False lectures IR sensor
Good morning,
I have a problem with my counter.
I´m using this IR sensor:
http://www.electronicaestudio.com/docs/SHT-015d.pdf
I placed a R=10K pull-up.
The problem I have: Sometimes I have false lectures and I want to eliminate it. I read about the bouncing and I tried to add a delay(500) to reduce it. Now its better than before but I still have the same problem.
Can you help me?
thanks in advance
This is my code:
  lectura = digitalRead(pinsensor);
  if (lectura != 1)
    contador=contador+1;
    printN(contador);
    delay(500);                   //I reduced a little bit the falses lectures
    while(digitalRead(pinsensor) != 1)
You should look at the state change detection example. Count only when then switch BECOMES pressed. No delay() and no blocking while needed.
Thank you PaulS
