Recently I followed Nick Gammon's guide to burn the bootloader to the ATmega328P -PU and use the chip at 8Mhz (internal RC oscillator). The process went smoothly so I decided to switch to using the ATmega328P U-TH (smd chip) too. However after burning the bootloader successfully according to Nick Gammon's "How to make an Arduino-compatible minimal board". I'm now unable to upload any code to the ATmega328P U-TH using the CP2102 USB to Uart module. The Usb-Uart module works completely fine as I have plugged it back to the ATmega328P-PU breadboard I made earlier and it still works as normal.
The board that I made is wired like this:
IC: ATmega328P U-TH
GND: Pin 3,5,21
Vcc: Pin 4,6,18
A 100nf ceramic capacitor between pin 3 & 4, pin 5 & 6, pin 18 & 21
Reset: Pin 29 to 10K Ohm to Vcc
Pin 30(RX) to TXD of Usb-Uart
Pin 31(TXD) to Rx of Usb-Uart
Pin 29(Reset) in series to 100nF capacitor to DTR of Usb-Uart
Vcc and Gnd to the respective Vcc (3.3V) and Gnd of Usb-Uart
Yes I've check continuity of all the wire on my board. I'm using the TQFP to DIP breakout board to make the SMD Atmega328P U-TH breadboard compatible. All the capacitors are soldered on the header of the breakout board so it shouldn't be too far from the chip. The error output is below:
Arduino: 1.8.13 (Windows 10), Board: "LilyPad Arduino, ATmega328P"
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 57600
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0xfc
Hardware Version: 2
Firmware Version: 0.16
Vtarget : 420030.5 V
Varef : 197961888.0 V
Oscillator : 0.531 Hz
SCK period : 11340798.7 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\Admin\AppData\Local\Temp\arduino_build_467026/ASCIITable.ino.hex"
avrdude: writing flash (1954 bytes):
Writing | ################################################## | 100% 0.56s
avrdude: 1954 bytes of flash written
avrdude: verifying flash memory against C:\Users\Admin\AppData\Local\Temp\arduino_build_467026/ASCIITable.ino.hex:
avrdude: load data flash data from input file C:\Users\Admin\AppData\Local\Temp\arduino_build_467026/ASCIITable.ino.hex:
avrdude: input file C:\Users\Admin\AppData\Local\Temp\arduino_build_467026/ASCIITable.ino.hex contains 1954 bytes
avrdude: reading on-chip flash data:
Reading |
avrdude: stk500_paged_load(): (a) protocol error, expect=0x10, resp=0x00
###avrdude: stk500_cmd(): programmer is out of sync
avr_read(): error reading address 0x0000
read operation not supported for memory "flash"
avrdude: failed to read all of flash memory, rc=-2
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0xe0
avrdude done. Thank you.
Could anyone tell me what did I do wrong? Maybe I'm missing something.
Thank you so much for your time
