Failed to upload the Arduino ISP programmer sketch to Arduino nano
When I was burning the bootloader to my Arduino uno using the Arduino nano I bought for this specific purpose even though I could used another thing I don't know what it was called but anyway I tried all usb ports on my laptop (not including usb c). This is the output and the hardware I'm using.
Windows 10
Arduino IDE 2.0.3
programmer for bootloader: Arduino nano
Target board: Arduino uno (u might recognize this from the past posts)
Output:
Sketch uses 4354 bytes (14%) of program storage space. Maximum is 30720 bytes.
Global variables use 482 bytes (23%) of dynamic memory, leaving 1566 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x0f
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x0f
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x0f
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x0f
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x0f
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x0f
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x0f
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x0f
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x0f
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x0f
Failed uploading: uploading error: exit status 1
Thanks
the output is a sketch upload, not bootloader burn output.
if you are unable to upload to the Nano, try to select in Tools menu Processor other option
Take a look at Burn Bootloader | Troubleshooting Guide For Arduino
Why such an old IDE version?
Did you try a different and known good data cable?
I meant 2.0.3
