Hey Hey, everyone! Need help.
I've having problems with this ESP32CAM. I'm having troubles uploading. I'm using an ESP32 - CAM - MB. It's my first time using it and can't even get it to start. I'm keep on having troubles with the similar error with using different boards on IDE. ESP32 Dev Module, AI Thinker ESP32-CAM, even DOIT. None of them work. I tried formatting the sd card to FAT32. Still doesn't work. Changed all the hard wares (tried in different ESP32 cams). Nothing's working. What am I doing wrong?
Sketch uses 1556761 bytes (49%) of program storage space. Maximum is 3145728 bytes.
Global variables use 94364 bytes (28%) of dynamic memory, leaving 233316 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.5.1
Serial port COM3
A serial exception error occurred: Cannot configure port, something went wrong. Original message: PermissionError(13, 'A device attached to the system is not functioning.', None, 31)
Note: This error originates from pySerial. It is likely not a problem with esptool, but with the hardware connection or drivers.
For troubleshooting steps visit: https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html
Failed uploading: uploading error: exit status 1
