Falling edge counting on a timer
Hello,
I'm trying to use Arduino Due to count number of falling edges (and eventually rising as well) every 26 milliseconds from a rising edge. I have a function generator on pin 22 that generates a pulse of width of 2ms every 20ms.
I'm having some problems with interrupts and timers as I'm new to them. Essentially, I use a hardware interrupt on pin 22 to track every falling edge and a timer interrupt that resets the number of falling edges every 26 millisec; however, I need to synchronize my timer interrupt with my rising edges. I thought I could make an interrupt that would trigger on a rising edge and start a counter, but that doesn't seem to work. I appreciate any advice or help.
Also I'm using DueTimer library to help me with timer interrupts.
Thank you :slight_smile:
#include <DueTimer.h>
volatile int i=0;
volatile int countUp=0;
volatile int countDown=0;
  Serial.begin(9800);
  pinMode(22, INPUT);
  Timer3.attachInterrupt(counterReset).start(26000);
  attachInterrupt(22, interrupt3, RISING);
  detachInterrupt(22);
  attachInterrupt(22, interrupt1, FALLING);
  //attachInterrupt(22, interrupt2, RISING);
void interrupt1()
  countDown++;
void interrupt2()
  countUp++;
void interrupt3()
  Timer3.start();
  i++;
void counterReset()
  countDown=0;
  Serial.print("Falling: ");
  Serial.print(countDown);
  Serial.print(" Rising: ");
  Serial.print(countUp);
  Serial.print(" ms: ");
  Serial.print(millis());
  Serial.print("    ");
  Serial.print(i);
  delay(20);
All you need is a Timer Capture (TC_CMR in capture mode).
See an example in this thread, reply #3:
https://forum.arduino.cc/index.php?topic=459707.0
