Failed with state -connecting to mqtt
I want to connect esp32 that detect the ibeacon using bluetooth to the server. Wifi is connected but arduino shows "failed with state -2connecting to mqtt...". I that any solution to solve this?
for credentials. h file
#ifndef CREDENTIALS_H_
#define CREDENTIALS_H_
/* WiFi username and password /
const char
ssid = "GUE SEY HAU-TIME2.4Ghz";
const char* password = "71957401";
/* MQTT credentials and connection /
const char
mqttServer = "192.168.0.110";
const int mqttPort = 3000;
const char* mqttUser = "station";
const char* mqttPassword = "bledemo";
#endif
for esp32 station:
#include
#include
#include <WiFi.h>
#define MQTT_MAX_PACKET_SIZE 1844
#include <PubSubClient.h>
// Bluetooth LE
#include <BLEDevice.h>
#include <BLEUtils.h>
#include <BLEScan.h>
#include <BLEAdvertisedDevice.h>
/* Add WiFi and MQTT credentials to credentials.h file */
#include "credentials.h"
#ifdef __cplusplus
extern "C" {
#endif
uint8_t temprature_sens_read();
#ifdef __cplusplus
#endif
//Scan time must be longer than beacon interval
int beaconScanTime = 4;
WiFiClient espClient;
PubSubClient client(espClient);
// We collect each device MAC and RSSI
typedef struct {
char address[17]; // F4:79:FA:49:51:4B
int rssi;
} BeaconData;
uint8_t bufferIndex = 0; // Found devices counter
BeaconData buffer[50]; // Buffer to store found device data
uint8_t message_char_buffer[MQTT_MAX_PACKET_SIZE];
class MyAdvertisedDeviceCallbacks : public BLEAdvertisedDeviceCallbacks {
public:
void onResult(BLEAdvertisedDevice advertisedDevice) {
extern uint8_t bufferIndex;
extern BeaconData buffer[];
if(bufferIndex >= 50) {
return;
// RSSI
if(advertisedDevice.haveRSSI()) {
buffer[bufferIndex].rssi = advertisedDevice.getRSSI();
} else { buffer[bufferIndex].rssi = 0; }
// MAC is mandatory for BT to work
strcpy (buffer[bufferIndex].address, advertisedDevice.getAddress().toString().c_str());
bufferIndex++;
// Print everything via serial port for debugging
Serial.printf("MAC: %s \n", advertisedDevice.getAddress().toString().c_str());
Serial.printf("name: %s \n", advertisedDevice.getName().c_str());
Serial.printf("RSSI: %d \n", advertisedDevice.getRSSI());
BLEDevice::init(""); // Can only be called once
void connectWiFi() {
WiFi.begin(ssid, password);
Serial.println("Connecting to WiFi..");
Serial.println("Connected to the WiFi network");
void connectMQTT() {
client.setServer(mqttServer, mqttPort);
Serial.println("Connecting to MQTT...");
if (client.connect("ESP32Client", mqttUser, mqttPassword)) {
Serial.println("connected");
Serial.print("failed with state ");
Serial.print(client.state());
delay(2000);
void ScanBeacons() {
BLEScan* pBLEScan = BLEDevice::getScan(); //create new scan
MyAdvertisedDeviceCallbacks cb;
pBLEScan->setAdvertisedDeviceCallbacks(&cb);
pBLEScan->setActiveScan(true); //active scan uses more power, but get results faster
BLEScanResults foundDevices = pBLEScan->start(beaconScanTime);
Serial.print("Devices found: ");
//Serial.print(cb.getConcatedMessage());
for (uint8_t i = 0; i < bufferIndex; i++) {
Serial.print(buffer[i].address);
Serial.print(" : ");
Serial.println(buffer[i].rssi);
// Stop BLE
pBLEScan->stop();
Serial.println("Scan done!");
boolean result;
// Scan Beacons
ScanBeacons();
// Reconnect WiFi if not connected
connectWiFi();
// Reconnect to MQTT if not connected
while (!client.connected()) {
connectMQTT();
client.loop();
// SenML begins
String payloadString = "{"e":[";
for(uint8_t i = 0; i < bufferIndex; i++) {
payloadString += "{"m":"";
payloadString += String(buffer[i].address);
payloadString += "","r":"";
payloadString += String(buffer[i].rssi);
payloadString += ""}";
if(i < bufferIndex-1) {
payloadString += ',';
// SenML ends. Add this stations MAC
payloadString += "],"st":"";
payloadString += String(WiFi.macAddress());
// Add board temperature in fahrenheit
payloadString += "","t":"";
payloadString += String(temprature_sens_read());
// Print and publish payload
Serial.print("MAX len: ");
Serial.println(MQTT_MAX_PACKET_SIZE);
Serial.print("Payload length: ");
Serial.println(payloadString.length());
Serial.println(payloadString);
payloadString.getBytes(message_char_buffer, payloadString.length()+1);
result = client.publish("/beacons/office", message_char_buffer, payloadString.length(), false);
Serial.print("PUB Result: ");
Serial.println(result);
//Start over the scan loop
bufferIndex = 0;
// Add delay to slow down publishing frequency if needed.
//delay(5000);
@seywen916
Installation and Troubleshooting is for Problems with the Arduino itself NOT your project. It says so in the description of the section. Therefore I have moved your post here.
You may want to read this before you proceed:-
how to get the best out of this forum
-2 means the connection failed. Most probably because you use the wrong port. MQTT usually runs on port 1883, not 3000. I don't know what the picture actually shows, I guess you installed NodeRed on port 3000 but hat runs a web server and not an MQTT broker! The picture even says that port 3000 is for a web browser.
