Fairly new to Arduino - need help programming a code to control speed of a motor
I'm doing a project for my engineering class in my university and I'm trying to create a car that can change the speed wirelessly via bluetooth. As of right now I have arduino uno, 5V DC motor, L239D Stepper motor driver IC, and HC-05 bluetooth module. I'm confident what I'm trying to achieve is possible because so far I have been able to control the motor to move left and right wirelessly. I just need to learn to code so that it can change speeds.
Simply put, I need to know how to code so that I can open up "Serial Monitor" and input a "speed value" for the motor.
I followed this website: http://www.instructables.com/id/Arduino-Control-DC-Motor-via-Bluetooth/
The current coding looks like this:
int motorPin1 = 3; // pin 2 on L293D IC
int motorPin2 = 4; // pin 7 on L293D IC
int enablePin = 5; // pin 1 on L293D IC
int state;
int flag=0; //makes sure that the serial only prints once the state
// sets the pins as outputs:
pinMode(motorPin1, OUTPUT);
pinMode(motorPin2, OUTPUT);
pinMode(enablePin, OUTPUT);
// sets enablePin high so that motor can turn on:
digitalWrite(enablePin, HIGH);
// initialize serial communication at 9600 bits per second:
//if some date is sent, reads it and saves in state
if(Serial.available() > 0){
state = Serial.read();
flag=0;
// if the state is '0' the DC motor will turn off
if (state == '0') {
digitalWrite(motorPin1, LOW); // set pin 2 on L293D low
digitalWrite(motorPin2, LOW); // set pin 7 on L293D low
if(flag == 0){
Serial.println("Motor: off");
flag=1;
// if the state is '1' the motor will turn right
else if (state == '1') {
digitalWrite(motorPin2, HIGH); // set pin 7 on L293D high
if(flag == 0){
Serial.println("Motor: right");
flag=1;
// if the state is '2' the motor will turn left
else if (state == '2') {
digitalWrite(motorPin1, HIGH); // set pin 2 on L293D high
if(flag == 0){
Serial.println("Motor: left");
flag=1;
First thing to learn is to use     [code] and [/code]  to put your code in its own window.
Weedpharma
You could easily get 26 speeds by just using letters.
52 speeds if you make it case-sensitive.
Look up the switch-case construct in the Reference page to avoid loads of if-else statements.
From the code you appear to be driving two seperate DC motors neither of which are stepper motors.
If you want to control speed you could drive them with a PWM signal, and use analogWrite() see here.
