I have the following problem.
I had buy this product , and i want to open it when the temperature at house is more than 30 degrees. For that reason i have the lm35 temperature sensor.
The problem is that i read that this fan need 5v DC and 0.180 A for working. I know that arduino pins can give at limit like 0.040 A.
Can someone tell me if that is the reason that the fan dont work?
P.S
When i connect the fan at 5V of arduino pin, and GND , it starts working ..
A logic signal is a signal, not a source of power to do work. Whenever you need to power something
you need some sort of switch which is controlled by a logic level signal and does the heavy lifting,
beit a transistor/MOSFET/relay/controller unit..
Start with the first problem, and forget about the second one untill you have completely finished the first one.
Here is a sketch I wrote for an LM35/TMP35/TMP36 sensor.
It uses the stable internal 1.1volt reference.
You can prune the parts that you don't want (or leave them in).
Try to add "if" statements to turn the onboard LED on pin13 on/off on the temps you want for your fan.
If that works, you can think of adding a real fan.
Leo..
// TMP35 or TMP36 temp sensor connected to Analogue input A1, 3.3volt and ground
// or LM35 temp sensor connected to A1, 5volt and ground
// temp range ~2C to ~105C
// display on serial monitor and/or LCD
// for a TMP36 (-40C to ~55C), change line 45 to: tempC = total * Aref * 0.1 / numReadings - 50.0;
#include <LiquidCrystal.h>
LiquidCrystal lcd(8, 9, 4, 5, 6, 7); // your LCD pins could be different
byte ledPin = 10; // backlight pin
const byte numReadings = 32; // number of readings for smoothing (max 64)
int readings[numReadings]; // readings from the analog input
byte index = 0; // index of the current reading
unsigned int total = 0; // running total
int inputPin = A1; // the pin that the TMP35 is connected to
float Aref = 1.0759; // change this value to the actual Aref voltage of ---YOUR--- Arduino (1.0 - 1.2), or adjust to get accurate readings
float tempC; // Celcius
float tempF; // Fahrenheit
//analogWrite(ledPin, 200); // optional dimming
analogReference(INTERNAL); // use the internal ~1.1volt reference | change (INTERNAL) to (INTERNAL1V1) for a Mega
Serial.begin(115200); // ---set serial monitor to this value---
lcd.begin(16, 2); // shield with 2x16 characters
lcd.print("Thermometer"); // info text
lcd.setCursor(0, 1); // second row
lcd.print("0-100 Celcius");
for (index = 0; index < numReadings; index++) { // fill the array for faster startup
readings[index] = analogRead(inputPin);
total = total + readings[index];
index = 0; // reset
delay(2000); // info display time
total = total - readings[index]; // subtract the last reading
readings[index] = analogRead(inputPin); // one unused reading to clear ghost charge
readings[index] = analogRead(inputPin); // read from the sensor
total = total + readings[index]; // add the reading to the total
index = index + 1; // advance to the next position in the array
if (index >= numReadings) // if we're at the end of the array
index = 0; // wrap around to the beginning
// convert value to temp
tempC = total * Aref * 0.1 / numReadings; // value to celcius conversion
tempF = tempC * 1.8 + 32; // Celcius to Fahrenheit conversion
// print to LCD
if (total == 1023 * numReadings) { // if overflow
lcd.clear();
lcd.print("---TOO HOT---");
else {
lcd.clear();
lcd.print(tempC, 2); // two decimal places
lcd.setCursor(6, 0); // position 6, first row
lcd.print("Celcius");
lcd.print(tempF, 1); // one decimal place
lcd.setCursor(6, 1); // position 6, second row
lcd.print("Fahrenheit");
// print to serial monitor
Serial.print("Raw average = ");
Serial.print(total / numReadings);
Serial.println(" ----too hot----");
else {
Serial.print(" The temperature is ");
Serial.print(tempC, 2);
Serial.print(" Celcius ");
Serial.print(tempF, 1);
Serial.println(" Fahrenheit");
delay(1000); // use a non-blocking delay when combined with other code
