Hi all,
Just thought I should mention this.
I purchased 10 x DS18B20 temperature sensors from an Ebay supplier at the end of March 2018.
They came quite fast and in individual packages. Quite impressed as I had them in under 2 weeks.
Today, I came to use one of them, after connecting it to an Arduino Uno and running the oneWireSearch sketch, I could not get an address for it. I tried a few times, before I realised that this chip was getting very hot.
I immediately checked my wiring and confirmed that everything was ok, so tried again. This time I noticed that the 'ON' and 'L' LED's on the Arduino dimmed quite significantly.
I feared the worst that I had damaged the Arduino, but I inserted an old DS18B20 that I had some while and it worked fine.
I checked the physical difference between them and noticed number which has a '1541C4' marking on it, my older one having a '1523C4'.
A search on the internet brought up very little but did come up with someone on the forum having the exact same problem over a year ago and the sensor had the same '1541C4' marking on his.
Putting into a component checker revealed that it is a standard NPN transistor, worse still, all 10 were tested the same.
I have emailed the seller for a full refund before opening a dispute with Ebay and hope to get my money back.
So, has anyone else had a similar problem?
I have included here some images of the sensor, its packaging, the test and a real one.
Thanks
Martin
