false ip address on dfrobot ethernet shield and Arduino Mega 2560
i tried this code to test my arduino mega 2560 and dfrobot ethernet shield, but the ip address that showed in serial monitor is different with the one that i typed in the code. how to solve this?
the ip that displayed in serial monitor is 16.227.107.172
#include <SPI.h>
#include <Ethernet.h>
#define SS  53  //Gadgeteer PIN 6
#define nRST  46  //Gadgeteer PIN 4
#define nPWDN 45  //Gadgeteer PIN 5
#define nINT 2  //Gadgeteer PIN 3
//define the interface: Dreamer MEGA X2 PORT
#define SS    10  //Gadgeteer PIN 6
#define nRST  8  //Gadgeteer PIN 4
#define nPWDN 9  //Gadgeteer PIN 5
#define nINT 3  //Gadgeteer PIN 3
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,0,117);
EthernetServer server(80);
  pinMode(SS,OUTPUT);  //Define the interfave :Dreamer MEGA X2 PORT  Gadgeteer PIN 6 use SS
  pinMode(nRST,OUTPUT);
  pinMode(nPWDN,OUTPUT);
  pinMode(nINT,INPUT);
  digitalWrite(nPWDN,LOW);  //enable power
  digitalWrite(nRST,LOW);  //Reset W5200
  delay(10);
  digitalWrite(nRST,HIGH);
delay(200);      // wait W5200 work
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Ethernet.begin(mac, ip);
  server.begin();
  Serial.print("server is at ");
  Serial.println(Ethernet.localIP());
  // listen for incoming clients
  if (client) {
    Serial.println("new client");
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          client.println("Content-Type: text/html");
          client.println("Connnection: close");
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println("<html>");
                    // add a meta refresh tag, so the browser pulls again every 5 seconds:
          client.println("<meta http-equiv=\"refresh\" content=\"5\">");
          // output the value of each analog input pin
          for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
            int sensorReading = analogRead(analogChannel);
            client.print("analog input ");
            client.print(analogChannel);
            client.print(" is ");
            client.print(sensorReading);
            client.println("
          client.println("</html>");
        if (c == '\n') {
          // you're starting a new line
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    Serial.println("client disonnected");
If you are using a DFRobot shield, they normally use a W5200 controller. Are you using a library for that IC? The ethernet library included with the IDE is compatible with the W5100 only.
