I thought I'd try to manually bit-bang parallel mode on an ST7920 controller with my Arduino Uno because I'm planning to try and set it up with a Z80 microcomputer. Alas, after two evenings I am no closer to working out why my quite simple code doesn't work! Here's the code:
#define RS 0
#define EN 1
#define D0 2
Serial.println("Restarting!");
// Prepare pins for output
pinMode(RS, OUTPUT);
pinMode(EN, OUTPUT);
for (int pin = D0; pin < D0 + 8; pin +=1) {
pinMode(pin, OUTPUT);
digitalWrite(EN, LOW);
lcd_init();
// Send some characters
lcd_send(0, 0x93);
delayMicroseconds(80);
lcd_send(1, 'A');
lcd_send(1, ' ');
void lcd_init() {
lcd_send(0, 0b00110000); // Basic function set
delayMicroseconds(200);
lcd_send(0, 0b00001111); // Set display (display on, cursor on, blink on)
lcd_send(0, 0b00000001); // Clear display (wait >1.6 ms after)
delay(100);
lcd_send(0, 0b00000110); // Set entry mode
Serial.println("Done init");
void lcd_send(int lcd_mode, byte data) {
digitalWrite(RS, lcd_mode);
digitalWrite(pin, data & 1);
data = data >> 1;
digitalWrite(EN, HIGH);
delayMicroseconds(100);
Nothing appears on the LCD when I run this code, not even the cursor.
I feel like I must be missing something simple, because the display works perfectly with identical wiring, on the same board, with the following U8g2 code:
#include <U8g2lib.h>
U8G2_ST7920_128X64_1_8080 u8g2(
/* Rotation */ U8G2_R2,
/*D0 - D7*/ 2, 3, 4, 5, 6, 7, 8, 9,
/*EN*/ 1,
/*CS*/ U8X8_PIN_NONE,
/*RS*/ 0);
u8g2.begin();
u8g2.firstPage();
do {
u8g2.setFont(u8g2_font_profont11_tf);
u8g2.drawStr(0,20,"Hello World!");
} while ( u8g2.nextPage() );
I'd appreciate any help - I feel like I've scoured every line of my code, and the datasheet, countless times.
