Failure Serial Communication between C# Winform and Uno R4 wifi
Winform that I made can't receive datas from Arduino Uno R4 wifi. It works well when I used Arduino Nano.
This is arduino sketch :
#include<stdio.h>
char inp[10];
  if (Serial.available()>0) {
    int i = 0;
    //inp = Serial.read();
    for (i=0; i<10; i++) {
      inp[i] = Serial.read();
      delayMicroseconds(80);
    if (inp[0] == 'S') {
      Serial.println("Hello");
and below is for winform :
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
using System.IO.Ports;
namespace _230801_test2
    public partial class Form1 : Form
        public Form1()
            InitializeComponent();
            serialPort1.Open();
        private void button2_Click(object sender, EventArgs e)
            serialPort1.Write("S");
            Debug.WriteLine("S");
            string data = serialPort1.ReadLine();
            Debug.WriteLine(data);
            richTextBox1.Text += data;
Welcome to the forum
Why did you start a topic in the Uncategorised category of the forum when its description is
:warning: DO NOT CREATE TOPICS IN THIS CATEGORY :warning:
Your topic has been moved to the Uno R4 category
i have the exact same problem, did you manage to find a sollution?,
it works with an arduino r3??
