Failing to build a simple webclient
I’ve been trying for days now to do a simply web read (I only need to do a simple GET request, which returns ‘true’ or ‘false’ on the website.
The big issue: I’m using an arduino nano (which has VERY limited memory) with an ENC28J60 shield.
I’ve tried many many different scripts and none work. I was succesfull to let the nano act as a server and access it remotely, so it does work. I just can’t get it to work the other way round.
My latest attempt appears to be closest to working…except that it returns nothing. Here’s the script
#include <Nanoshield_Ethernet.h>
static byte mac[] = { 0x74,0x69,0x69,0x2D,0x30,0x31 };
char server[] = "www.google.com";    // name address for Google (using DNS)
EthernetClient client;
 Serial.begin(57600);
 Ethernet.begin(mac);
 Serial.println("connecting...");
 if (client.connect(server, 80)) {
   Serial.println("connected");
   // Make a HTTP request:
   client.println("GET /search?q=arduino HTTP/1.1");
   client.println("Host: www.google.com");
   client.println("Connection: close");
   client.println();
 else {
   Serial.println("connection failed");
 if (client.available()) {
   char c = client.read();
   Serial.print(c);
 if (!client.connected()) {
   Serial.println("disconnecting.");
   client.stop();
   while (true);
The resulting serial output:
connecting...
connected
disconnecting.
any clues on how to proceed?
Are you able to access the web server using your browser ?
use EtherCard library. it has a webclient example
thank you for the replies.
yes I can access the webserver, actually the one in the sketch is google, its just to test.
And 'a few days' means that I've obviously also tested ehterCard with that one I was able to set the nano up as a server but that webclient sketch also failed. The only output to serial I got from that is: [webclient] which basically means that it didnt'even get passed the void setup()
