Falha na Conexão do Arduino uno e o RFID
Estou tendo problemas na hora de executar meu código no monitor serial para que possar ler minhas tags Aparece o seguinte problema
“WARNING: Communication failure, is the MFRC522 properly connected?”
Essas são as minhas conexões:
|VCC (Módulo)|Pino 3.3V (Arduino)|
|GND (Módulo)|Pino GND (Arduino)|
|Pino RST (Módulo)|Pino 5 (Arduino)|
|Pino IRQ (Módulo)|-|
|Pino SDA (Módulo)|Pino 10 (Arduino)|
|Pino SCK (Módulo)|PINO 13 (Arduino)|
|Pino MOSI (Módulo)|PINO 11 (Arduino)|
|Pino MISO (Módulo)|PINO 12 (Arduino)|
Eu não sei ao certo qual o erro, pelo fato de eu ter feito todas as conexões exatamente como estão ai e utilizado o código de exemplo na biblioteca MFRC522 então sei que o erro não está no código caso queiram ver aqui está o meu código, fiz algumas alterações.
 * Example sketch/program showing how to read data from a PICC to serial.
 * This is a MFRC522 library example; for further details and other examples see: https://github.com/miguelbalboa/rfid
 * Example sketch/program showing how to read data from a PICC (that is: a RFID Tag or Card) using a MFRC522 based RFID
 * Reader on the Arduino SPI interface.
 * When the Arduino and the MFRC522 module are connected (see the pin layout below), load this sketch into Arduino IDE
 * then verify/compile and upload it. To see the output: use Tools, Serial Monitor of the IDE (hit Ctrl+Shft+M). When
 * you present a PICC (that is: a RFID Tag or Card) at reading distance of the MFRC522 Reader/PCD, the serial output
 * will show the ID/UID, type and any data blocks it can read. Note: you may see "Timeout in communication" messages
 * when removing the PICC from reading distance too early.
 * If your reader supports it, this sketch/program will read all the PICCs presented (that is: multiple tag reading).
 * So if you stack two or more PICCs on top of each other and present them to the reader, it will first output all
 * details of the first and then the next PICC. Note that this may take some time as all data blocks are dumped, so
 * keep the PICCs at reading distance until complete.
 * @license Released into the public domain.
 * Typical pin layout used:
 *             MFRC522      Arduino       Arduino   Arduino    Arduino          Arduino
 *             Reader/PCD   Uno/101       Mega      Nano v3    Leonardo/Micro   Pro Micro
 * Signal      Pin          Pin           Pin       Pin        Pin              Pin
 * RST/Reset   RST          9             5         D9         RESET/ICSP-5     RST
 * SPI SS      SDA(SS)      10            53        D10        10               10
 * SPI MOSI    MOSI         11 / ICSP-4   51        D11        ICSP-4           16
 * SPI MISO    MISO         12 / ICSP-1   50        D12        ICSP-1           14
 * SPI SCK     SCK          13 / ICSP-3   52        D13        ICSP-3           15
 * More pin layouts for other boards can be found here: https://github.com/miguelbalboa/rfid#pin-layout
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN  5         // Configurable, see typical pin layout above
#define SS_PIN  10        // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN);  // Create MFRC522 instance
	Serial.begin(9600);		// Initialize serial communications with the PC
	while (!Serial);		// Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
	SPI.begin();			// Init SPI bus
	mfrc522.PCD_Init();		// Init MFRC522
	delay(4);				// Optional delay. Some board do need more time after init to be ready, see Readme
	mfrc522.PCD_DumpVersionToSerial();	// Show details of PCD - MFRC522 Card Reader details
	Serial.println(F("Scan PICC to see UID, SAK, type, and data blocks..."));
	// Reset the loop if no new card present on the sensor/reader. This saves the entire process when idle.
	if ( ! mfrc522.PICC_IsNewCardPresent()) {
		return;
	// Select one of the cards
	if ( ! mfrc522.PICC_ReadCardSerial()) {
		return;
	// Dump debug info about the card; PICC_HaltA() is automatically called
	mfrc522.PICC_DumpToSerial(&(mfrc522.uid));
Se alguém puder me ajudar ficarei muito GRATO
Testei aqui no meu UNO com seu programa e seu codigo e funcionou corretamente.
Verifique se não tem nenhum fio quebrado ou com mau contato.
Muito obrigado! Tirou a minha dúvida, então realmente são meus componentes que podem estar com defeito. Irei pegar novos componentes para testar.
