Failed to Upload Sketch Error Solution
Issue:
This error appears during the process of uploading code (a "sketch") to a microcontroller or development board. It could stem from incorrect settings, hardware issues, or code that exceeds the available memory, preventing successful upload.
Solution:
This particularly occurs while interfacing esp32 micro controller with Arduino ide, the solution to this is that we correct board type is selected and the conditional USB cable is used, if problem still persists following is the solution:
Press the EN button once,
Press and hold the BOOT button, until 4-5 strands of communication lines appears on serial monitor,
Then release the BOOT button.
Looks to me that ChatGPT has become a member of the Arduino forum.
