Failed while uploading code on arduino ide for testing ESP WROVER Kit 4.1
esptool.py v4.6
Serial port /dev/ttyUSB0
Connecting......................................
A fatal error occurred: Failed to connect to ESP32: No serial data received.
For troubleshooting steps visit: Troubleshooting - ESP32 - — esptool.py latest documentation
Failed uploading: uploading error: exit status 2
Hi @w_roo_ver_1. This error might be caused by having the wrong port selected from the Tools > Port menu in Arduino IDE.
Please perform this experiment to verify that the port you have selected is your Arduino board:
  1. Disconnect the USB cable of the Arduino board from your computer.
  2. Select Tools > Port from the Arduino IDE menus.
  3. Take note of the ports, if any, listed in the menu.
  4. Close the Tools menu.
    :exclamation: The ports list is only updated when the Tools menu is re-opened, so this step is essential.
  5. Connect the Arduino board to your computer with a USB cable.
  6. Select Tools > Port from the Arduino IDE menus. - If a new port is listed in the menu, that is the port of your Arduino board.
Select that port from the menu and try uploading again.
If the upload still fails, or if no new port appeared after you plugged the Arduino board into your computer, add a reply here to let us know and we'll investigate the problem further.
Already tested with interchanging the port.Same error persists.
Please try this:
  1. Select Sketch > Upload from the Arduino IDE menus.
  2. Watch the black output panel at the bottom of the Arduino IDE window until you see this text printed:
    Connecting...
  3. Press and hold the button on your ESP32 board.
    if your board has multiple buttons, you might have to do some trial and error to determine which is the one you need to press.
  4. Wait about one second.
  5. Release the button.
The upload should now finish successfully.
Tried with both the button pressed and upload the same error
the error message is
FQBN: esp32:esp32:esp32wrover
Using board 'esp32wrover' from platform in folder: /home/amma/.arduino15/packages/esp32/hardware/esp32/3.0.3
Using core 'esp32' from platform in folder: /home/amma/.arduino15/packages/esp32/hardware/esp32/3.0.3
/usr/bin/env bash -c "[ ! -f "/tmp/.arduinoIDE-unsaved2024631-8558-e14wiq.ym3b/sketch_jul31c"/partitions.csv ] || cp -f "/tmp/.arduinoIDE-unsaved2024631-8558-e14wiq.ym3b/sketch_jul31c"/partitions.csv "/tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972"/partitions.csv"
/usr/bin/env bash -c "[ -f "/tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972"/partitions.csv ] || [ ! -f "/home/amma/.arduino15/packages/esp32/hardware/esp32/3.0.3/variants/esp32"/partitions.csv ] || cp "/home/amma/.arduino15/packages/esp32/hardware/esp32/3.0.3/variants/esp32"/partitions.csv "/tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972"/partitions.csv"
/usr/bin/env bash -c "[ -f "/tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972"/partitions.csv ] || cp "/home/amma/.arduino15/packages/esp32/hardware/esp32/3.0.3"/tools/partitions/default.csv "/tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972"/partitions.csv"
/usr/bin/env bash -c "[ -f "/tmp/.arduinoIDE-unsaved2024631-8558-e14wiq.ym3b/sketch_jul31c"/bootloader.bin ] && cp -f "/tmp/.arduinoIDE-unsaved2024631-8558-e14wiq.ym3b/sketch_jul31c"/bootloader.bin "/tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972"/sketch_jul31c.ino.bootloader.bin || ( [ -f "/home/amma/.arduino15/packages/esp32/hardware/esp32/3.0.3/variants/esp32"/bootloader.bin ] && cp "/home/amma/.arduino15/packages/esp32/hardware/esp32/3.0.3/variants/esp32"/bootloader.bin "/tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972"/sketch_jul31c.ino.bootloader.bin || python3 "/home/amma/.arduino15/packages/esp32/tools/esptool_py/4.6"/esptool.py --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "/tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972"/sketch_jul31c.ino.bootloader.bin "/home/amma/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.1-dc859c1e67/esp32"/bin/bootloader_qio_80m.elf )"
esptool.py v4.6
Creating esp32 image...
Merged 1 ELF section
Successfully created esp32 image.
/usr/bin/env bash -c "[ ! -f "/tmp/.arduinoIDE-unsaved2024631-8558-e14wiq.ym3b/sketch_jul31c"/build_opt.h ] || cp -f "/tmp/.arduinoIDE-unsaved2024631-8558-e14wiq.ym3b/sketch_jul31c"/build_opt.h "/tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972"/build_opt.h"
/usr/bin/env bash -c "[ -f "/tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972"/build_opt.h ] || : > "/tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972"/build_opt.h"
/usr/bin/env bash -c ": > '/tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972/file_opts'"
Detecting libraries used...
/home/amma/.arduino15/packages/esp32/tools/esp-x32/2302/bin/xtensa-esp32-elf-g++ -c @/home/amma/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.1-dc859c1e67/esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="linux" -DARDUINO_FQBN="esp32:esp32:esp32wrover:UploadSpeed=921600,FlashFreq=80,FlashMode=qio,PartitionScheme=default,DebugLevel=none,EraseFlash=none" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 @/home/amma/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.1-dc859c1e67/esp32/flags/defines -I/tmp/.arduinoIDE-unsaved2024631-8558-e14wiq.ym3b/sketch_jul31c -iprefix /home/amma/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.1-dc859c1e67/esp32/include/ @/home/amma/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.1-dc859c1e67/esp32/flags/includes -I/home/amma/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.1-dc859c1e67/esp32/qio_qspi/include -I/home/amma/.arduino15/packages/esp32/hardware/esp32/3.0.3/cores/esp32 -I/home/amma/.arduino15/packages/esp32/hardware/esp32/3.0.3/variants/esp32 @/tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972/build_opt.h @/tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972/file_opts /tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972/sketch/sketch_jul31c.ino.cpp -o /dev/null
Generating function prototypes...
/home/amma/.arduino15/packages/esp32/tools/esp-x32/2302/bin/xtensa-esp32-elf-g++ -c @/home/amma/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.1-dc859c1e67/esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="linux" -DARDUINO_FQBN="esp32:esp32:esp32wrover:UploadSpeed=921600,FlashFreq=80,FlashMode=qio,PartitionScheme=default,DebugLevel=none,EraseFlash=none" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 @/home/amma/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.1-dc859c1e67/esp32/flags/defines -I/tmp/.arduinoIDE-unsaved2024631-8558-e14wiq.ym3b/sketch_jul31c -iprefix /home/amma/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.1-dc859c1e67/esp32/include/ @/home/amma/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.1-dc859c1e67/esp32/flags/includes -I/home/amma/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.1-dc859c1e67/esp32/qio_qspi/include -I/home/amma/.arduino15/packages/esp32/hardware/esp32/3.0.3/cores/esp32 -I/home/amma/.arduino15/packages/esp32/hardware/esp32/3.0.3/variants/esp32 @/tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972/build_opt.h @/tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972/file_opts /tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972/sketch/sketch_jul31c.ino.cpp -o /tmp/1393269462/sketch_merged.cpp
/home/amma/.arduino15/packages/builtin/tools/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /tmp/1393269462/sketch_merged.cpp
Compiling sketch...
/home/amma/.arduino15/packages/esp32/tools/esp-x32/2302/bin/xtensa-esp32-elf-g++ -MMD -c @/home/amma/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.1-dc859c1e67/esp32/flags/cpp_flags -w -Os -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS="linux"" "-DARDUINO_FQBN="esp32:esp32:esp32wrover:UploadSpeed=921600,FlashFreq=80,FlashMode=qio,PartitionScheme=default,DebugLevel=none,EraseFlash=none"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 @/home/amma/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.1-dc859c1e67/esp32/flags/defines -I/tmp/.arduinoIDE-unsaved2024631-8558-e14wiq.ym3b/sketch_jul31c -iprefix /home/amma/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.1-dc859c1e67/esp32/include/ @/home/amma/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.1-dc859c1e67/esp32/flags/includes -I/home/amma/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.1-dc859c1e67/esp32/qio_qspi/include -I/home/amma/.arduino15/packages/esp32/hardware/esp32/3.0.3/cores/esp32 -I/home/amma/.arduino15/packages/esp32/hardware/esp32/3.0.3/variants/esp32 @/tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972/build_opt.h @/tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972/file_opts /tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972/sketch/sketch_jul31c.ino.cpp -o /tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972/sketch/sketch_jul31c.ino.cpp.o
Compiling libraries...
Compiling core...
/usr/bin/env bash -c "echo -DARDUINO_CORE_BUILD > '/tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972/file_opts'"
Using precompiled core: /tmp/arduino/cores/c307e8d561208d55230ab42383820771/core.a
Linking everything together...
/home/amma/.arduino15/packages/esp32/tools/esp-x32/2302/bin/xtensa-esp32-elf-g++ @/home/amma/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.1-dc859c1e67/esp32/flags/ld_flags @/home/amma/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.1-dc859c1e67/esp32/flags/ld_scripts -Wl,--Map=/tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972/sketch_jul31c.ino.map -L/home/amma/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.1-dc859c1e67/esp32/lib -L/home/amma/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.1-dc859c1e67/esp32/ld -L/home/amma/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.1-dc859c1e67/esp32/qio_qspi -Wl,--wrap=esp_panic_handler -Wl,--start-group /tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972/sketch/sketch_jul31c.ino.cpp.o /tmp/arduino/cores/c307e8d561208d55230ab42383820771/core.a @/home/amma/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.1-dc859c1e67/esp32/flags/ld_libs -Wl,--end-group -Wl,-EL -o /tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972/sketch_jul31c.ino.elf
python3 /home/amma/.arduino15/packages/esp32/tools/esptool_py/4.6/esptool.py --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB --elf-sha256-offset 0xb0 -o /tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972/sketch_jul31c.ino.bin /tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972/sketch_jul31c.ino.elf
esptool.py v4.6
Merged 2 ELF sections
python3 /home/amma/.arduino15/packages/esp32/hardware/esp32/3.0.3/tools/gen_esp32part.py -q /tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972/partitions.csv /tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972/sketch_jul31c.ino.partitions.bin
/usr/bin/env bash -c "[ ! -d "/tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972"/libraries/Insights ] || python3 "/home/amma/.arduino15/packages/esp32/hardware/esp32/3.0.3"/tools/gen_insights_package.py /tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972 sketch_jul31c.ino "/tmp/.arduinoIDE-unsaved2024631-8558-e14wiq.ym3b/sketch_jul31c""
/usr/bin/env bash -c "[ ! -d "/tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972"/libraries/ESP_SR ] || [ ! -f "/home/amma/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.1-dc859c1e67/esp32"/esp_sr/srmodels.bin ] || cp -f "/home/amma/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.1-dc859c1e67/esp32"/esp_sr/srmodels.bin "/tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972"/srmodels.bin"
python3 /home/amma/.arduino15/packages/esp32/tools/esptool_py/4.6/esptool.py --chip esp32 merge_bin -o /tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972/sketch_jul31c.ino.merged.bin --fill-flash-size 4MB --flash_mode keep --flash_freq keep --flash_size keep 0x1000 /tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972/sketch_jul31c.ino.bootloader.bin 0x8000 /tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972/sketch_jul31c.ino.partitions.bin 0xe000 /home/amma/.arduino15/packages/esp32/hardware/esp32/3.0.3/tools/partitions/boot_app0.bin 0x10000 /tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972/sketch_jul31c.ino.bin
esptool.py v4.6
Wrote 0x400000 bytes to file /tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972/sketch_jul31c.ino.merged.bin, ready to flash to offset 0x0
/home/amma/.arduino15/packages/esp32/tools/esp-x32/2302/bin/xtensa-esp32-elf-size -A /tmp/arduino/sketches/7DBB62AFA9E8EA2A74E03F074BF8B972/sketch_jul31c.ino.elf
Sketch uses 290577 bytes (22%) of program storage space. Maximum is 1310720 bytes.
Global variables use 20264 bytes (6%) of dynamic memory, leaving 307416 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.6
code tried to upload
Serial.begin(115200); // Initialize serial communication at 115200 baud
Serial.println("Hello, Arduino!"); // Print message to the Arduino
// Check if data is available to read from the Arduino
if (Serial.available()) {
String received = Serial.readStringUntil('\n'); // Read incoming data
Serial.print("Received from Arduino: ");
Serial.println(received); // Print received data to the serial monitor
Unfortunately I don't have any other ideas about what might be causing this problem. Hopefully one of the other forum helpers will be able to provide a solution.
Okay Thank You!!!
