I am getting an error on uploading programs to my nano. The error statement is:
avrdude: can't open config file "C:\Users\wicke\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf": No such file or directory.
Can anyone give a hint on what the problem is and how I can fix it? I am using the newest Arduino IDE 2.0.2.
Thanks.
Does the file exist? If not, your install seems to be corrupted. If yes, your OS or virus scanner night block access.
You can use the attached; note that I can't be trusted (
) and that you're advised to run a virus scanner.
avrdude.conf.zip (30.9 KB)
Thanks for the suggestion. The config file is not in the folder, but the avrdude. exe and a .dll file is in a folder labeled /bin/. Thank for the config file. I added your config file to a new folder labeled as /etc/ with the .config and .exe and .dll. It now works. Thanks much.
I spoke too soon. I don't get the config file error anymore, but I get the following error message:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xfa
I think I saw something on this in some posts in the forum, so I will check them out. In the meantime, if you have any suggestions, please respond.
best regards,
chuck
I am using the old bootloader and I needed to check on the avr Isp in the programmer option in the tools menu. It now appears to be working. Thanks again for your help.
If you upload via USB (which is the usual way) instead of using a programmer, the programmer options don't matter as they are not used.
