Failed uploading exit status 1
Hello,
I have two Nano V3.0 Atymega3238P/chc40, Arduinos. Each with their own cable the cables both work the Nanos come up on my port lists but when I try to lad blink i get
Sketch uses 924 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
"C:\Users\jkeen\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\jkeen\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega328p -carduino "-PCOM3" -b115200 -D "-Uflash:w:C:\Users\jkeen\AppData\Local\Temp\arduino\sketches\E2069D96441576E4049F4F77BDAE79ED/Blink.ino.hex:i"
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
     System wide configuration file is "C:\Users\jkeen\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
     Using Port                    : COM3
     Using Programmer              : arduino
     Overriding Baud Rate          : 115200
avrdude: ser_open(): can't set com-state for "\.\COM3"
avrdude done. Thank you.
Failed uploading: uploading error: exit status 1
Try the advice in Port monitor error: command 'open' failed: Invalid serial port. Could not connect to COM serial port - #49 by ptillisch.
under my listed ports \I have oem38.inf(ch341ser.inf) 3 times then usbser.inf
Hi @pacific10. Select View > Devices by type from the Windows Device Manager menus.
Use code tags to format code for the forumSketch uses 924 bytes (3%) of program storage space. Maximum is 30720 bytes.
"C:\Users\jkeen\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\jkeen\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega328p -carduino "-PCOM3" -b115200 -D "-Uflash:w:C:\Users\jkeen\AppData\Local\Temp\arduino\sketches\37479BE5F5D9440E8718F7DB077CE4A0/Blink.ino.hex:i"
     Using Port                    : COM3
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xf2
Failed uploading: uploading error: exit status 1Use code tags to format code for the forum
Even if it doesn't seem like it, this is actually good progress!
The upload is now failing with a new error:
This tells us that you have fixed the driver problem that caused the upload to previously fail with the "avrdude: ser_open(): can't set com-state for "\.\COM3"" error.
So now we must find the fix for the unrelated problem that is causing this new error.
A program called a "bootloader" is stored in a special area of memory in the Nano board's microcontroller. The classic Nano (as well as its 3rd party derivatives) have been manufactured with two different types of bootloader installed.
You must configure the Tools > Processor menu in Arduino IDE according to which bootloader is installed on your Nano. Having the incorrect configuration selected in this menu is one of the potential causes of uploads failing with the "avrdude: stk500_recv(): programmer is not responding" error.
I can see from the verbose upload output that you have Arduino IDE incorrectly configured for use with the Nano boards that have the modern bootloader.
Select Tools > Processor > ATmega328P from the Arduino IDE menus to configure it for use with the modern bootloader and then try uploading again.
Hopefully this time the upload will finish successfully.
> type or paste code here
```Sketch uses 924 bytes (3%) of program storage space. Maximum is 30720 bytes.
         Using Port                    : COM3
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x0f
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x0f
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x0f
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x0f
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x0f
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x0f
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x0f
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x0f
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x0f
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x0f
Failed uploading: uploading error: exit status 1`
`This is on AMega328P
Sorry, I should have written "Select Tools > Processor > ATmega328P (Old Bootloader) from the Arduino IDE menus." in my previous reply.
Please make that menu selection and then try uploading again.
     System wide configuration file is "C:\Users\\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
     Using Port                    : COM3
     Overriding Baud Rate          : 57600
     AVR Part                      : ATmega328P
     Chip Erase delay              : 9000 us
     PAGEL                         : PD7
     BS2                           : PC2
     RESET disposition             : dedicated
     RETRY pulse                   : SCK
     serial program mode           : yes
     parallel program mode         : yes
     Timeout                       : 200
     StabDelay                     : 100
     CmdexeDelay                   : 25
     SyncLoops                     : 32
     ByteDelay                     : 0
     PollIndex                     : 3
     PollValue                     : 0x53
     Memory Detail                 :
                              Block Poll               Page                       Polled
       Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
       eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
       flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
       lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
       signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
     Programmer Type : Arduino
     Description     : Arduino
     Hardware Version: 2
     Firmware Version: 1.16
     Vtarget         : 0.0 V
     Varef           : 0.0 V
     Oscillator      : Off
     SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\jkeen\AppData\Local\Temp\arduino\sketches\37479BE5F5D9440E8718F7DB077CE4A0/Blink.ino.hex"
avrdude: writing flash (924 bytes):
Writing | ################################################## | 100% 0.31s
avrdude: 924 bytes of flash written
I think its working thank you. Blink uploaded
You are welcome. Yes, this output indicates uploads are working perfectly now. Congratulations!
Regards,
Per
