my serial monitor kept showing this even after the code i run have been verified, and the wifi hotspot username and password is the same as in the code. Thank you
the hardware used is esp32 wroom 32D
the intention of this mqtt is to send data that have been coded in the esp that is connected with hcsr04 ultrasonic sensor then transfering it to the mqtt as a broker before being displayed using node red as the iot dashboard
