCD connections
int Motor_Pin1 = 4; // pin 2 on L293D
int Motor_Pin2 = 3; // pin 7 on L293D
int Enable = 5; // pin 1 on L293D
int val;
int button = 2; //button input on arduino pin 2
int count=0;
int total=0;
pinMode(Motor_Pin1, OUTPUT);
pinMode(Motor_Pin2, OUTPUT);
pinMode(Enable, OUTPUT);
pinMode(button, INPUT);
lcd.begin(16,2); // Initializes the 16x2 LCD
dht.begin(); // Initializes DHT sensor
lcd.clear(); // Clear LCD
float temp = dht.readTemperature(); // Reading the temperature in Celsius
float hum = dht.readHumidity (); //Reading the humidity
if (isnan(temp)) { // Validating received data
lcd.print("Failed to read");
return;
val=digitalRead(button);
if (val==HIGH){
total=count++;
delay (250);
if(total>=3){
total=0;
lcd.setCursor(0,0);
if(total=0){{
lcd.print(total);
lcd.print(" T:");
lcd.print(temp); // Writing temperature in the first row
lcd.print("C");
lcd.setCursor(0,1);}
if(temp <25 ) { // If the temperature less than 25
analogWrite(Enable,0); // 0% PWM duty cycle
lcd.print("Fan OFF ");
delay(100);
else if(temp>=25 & temp<30) { // If the temperature is between 25 & 30
analogWrite(Enable, 77); // 30% of maximum duty cycle value (255).
lcd.print("Fan Speed: 30% ");
delay(100);
else if(temp>=30 & temp<35) { // If the temperature is between 30 & 35
analogWrite(Enable, 153); // 60% of maximum duty cycle value (255).
lcd.print("Fan Speed: 60% ");
delay(100);
else if(temp>=35) { // If the temperature is above 35
analogWrite(Enable, 255); // 100% duty cycle
lcd.print("Fan Speed: 100% ");
delay(100);
else if(total=1){{
lcd.print(total);
lcd.print(" H:");
lcd.print(hum);
lcd.print("%");
if(hum>=85) { // If the temperature is above 35
delay(100);
else if(hum>=80 & hum<85) { // If the temperature is between 30 & 35
delay(100);
else if(hum<80) { // If the temperature less than 25
delay(100);
else if(total=2){{
lcd.print(total);
lcd.print("T:");
lcd.print("C");
lcd.setCursor(0,1);
lcd.print("H:");
lcd.print(hum);}
if((temp>=35)|(hum>=85)) { // If the temperature is above 35
lcd.print(" F:100%");
delay(100);
else if((temp>=30 & temp<35)|(hum>=80 & hum<85)) { // If the temperature is between 30 & 35
lcd.print(" F:60%");
delay(100);
lcd.print("F:30%");
delay(100);
else if(temp <25 | hum <80 ) { // If the temperature less than 25
lcd.print("F:OFF");
delay(100);
digitalWrite(Motor_Pin1, LOW); // To drive the motor in a particular direction
digitalWrite(Motor_Pin2, HIGH); // To drive the motor in a particular direction
delay(2000); // 2 seconds delay
Every time I am keep getting "Failed to read" message on my LCD.
Where are the mistake i did in this coding or SCHEMATIC.
