False Digital Reads
Hey All,
Could anyone tell me why i am getting false digital reads?
Code sets maleConnectorPins to HIGH and then reads if the femaleConnectorPins are connected and read HIGH.
Currently i am just getting "47" show on my LCD.
uint8_t maleConnectorPins[] = {22, 24, 26, 28, 30, 32, 34 ,36 ,38,  40, 42, 44, 46};// Check what cable is conencted Pins
uint8_t femaleConnectorPins[] = {23, 25, 27, 29, 31, 33, 35, 37, 39, 41, 43, 45, 47};// Check what cable is conencted Pins
        for (uint8_t m = 0; m < sizeof(maleConnectorPins); m++) // Setup output pins
          pinMode(maleConnectorPins[m],OUTPUT);
          digitalWrite(maleConnectorPins[m],LOW);
        for (uint8_t f = 0; f < sizeof(femaleConnectorPins); f++) // Setup input pins
          pinMode(femaleConnectorPins[f],INPUT); // Turn off internap pullup resistor
        for (uint8_t i = 0; i < sizeof(femaleConnectorPins); i++) // Setup Female input pins
          digitalWrite(maleConnectorPins[i],HIGH);
          if (digitalRead(femaleConnectorPins[i]) == HIGH)
              //int var;
              //var = f + 1;
              lcd.setCursor(0,0);
              lcd.print(femaleConnectorPins[i]);
          else if (digitalRead(femaleConnectorPins[i]) == LOW)
Because lcd.print(femaleConnectorPins[i])
Is input pin 47 actually HIGH? If so that is what I would expect to see. The code will run too fast to see the status of any pin except the last pin that reads HIGH.
If i do
lcd.print(i)
It just says "12" am i doing this bit wrong?
The code is running so fast you can't see anything but the last because you are displaying at the same position:
              lcd.setCursor(0,0);
You could put a delay just to convince yourself.
Please describe what you actually want the output to be.
david_2018:
No there is nothing plugged in other than a jumper from 22 to 23 at the moment
eddcaton:
The inputs are floating. If you want a low reading on an unconnected input pin, you will need a pulldown resistor to ground.
david_2018:
I would like the output to be 23. As i currently have 22 and 23 connected together.
david_2018:
Thanks,
I will give that a go
The resistors worked with this.
Thanks for all the help.
I have one further question if anyone knows what i am doing wrong or need to change i would be very grateful.
With the same code in my first post, I am trying to set an array of pins high and then see where pin goes high to see where the jumper cable is connected.
I have the input working and showing on an LCD so i can see where the pin is going high. But i would also like to know what output pin was high.
