H,
I was recently building up some small project for FAN regulation and measuring temperature with output on a display. I have at first started to use a 3 pin FAN and used this project as a reference for controlling the rotation of the FAN: https://www.baldengineer.com/pwm-3-pin-pc-fan-arduino.html. This was working nicely and the RPM was detected right, however, the FAN made a noise while lowering the RPM and thus I have decided to go with a 4 pin FAN, Arduino nano and changing the PWM frequency using the timers. Again, I have used this as a reference: How to properly control PWM fans with Arduino - Federico Dossena. The PWM regulation works like a charm, however, the RPM detection went crazy.
It shows good RPM at full speed of the FAN, however, by lowering the PWM signal, the RPM goes like 6000 instead of app. 1000RPM. I am using an Noctua FAN but tried as well a few different ones, the same result. No idea why it is happening. The tachometer pin is through an pullup resistor and a C is used for filtering. Again, the schematic is as in the reference here: https://www.baldengineer.com/pwm-3-pin-pc-fan-arduino.html. Below the code I am using, honestly, I have no clue what to do next. Any suggestion will be appreciated. thx, Tomas
Abakus FAN controler
Written by Tomalf.
#include <Adafruit_GFX.h> // Core graphics library
#include <Adafruit_ST7789.h> // Hardware-specific library for ST7789
#include <SPI.h> // Arduino SPI library
// Include custom fonts, refer to Ardafruit
//#include <Fonts/FreeMonoBoldOblique12pt7b.h>
//if using extern constants or reading from memorz, use the below
//extern const uint16_t PROGMEM NF_P14[2600];
static const unsigned char PROGMEM thermometer_icon[] = {
0x00, 0x0F, 0x80, 0x00, 0x18, 0xC0, 0x00, 0x20, 0x20, 0x00, 0x21, 0xE0, 0x00, 0x20, 0x20, 0x00,
0x27, 0xE0, 0x00, 0x20, 0x20, 0x00, 0x21, 0xE0, 0x00, 0x20, 0x20, 0x00, 0x27, 0xE0, 0x00, 0x20,
0x20, 0x00, 0x21, 0xE0, 0x00, 0x20, 0x20, 0x00, 0x27, 0xE0, 0x00, 0x20, 0x20, 0x00, 0x21, 0xE0,
0x00, 0x20, 0x20, 0x00, 0x27, 0xE0, 0x00, 0x20, 0x20, 0x00, 0x2C, 0x20, 0x00, 0x2E, 0x20, 0x00,
0x2F, 0xA0, 0x00, 0x6F, 0xB0, 0x00, 0x8F, 0x88, 0x00, 0x8F, 0x88, 0x01, 0x1F, 0xC4, 0x01, 0x1F,
0xC4, 0x01, 0x3F, 0xE4, 0x01, 0x3E, 0x64, 0x01, 0x3E, 0x64, 0x00, 0x9F, 0xC8, 0x00, 0x9F, 0xC8,
0x00, 0x47, 0x10, 0x00, 0x30, 0x60, 0x00, 0x0F, 0x80, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
// 'fan', 70x70px generated by http://javl.github.io/image2cpp/
// Color export http://www.rinkydinkelectronics.com/t_imageconverter565.php
const unsigned char fanfan [] PROGMEM = {
0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xf0, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x7f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xf8, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0xf1, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xfe, 0x3c, 0xf9, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x7c, 0xff,
0xff, 0xff, 0xf0, 0x00, 0x3f, 0xff, 0xff, 0xfc, 0xff, 0xff, 0xff, 0x80, 0x00, 0x07, 0xff, 0xff,
0xfc, 0xff, 0xff, 0xfe, 0x00, 0x00, 0x01, 0xff, 0xff, 0xfc, 0xff, 0xff, 0xf8, 0x07, 0xfe, 0x00,
0x7f, 0xff, 0xfc, 0xff, 0xff, 0xe0, 0x0f, 0xff, 0x00, 0x1f, 0xff, 0xfc, 0xff, 0xff, 0xc0, 0x1f,
0xfe, 0x00, 0x0f, 0xff, 0xfc, 0xff, 0xff, 0x80, 0x1f, 0xfc, 0x03, 0x07, 0xff, 0xfc, 0xff, 0xff,
0x00, 0x3f, 0xf8, 0x1f, 0xc3, 0xff, 0xfc, 0xff, 0xfe, 0x1c, 0x3f, 0xf0, 0x3f, 0xe1, 0xff, 0xfc,
0xff, 0xfc, 0x3c, 0x3f, 0xe0, 0xff, 0xf0, 0xff, 0xfc, 0xff, 0xf8, 0x7c, 0x3f, 0xe0, 0xff, 0xf8,
0x7f, 0xfc, 0xff, 0xf0, 0xfc, 0x3f, 0xc1, 0xff, 0xfc, 0x3f, 0xfc, 0xff, 0xe1, 0xfc, 0x3f, 0xc3,
0xff, 0xfe, 0x1f, 0xfc, 0xff, 0xe3, 0xfc, 0x3f, 0xc7, 0xff, 0xff, 0x1f, 0xfc, 0xff, 0xc3, 0xfc,
0x3f, 0xc7, 0xff, 0xfe, 0x0f, 0xfc, 0xff, 0xc7, 0xfc, 0x3f, 0x8f, 0xfe, 0x00, 0x0f, 0xfc, 0xff,
0x87, 0xfe, 0x1f, 0x8f, 0xf8, 0x00, 0x07, 0xfc, 0xff, 0x83, 0xfe, 0x1f, 0x8f, 0xf0, 0x00, 0x07,
0xfc, 0xff, 0x03, 0xff, 0x1f, 0x9f, 0xc0, 0x00, 0x03, 0xfc, 0xff, 0x03, 0xff, 0x8f, 0xbf, 0x81,
0xff, 0x03, 0xfc, 0xff, 0x01, 0xff, 0x8f, 0xff, 0x0f, 0xff, 0xc3, 0xfc, 0xfe, 0x00, 0xff, 0xc7,
0x03, 0x3f, 0xff, 0xe1, 0xfc, 0xfe, 0x00, 0xff, 0xe6, 0x01, 0xff, 0xff, 0xf1, 0xfc, 0xfe, 0x00,
0x7f, 0xfc, 0x00, 0xff, 0xff, 0xf1, 0xfc, 0xfe, 0x38, 0x1f, 0xf8, 0x00, 0x7f, 0xff, 0xf1, 0xfc,
0xfe, 0x3c, 0x0f, 0xf0, 0x00, 0x3f, 0xff, 0xf1, 0xfc, 0xfe, 0x3e, 0x03, 0xf0, 0x00, 0x20, 0xff,
0xf1, 0xfc, 0xfe, 0x3f, 0x00, 0x70, 0x00, 0x30, 0x0f, 0xf1, 0xfc, 0xfe, 0x3f, 0xc0, 0x30, 0x00,
0x38, 0x03, 0xf1, 0xfc, 0xfe, 0x3f, 0xfc, 0x10, 0x00, 0x3f, 0x01, 0xf1, 0xfc, 0xfe, 0x3f, 0xff,
0xf0, 0x00, 0x3f, 0xc0, 0xf1, 0xfc, 0xfe, 0x3f, 0xff, 0xf8, 0x00, 0x7f, 0xe0, 0x71, 0xfc, 0xfe,
0x3f, 0xff, 0xfc, 0x00, 0xff, 0xf8, 0x01, 0xfc, 0xfe, 0x3f, 0xff, 0xfe, 0x01, 0x9f, 0xfc, 0x01,
0xfc, 0xfe, 0x1f, 0xff, 0xf3, 0x03, 0x8f, 0xfc, 0x01, 0xfc, 0xff, 0x0f, 0xff, 0xc3, 0xff, 0xc7,
0xfe, 0x03, 0xfc, 0xff, 0x03, 0xfe, 0x07, 0xf7, 0xc3, 0xff, 0x03, 0xfc, 0xff, 0x00, 0x00, 0x0f,
0xe7, 0xe3, 0xff, 0x03, 0xfc, 0xff, 0x80, 0x00, 0x1f, 0xc7, 0xe1, 0xff, 0x07, 0xfc, 0xff, 0x80,
0x00, 0x7f, 0xc7, 0xe1, 0xff, 0x87, 0xfc, 0xff, 0xc0, 0x01, 0xff, 0xc7, 0xf0, 0xff, 0x8f, 0xfc,
0xff, 0xc1, 0xff, 0xff, 0x8f, 0xf0, 0xff, 0x8f, 0xfc, 0xff, 0xe1, 0xff, 0xff, 0x8f, 0xf0, 0xff,
0x1f, 0xfc, 0xff, 0xe1, 0xff, 0xff, 0x0f, 0xf0, 0xfe, 0x1f, 0xfc, 0xff, 0xf0, 0xff, 0xfe, 0x0f,
0xf0, 0xfc, 0x3f, 0xfc, 0xff, 0xf8, 0x7f, 0xfe, 0x1f, 0xf0, 0xf8, 0x7f, 0xfc, 0xff, 0xfc, 0x3f,
0xfc, 0x1f, 0xf0, 0xf0, 0xff, 0xfc, 0xff, 0xfc, 0x1f, 0xf0, 0x3f, 0xf0, 0xe0, 0xff, 0xfc, 0xff,
0xfe, 0x0f, 0xe0, 0x7f, 0xf0, 0x01, 0xff, 0xfc, 0xff, 0xff, 0x83, 0x00, 0xff, 0xe0, 0x07, 0xff,
0xfc, 0xff, 0xff, 0xc0, 0x01, 0xff, 0xe0, 0x0f, 0xff, 0xfc, 0xff, 0xff, 0xe0, 0x03, 0xff, 0xc0,
0x1f, 0xff, 0xfc, 0xff, 0xff, 0xf8, 0x01, 0xff, 0x80, 0x7f, 0xff, 0xfc, 0xff, 0xff, 0xfe, 0x00,
0x00, 0x01, 0xff, 0xff, 0xfc, 0xff, 0xff, 0xff, 0x80, 0x00, 0x07, 0xff, 0xff, 0xfc, 0xff, 0xff,
0xff, 0xf0, 0x00, 0x3f, 0xff, 0xff, 0xfc, 0xf9, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x7c,
0xf1, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x3c, 0xfb, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0x7c, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x7f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xf8, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf0, 0x0f, 0xff, 0xff,
// 'propeler1_7', 70x70px
const unsigned char fan_propeler1_7 [] PROGMEM = {
0xfc, 0xff, 0xff, 0xfe, 0x00, 0x00, 0x01, 0xff, 0xff, 0xfc, 0xff, 0xff, 0xf8, 0x01, 0xff, 0xc0,
0x7f, 0xff, 0xfc, 0xff, 0xff, 0xe0, 0x03, 0xff, 0xc0, 0x1f, 0xff, 0xfc, 0xff, 0xff, 0xc0, 0x03,
0xff, 0xc0, 0x0f, 0xff, 0xfc, 0xff, 0xff, 0x87, 0x07, 0xff, 0x80, 0x07, 0xff, 0xfc, 0xff, 0xff,
0x0f, 0x07, 0xff, 0x00, 0x03, 0xff, 0xfc, 0xff, 0xfe, 0x1f, 0x0f, 0xfe, 0x03, 0xe1, 0xff, 0xfc,
0xff, 0xfc, 0x3f, 0x0f, 0xfc, 0x0f, 0xf0, 0xff, 0xfc, 0xff, 0xf8, 0x7f, 0x0f, 0xf8, 0x1f, 0xf8,
0x7f, 0xfc, 0xff, 0xf0, 0xff, 0x0f, 0xf0, 0x3f, 0xfc, 0x3f, 0xfc, 0xff, 0xe1, 0xff, 0x0f, 0xf0,
0xff, 0xfe, 0x1f, 0xfc, 0xff, 0xe1, 0xff, 0x0f, 0xf0, 0xff, 0xff, 0x1f, 0xfc, 0xff, 0xc1, 0xff,
0x0f, 0xe1, 0xff, 0xff, 0x0f, 0xfc, 0xff, 0xc1, 0xff, 0x8f, 0xe3, 0xff, 0xff, 0x8f, 0xfc, 0xff,
0x80, 0xff, 0x8f, 0xe3, 0xff, 0xff, 0x87, 0xfc, 0xff, 0x80, 0xff, 0xc7, 0xc7, 0xfe, 0x00, 0x07,
0xfc, 0xff, 0x00, 0x7f, 0xc7, 0xc7, 0xf8, 0x00, 0x03, 0xfc, 0xff, 0x00, 0x7f, 0xc7, 0xff, 0xe0,
0x00, 0x03, 0xfc, 0xff, 0x18, 0x3f, 0xe3, 0xff, 0x80, 0x00, 0x03, 0xfc, 0xfe, 0x18, 0x1f, 0xf7,
0x03, 0x87, 0xfe, 0x01, 0xfc, 0xfe, 0x3c, 0x0f, 0xfc, 0x00, 0xff, 0xff, 0x81, 0xfc, 0xfe, 0x3e,
0x07, 0xf8, 0x00, 0x7f, 0xff, 0xe1, 0xfc, 0xfe, 0x3f, 0x01, 0xf8, 0x00, 0x7f, 0xff, 0xf1, 0xfc,
0xfe, 0x3f, 0x80, 0xf0, 0x00, 0x3f, 0xff, 0xf1, 0xfc, 0xfe, 0x3f, 0xe0, 0x30, 0x00, 0x3f, 0xff,
0xf1, 0xfc, 0xfe, 0x3f, 0xf8, 0x10, 0x00, 0x31, 0xff, 0xf1, 0xfc, 0xfe, 0x3f, 0xff, 0x30, 0x00,
0x30, 0x3f, 0xf1, 0xfc, 0xfe, 0x3f, 0xff, 0xf0, 0x00, 0x30, 0x0f, 0xf1, 0xfc, 0xfe, 0x3f, 0xff,
0xf0, 0x00, 0x3e, 0x07, 0xf1, 0xfc, 0xfe, 0x1f, 0xff, 0xf8, 0x00, 0x7f, 0x01, 0xf1, 0xfc, 0xfe,
0x0f, 0xff, 0xfc, 0x00, 0xff, 0xc0, 0xf1, 0xfc, 0xfe, 0x07, 0xff, 0xee, 0x01, 0xff, 0xe0, 0xf1,
0xfc, 0xfe, 0x00, 0xfe, 0x07, 0x03, 0x9f, 0xf0, 0x61, 0xfc, 0xff, 0x00, 0x00, 0x07, 0xff, 0x9f,
0xf8, 0x03, 0xfc, 0xff, 0x00, 0x00, 0x1f, 0xdf, 0x8f, 0xf8, 0x03, 0xfc, 0xff, 0x00, 0x00, 0xff,
0x8f, 0x8f, 0xfc, 0x03, 0xfc, 0xff, 0x80, 0x03, 0xff, 0x8f, 0x87, 0xfc, 0x07, 0xfc, 0xff, 0x87,
0xff, 0xff, 0x1f, 0xc7, 0xfe, 0x07, 0xfc, 0xff, 0xc7, 0xff, 0xff, 0x1f, 0xc3, 0xfe, 0x0f, 0xfc,
0xff, 0xc3, 0xff, 0xfe, 0x1f, 0xc3, 0xfe, 0x0f, 0xfc, 0xff, 0xe3, 0xff, 0xfc, 0x3f, 0xc3, 0xfe,
0x1f, 0xfc, 0xff, 0xe1, 0xff, 0xf8, 0x3f, 0xc3, 0xfe, 0x1f, 0xfc, 0xff, 0xf0, 0xff, 0xf0, 0x7f,
0xc3, 0xfc, 0x3f, 0xfc, 0xff, 0xf8, 0x7f, 0xe0, 0x7f, 0xc3, 0xf8, 0x7f, 0xfc, 0xff, 0xfc, 0x3f,
0x80, 0xff, 0xc3, 0xf0, 0xff, 0xfc, 0xff, 0xfc, 0x1c, 0x01, 0xff, 0xc3, 0xe0, 0xff, 0xfc, 0xff,
0xfe, 0x00, 0x03, 0xff, 0x83, 0xc1, 0xff, 0xfc, 0xff, 0xff, 0x80, 0x07, 0xff, 0x83, 0x07, 0xff,
0xfc, 0xff, 0xff, 0xc0, 0x0f, 0xff, 0x00, 0x0f, 0xff, 0xfc, 0xff, 0xff, 0xe0, 0x0f, 0xfe, 0x00,
0x1f, 0xff, 0xfc, 0xff, 0xff, 0xf8, 0x03, 0xfe, 0x00, 0x7f, 0xff, 0xfc, 0xff, 0xff, 0xfe, 0x00,
// 'propeler1_15', 70x70px
const unsigned char fan_15propeler1_15 [] PROGMEM = {
0xfc, 0xff, 0xff, 0xfe, 0x00, 0x00, 0x01, 0xff, 0xff, 0xfc, 0xff, 0xff, 0xf8, 0x00, 0x3f, 0xc0,
0x7f, 0xff, 0xfc, 0xff, 0xff, 0xe0, 0x00, 0x7f, 0xf0, 0x1f, 0xff, 0xfc, 0xff, 0xff, 0xc1, 0xe0,
0xff, 0xfc, 0x0f, 0xff, 0xfc, 0xff, 0xff, 0x83, 0xe0, 0xff, 0xf8, 0x07, 0xff, 0xfc, 0xff, 0xff,
0x0f, 0xe1, 0xff, 0xf0, 0x03, 0xff, 0xfc, 0xff, 0xfe, 0x1f, 0xc1, 0xff, 0xc0, 0x01, 0xff, 0xfc,
0xff, 0xfc, 0x3f, 0xc1, 0xff, 0x80, 0x00, 0xff, 0xfc, 0xff, 0xf8, 0x7f, 0xc3, 0xff, 0x00, 0xf8,
0x7f, 0xfc, 0xff, 0xf0, 0x7f, 0xc3, 0xfe, 0x07, 0xfc, 0x3f, 0xfc, 0xff, 0xe0, 0x7f, 0xc3, 0xfc,
0x0f, 0xfe, 0x1f, 0xfc, 0xff, 0xe0, 0x7f, 0xc3, 0xfc, 0x3f, 0xff, 0x1f, 0xfc, 0xff, 0xc0, 0x7f,
0xc3, 0xf8, 0x7f, 0xff, 0x8f, 0xfc, 0xff, 0xc0, 0x3f, 0xe3, 0xf8, 0xff, 0xff, 0x8f, 0xfc, 0xff,
0x80, 0x3f, 0xe3, 0xf1, 0xff, 0xff, 0xc7, 0xfc, 0xff, 0x80, 0x3f, 0xe3, 0xf1, 0xff, 0xff, 0xc7,
0xfc, 0xff, 0x0c, 0x1f, 0xf3, 0xe3, 0xff, 0xff, 0xe3, 0xfc, 0xff, 0x1e, 0x0f, 0xf1, 0xf7, 0xff,
0x01, 0xc3, 0xfc, 0xff, 0x1e, 0x0f, 0xf1, 0xff, 0xf8, 0x00, 0x03, 0xfc, 0xfe, 0x1f, 0x07, 0xff,
0x03, 0xc0, 0x00, 0x01, 0xfc, 0xfe, 0x3f, 0x83, 0xfe, 0x01, 0xc0, 0x00, 0x01, 0xfc, 0xfe, 0x3f,
0xc1, 0xfc, 0x00, 0xcf, 0xfc, 0x01, 0xfc, 0xfe, 0x3f, 0xe0, 0x78, 0x00, 0x7f, 0xff, 0x01, 0xfc,
0xfe, 0x3f, 0xf8, 0x30, 0x00, 0x3f, 0xff, 0xc1, 0xfc, 0xfe, 0x3f, 0xfe, 0x10, 0x00, 0x3f, 0xff,
0xe1, 0xfc, 0xfe, 0x3f, 0xff, 0xb0, 0x00, 0x3f, 0xff, 0xf1, 0xfc, 0xfe, 0x3f, 0xff, 0xf0, 0x00,
0x37, 0xff, 0xf1, 0xfc, 0xfe, 0x1f, 0xff, 0xf0, 0x00, 0x21, 0xff, 0xf1, 0xfc, 0xfe, 0x0f, 0xff,
0xf0, 0x00, 0x30, 0x7f, 0xf1, 0xfc, 0xfe, 0x03, 0xff, 0xf8, 0x00, 0x78, 0x1f, 0xf1, 0xfc, 0xfe,
0x00, 0xff, 0xcc, 0x00, 0xfe, 0x0f, 0xf1, 0xfc, 0xfe, 0x00, 0x00, 0x0e, 0x00, 0xff, 0x07, 0xf1,
0xfc, 0xfe, 0x00, 0x00, 0x0f, 0x03, 0xff, 0x83, 0xf1, 0xfc, 0xff, 0x00, 0x00, 0x3f, 0xfe, 0x3f,
0xc1, 0xe3, 0xfc, 0xff, 0x0e, 0x03, 0xff, 0xbe, 0x3f, 0xc1, 0xe3, 0xfc, 0xff, 0x0f, 0xff, 0xff,
0x1f, 0x1f, 0xe0, 0xc3, 0xfc, 0xff, 0x8f, 0xff, 0xfe, 0x3f, 0x1f, 0xf0, 0x47, 0xfc, 0xff, 0x8f,
0xff, 0xfe, 0x3f, 0x1f, 0xf0, 0x07, 0xfc, 0xff, 0xc7, 0xff, 0xfc, 0x7f, 0x1f, 0xf0, 0x0f, 0xfc,
0xff, 0xc3, 0xff, 0xf8, 0x7f, 0x0f, 0xf8, 0x0f, 0xfc, 0xff, 0xe3, 0xff, 0xf0, 0xff, 0x0f, 0xf8,
0x1f, 0xfc, 0xff, 0xe1, 0xff, 0xc0, 0xff, 0x0f, 0xf8, 0x1f, 0xfc, 0xff, 0xf0, 0xff, 0x81, 0xff,
0x0f, 0xf8, 0x3f, 0xfc, 0xff, 0xf8, 0x7c, 0x03, 0xff, 0x0f, 0xf8, 0x7f, 0xfc, 0xff, 0xfc, 0x00,
0x07, 0xff, 0x0f, 0xf0, 0xff, 0xfc, 0xff, 0xfc, 0x00, 0x0f, 0xfe, 0x0f, 0xe0, 0xff, 0xfc, 0xff,
0xfe, 0x00, 0x3f, 0xfe, 0x1f, 0xc1, 0xff, 0xfc, 0xff, 0xff, 0x80, 0x7f, 0xfc, 0x1f, 0x07, 0xff,
0xfc, 0xff, 0xff, 0xc0, 0x7f, 0xfc, 0x1e, 0x0f, 0xff, 0xfc, 0xff, 0xff, 0xe0, 0x3f, 0xf8, 0x00,
0x1f, 0xff, 0xfc, 0xff, 0xff, 0xf8, 0x0f, 0xf0, 0x00, 0x7f, 0xff, 0xfc, 0xff, 0xff, 0xfe, 0x00,
// 'propeler1_22', 70x70px
const unsigned char fan_propeler1_22 [] PROGMEM = {
0xfc, 0xff, 0xff, 0xfe, 0x00, 0x00, 0x01, 0xff, 0xff, 0xfc, 0xff, 0xff, 0xf8, 0x00, 0x07, 0xc0,
0x7f, 0xff, 0xfc, 0xff, 0xff, 0xe0, 0x7c, 0x0f, 0xf8, 0x1f, 0xff, 0xfc, 0xff, 0xff, 0xc1, 0xfc,
0x1f, 0xfe, 0x0f, 0xff, 0xfc, 0xff, 0xff, 0x83, 0xf8, 0x3f, 0xff, 0x07, 0xff, 0xfc, 0xff, 0xff,
0x0f, 0xf8, 0x3f, 0xff, 0x03, 0xff, 0xfc, 0xff, 0xfe, 0x0f, 0xf8, 0x7f, 0xfe, 0x01, 0xff, 0xfc,
0xff, 0xfc, 0x0f, 0xf0, 0x7f, 0xf0, 0x00, 0xff, 0xfc, 0xff, 0xf8, 0x1f, 0xf0, 0xff, 0xe0, 0x00,
0x7f, 0xfc, 0xff, 0xf0, 0x1f, 0xf0, 0xff, 0xc0, 0x00, 0x3f, 0xfc, 0xff, 0xe0, 0x1f, 0xf0, 0xff,
0x80, 0xfc, 0x1f, 0xfc, 0xff, 0xe0, 0x0f, 0xf0, 0xff, 0x03, 0xff, 0x1f, 0xfc, 0xff, 0xc0, 0x0f,
0xf0, 0xfe, 0x0f, 0xff, 0x8f, 0xfc, 0xff, 0xc7, 0x0f, 0xf8, 0xfc, 0x1f, 0xff, 0x8f, 0xfc, 0xff,
0x87, 0x07, 0xf8, 0xfc, 0x3f, 0xff, 0xc7, 0xfc, 0xff, 0x8f, 0x07, 0xf8, 0xf8, 0x7f, 0xff, 0xc7,
0xfc, 0xff, 0x0f, 0x83, 0xf8, 0xf8, 0xff, 0xff, 0xe3, 0xfc, 0xff, 0x1f, 0x83, 0xf8, 0xf9, 0xff,
0xff, 0xe3, 0xfc, 0xff, 0x1f, 0xc1, 0xff, 0xff, 0xff, 0xff, 0xe3, 0xfc, 0xfe, 0x1f, 0xe0, 0xff,
0x03, 0xfc, 0x01, 0xe1, 0xfc, 0xfe, 0x3f, 0xf0, 0x7c, 0x00, 0xe0, 0x00, 0x61, 0xfc, 0xfe, 0x3f,
0xf8, 0x38, 0x00, 0x60, 0x00, 0x01, 0xfc, 0xfe, 0x3f, 0xfe, 0x18, 0x00, 0x73, 0x00, 0x01, 0xfc,
0xfe, 0x1f, 0xff, 0x10, 0x00, 0x3f, 0xf8, 0x01, 0xfc, 0xfe, 0x0f, 0xff, 0xf0, 0x00, 0x3f, 0xff,
0x01, 0xfc, 0xfe, 0x0f, 0xff, 0xf0, 0x00, 0x3f, 0xff, 0x81, 0xfc, 0xfe, 0x03, 0xff, 0xf0, 0x00,
0x3f, 0xff, 0xc1, 0xfc, 0xfe, 0x01, 0xff, 0xf0, 0x00, 0x3f, 0xff, 0xe1, 0xfc, 0xfe, 0x00, 0x7f,
0xf8, 0x00, 0x23, 0xff, 0xf1, 0xfc, 0xfe, 0x00, 0x00, 0x18, 0x00, 0x60, 0xff, 0xf1, 0xfc, 0xfe,
0x00, 0x00, 0x0c, 0x00, 0x70, 0x7f, 0xf1, 0xfc, 0xfe, 0x1c, 0x00, 0x1e, 0x01, 0xfc, 0x1f, 0xf1,
0xfc, 0xfe, 0x1f, 0x83, 0xff, 0x83, 0xfc, 0x1f, 0xf1, 0xfc, 0xff, 0x1f, 0xff, 0xff, 0xfe, 0xfe,
0x0f, 0xe3, 0xfc, 0xff, 0x1f, 0xff, 0xfe, 0x7e, 0x7f, 0x07, 0xe3, 0xfc, 0xff, 0x0f, 0xff, 0xfc,
0x7c, 0x7f, 0x83, 0xc3, 0xfc, 0xff, 0x8f, 0xff, 0xf8, 0x7c, 0x7f, 0x83, 0xc7, 0xfc, 0xff, 0x87,
0xff, 0xf0, 0xfe, 0x3f, 0xc3, 0xc7, 0xfc, 0xff, 0xc7, 0xff, 0xe0, 0xfc, 0x3f, 0xc1, 0x8f, 0xfc,
0xff, 0xc3, 0xff, 0x81, 0xfc, 0x3f, 0xe0, 0x0f, 0xfc, 0xff, 0xe1, 0xff, 0x03, 0xfc, 0x3f, 0xe0,
0x1f, 0xfc, 0xff, 0xe0, 0x70, 0x07, 0xfc, 0x3f, 0xe0, 0x1f, 0xfc, 0xff, 0xf0, 0x00, 0x0f, 0xfc,
0x3f, 0xe0, 0x3f, 0xfc, 0xff, 0xf8, 0x00, 0x1f, 0xfc, 0x3f, 0xe0, 0x7f, 0xfc, 0xff, 0xfc, 0x00,
0x7f, 0xf8, 0x3f, 0xe0, 0xff, 0xfc, 0xff, 0xfc, 0x01, 0xff, 0xf8, 0x3f, 0xc0, 0xff, 0xfc, 0xff,
0xfe, 0x03, 0xff, 0xf0, 0x7f, 0xc1, 0xff, 0xfc, 0xff, 0xff, 0x83, 0xff, 0xf0, 0x7f, 0x07, 0xff,
0xfc, 0xff, 0xff, 0xc0, 0xff, 0xe0, 0xfc, 0x0f, 0xff, 0xfc, 0xff, 0xff, 0xe0, 0x3f, 0xc0, 0xf0,
0x1f, 0xff, 0xfc, 0xff, 0xff, 0xf8, 0x03, 0x00, 0x00, 0x7f, 0xff, 0xfc, 0xff, 0xff, 0xfe, 0x00,
// 'propeler1_30', 70x70px
const unsigned char fan_30propeler1_30 [] PROGMEM = {
0xfc, 0xff, 0xff, 0xfe, 0x00, 0x00, 0x01, 0xff, 0xff, 0xfc, 0xff, 0xff, 0xf8, 0x07, 0x80, 0x00,
0x7f, 0xff, 0xfc, 0xff, 0xff, 0xe0, 0x3f, 0x80, 0xf0, 0x1f, 0xff, 0xfc, 0xff, 0xff, 0xc0, 0xff,
0x83, 0xfe, 0x0f, 0xff, 0xfc, 0xff, 0xff, 0x83, 0xff, 0x07, 0xff, 0x87, 0xff, 0xfc, 0xff, 0xff,
0x03, 0xfe, 0x0f, 0xff, 0xc3, 0xff, 0xfc, 0xff, 0xfe, 0x03, 0xfe, 0x0f, 0xff, 0xe1, 0xff, 0xfc,
0xff, 0xfc, 0x03, 0xfe, 0x1f, 0xff, 0xe0, 0xff, 0xfc, 0xff, 0xf8, 0x07, 0xfc, 0x1f, 0xff, 0x00,
0x7f, 0xfc, 0xff, 0xf0, 0x03, 0xfc, 0x3f, 0xfc, 0x00, 0x3f, 0xfc, 0xff, 0xe1, 0x87, 0xfc, 0x3f,
0xf0, 0x00, 0x1f, 0xfc, 0xff, 0xe3, 0x83, 0xfc, 0x3f, 0xe0, 0x00, 0x1f, 0xfc, 0xff, 0xc3, 0xc3,
0xfc, 0x3f, 0xc0, 0x3c, 0x0f, 0xfc, 0xff, 0xc7, 0xc3, 0xfc, 0x7f, 0x81, 0xff, 0x8f, 0xfc, 0xff,
0x8f, 0xc1, 0xfc, 0x7f, 0x07, 0xff, 0xc7, 0xfc, 0xff, 0x8f, 0xe1, 0xfc, 0x7e, 0x1f, 0xff, 0xc7,
0xfc, 0xff, 0x0f, 0xe0, 0xfc, 0x7c, 0x3f, 0xff, 0xe3, 0xfc, 0xff, 0x1f, 0xf0, 0xfe, 0x7c, 0x7f,
0xff, 0xe3, 0xfc, 0xff, 0x1f, 0xf8, 0x7f, 0xff, 0xff, 0xff, 0xe3, 0xfc, 0xfe, 0x1f, 0xfc, 0x3f,
0x03, 0xff, 0xff, 0xf1, 0xfc, 0xfe, 0x1f, 0xfe, 0x1e, 0x00, 0xff, 0xff, 0xf1, 0xfc, 0xfe, 0x0f,
0xff, 0x18, 0x00, 0x70, 0x07, 0xf1, 0xfc, 0xfe, 0x0f, 0xff, 0x98, 0x00, 0x60, 0x00, 0xf1, 0xfc,
0xfe, 0x07, 0xff, 0xf0, 0x00, 0x20, 0x00, 0x71, 0xfc, 0xfe, 0x03, 0xff, 0xf0, 0x00, 0x3f, 0x80,
0x01, 0xfc, 0xfe, 0x00, 0xff, 0xf0, 0x00, 0x3f, 0xf0, 0x01, 0xfc, 0xfe, 0x00, 0x3f, 0xf0, 0x00,
0x3f, 0xfc, 0x01, 0xfc, 0xfe, 0x00, 0x03, 0xf0, 0x00, 0x3f, 0xff, 0x01, 0xfc, 0xfe, 0x38, 0x00,
0x10, 0x00, 0x3f, 0xff, 0x81, 0xfc, 0xfe, 0x3c, 0x00, 0x18, 0x00, 0x67, 0xff, 0xc1, 0xfc, 0xfe,
0x3f, 0x80, 0x3c, 0x00, 0x63, 0xff, 0xc1, 0xfc, 0xfe, 0x3f, 0xff, 0xfc, 0x00, 0xe1, 0xff, 0xe1,
0xfc, 0xfe, 0x1f, 0xff, 0xff, 0x03, 0xf0, 0xff, 0xe1, 0xfc, 0xff, 0x1f, 0xff, 0xff, 0xff, 0xf8,
0x7f, 0xe3, 0xfc, 0xff, 0x1f, 0xff, 0xf8, 0xf9, 0xfc, 0x3f, 0xe3, 0xfc, 0xff, 0x0f, 0xff, 0xf0,
0xf8, 0xfc, 0x1f, 0xc3, 0xfc, 0xff, 0x8f, 0xff, 0xe1, 0xf8, 0xfe, 0x1f, 0xc7, 0xfc, 0xff, 0x87,
0xff, 0x83, 0xf8, 0xfe, 0x0f, 0xc7, 0xfc, 0xff, 0xc7, 0xfe, 0x07, 0xf8, 0xff, 0x0f, 0x8f, 0xfc,
0xff, 0xc0, 0xf0, 0x0f, 0xf8, 0xff, 0x0f, 0x8f, 0xfc, 0xff, 0xe0, 0x00, 0x0f, 0xf0, 0xff, 0x07,
0x1f, 0xfc, 0xff, 0xe0, 0x00, 0x3f, 0xf0, 0xff, 0x86, 0x1f, 0xfc, 0xff, 0xf0, 0x00, 0xff, 0xf0,
0xff, 0x80, 0x3f, 0xfc, 0xff, 0xf8, 0x03, 0xff, 0xe0, 0xff, 0x80, 0x7f, 0xfc, 0xff, 0xfc, 0x1f,
0xff, 0xe1, 0xff, 0x80, 0xff, 0xfc, 0xff, 0xfc, 0x1f, 0xff, 0xc1, 0xff, 0x00, 0xff, 0xfc, 0xff,
0xfe, 0x0f, 0xff, 0xc1, 0xff, 0x01, 0xff, 0xfc, 0xff, 0xff, 0x87, 0xff, 0x83, 0xff, 0x07, 0xff,
0xfc, 0xff, 0xff, 0xc1, 0xff, 0x07, 0xfe, 0x0f, 0xff, 0xfc, 0xff, 0xff, 0xe0, 0x3c, 0x07, 0xf0,
0x1f, 0xff, 0xfc, 0xff, 0xff, 0xf8, 0x00, 0x07, 0x80, 0x7f, 0xff, 0xfc, 0xff, 0xff, 0xfe, 0x00,
// 'propeler1_37', 70x70px
const unsigned char fan_propeler1_37 [] PROGMEM = {
0xfc, 0xff, 0xff, 0xfe, 0x00, 0x60, 0x01, 0xff, 0xff, 0xfc, 0xff, 0xff, 0xf8, 0x07, 0xf0, 0x00,
0x7f, 0xff, 0xfc, 0xff, 0xff, 0xe0, 0x3f, 0xf0, 0x00, 0x1f, 0xff, 0xfc, 0xff, 0xff, 0xc0, 0x7f,
0xe0, 0x3e, 0x0f, 0xff, 0xfc, 0xff, 0xff, 0x80, 0x7f, 0xe0, 0xff, 0x87, 0xff, 0xfc, 0xff, 0xff,
0x00, 0xff, 0xc1, 0xff, 0xc3, 0xff, 0xfc, 0xff, 0xfe, 0x00, 0xff, 0x83, 0xff, 0xf1, 0xff, 0xfc,
0xff, 0xfc, 0x20, 0xff, 0x83, 0xff, 0xf8, 0xff, 0xfc, 0xff, 0xf8, 0x60, 0xff, 0x87, 0xff, 0xf8,
0x7f, 0xfc, 0xff, 0xf0, 0xf0, 0xff, 0x0f, 0xff, 0xf8, 0x3f, 0xfc, 0xff, 0xe1, 0xf0, 0xff, 0x0f,
0xff, 0x80, 0x1f, 0xfc, 0xff, 0xe3, 0xf0, 0xff, 0x0f, 0xfc, 0x00, 0x1f, 0xfc, 0xff, 0xc3, 0xf0,
0xff, 0x1f, 0xf0, 0x00, 0x0f, 0xfc, 0xff, 0xc7, 0xf0, 0x7f, 0x1f, 0xe0, 0x00, 0x0f, 0xfc, 0xff,
0x87, 0xf8, 0x7f, 0x1f, 0xc0, 0x3c, 0x07, 0xfc, 0xff, 0x8f, 0xf8, 0x3f, 0x1f, 0x81, 0xff, 0x87,
0xfc, 0xff, 0x0f, 0xfc, 0x3f, 0x3f, 0x07, 0xff, 0xe3, 0xfc, 0xff, 0x0f, 0xfe, 0x3f, 0xfe, 0x1f,
0xff, 0xe3, 0xfc, 0xff, 0x07, 0xfe, 0x1f, 0xef, 0x7f, 0xff, 0xe3, 0xfc, 0xfe, 0x07, 0xff, 0x0f,
0x01, 0xff, 0xff, 0xf1, 0xfc, 0xfe, 0x03, 0xff, 0x8c, 0x00, 0xff, 0xff, 0xf1, 0xfc, 0xfe, 0x01,
0xff, 0xcc, 0x00, 0x7f, 0xff, 0xf1, 0xfc, 0xfe, 0x00, 0xff, 0xf8, 0x00, 0x30, 0xff, 0xf1, 0xfc,
0xfe, 0x00, 0x7f, 0xf0, 0x00, 0x30, 0x07, 0xf1, 0xfc, 0xfe, 0x10, 0x1f, 0xf0, 0x00, 0x30, 0x00,
0xf1, 0xfc, 0xfe, 0x38, 0x07, 0xf0, 0x00, 0x3e, 0x00, 0x71, 0xfc, 0xfe, 0x3c, 0x00, 0x30, 0x00,
0x3f, 0xc0, 0x31, 0xfc, 0xfe, 0x3f, 0x00, 0x10, 0x00, 0x3f, 0xf0, 0x01, 0xfc, 0xfe, 0x3f, 0xe0,
0x18, 0x00, 0x3f, 0xfc, 0x01, 0xfc, 0xfe, 0x3f, 0xff, 0xf8, 0x00, 0x7f, 0xfe, 0x01, 0xfc, 0xfe,
0x3f, 0xff, 0xfc, 0x00, 0xc7, 0xff, 0x01, 0xfc, 0xfe, 0x1f, 0xff, 0xfe, 0x01, 0xc3, 0xff, 0x81,
0xfc, 0xfe, 0x1f, 0xff, 0xff, 0x87, 0xe1, 0xff, 0x81, 0xfc, 0xff, 0x1f, 0xff, 0xf1, 0xff, 0xf1,
0xff, 0xc3, 0xfc, 0xff, 0x0f, 0xff, 0xe1, 0xfb, 0xf0, 0xff, 0xc3, 0xfc, 0xff, 0x0f, 0xff, 0x83,
0xf1, 0xf8, 0x7f, 0xc3, 0xfc, 0xff, 0x83, 0xfc, 0x07, 0xf1, 0xf8, 0x7f, 0xc7, 0xfc, 0xff, 0x80,
0x00, 0x0f, 0xf3, 0xfc, 0x3f, 0x87, 0xfc, 0xff, 0xc0, 0x00, 0x1f, 0xe3, 0xfc, 0x3f, 0x8f, 0xfc,
0xff, 0xc0, 0x00, 0x7f, 0xe3, 0xfc, 0x3f, 0x0f, 0xfc, 0xff, 0xe0, 0x01, 0xff, 0xe3, 0xfc, 0x1f,
0x1f, 0xfc, 0xff, 0xe0, 0x3f, 0xff, 0xc3, 0xfc, 0x1e, 0x1f, 0xfc, 0xff, 0xf0, 0x7f, 0xff, 0xc3,
0xfe, 0x1c, 0x3f, 0xfc, 0xff, 0xf8, 0x7f, 0xff, 0x83, 0xfe, 0x18, 0x7f, 0xfc, 0xff, 0xfc, 0x3f,
0xff, 0x07, 0xfc, 0x00, 0xff, 0xfc, 0xff, 0xfc, 0x0f, 0xfe, 0x07, 0xfc, 0x00, 0xff, 0xfc, 0xff,
0xfe, 0x07, 0xfc, 0x0f, 0xfc, 0x01, 0xff, 0xfc, 0xff, 0xff, 0x83, 0xf8, 0x1f, 0xfc, 0x07, 0xff,
0xfc, 0xff, 0xff, 0xc0, 0xe0, 0x1f, 0xf8, 0x0f, 0xff, 0xfc, 0xff, 0xff, 0xe0, 0x00, 0x3f, 0xf0,
0x1f, 0xff, 0xfc, 0xff, 0xff, 0xf8, 0x00, 0x3f, 0x00, 0x7f, 0xff, 0xfc, 0xff, 0xff, 0xfe, 0x00,
// 'abakus', 180x180px
const unsigned char logoabakus [] PROGMEM = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xc0, 0x33, 0x78, 0x00,
0x03, 0xc0, 0x1e, 0x00, 0x02, 0xc0, 0x60, 0x0f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x03, 0xc0, 0x61, 0xce, 0x00, 0x03, 0x80, 0x37, 0x81, 0x8c, 0xe0, 0xe0, 0x0d, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xc0, 0x61, 0xc6, 0x00, 0x03, 0x80,
0x7f, 0xc3, 0x8d, 0xe0, 0xe0, 0x0b, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x06, 0xc0, 0x7d, 0xc6, 0x00, 0x07, 0x80, 0x7f, 0xc7, 0x07, 0x70, 0xe0, 0x0e, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0xc0, 0x3b, 0xc6, 0x00, 0x0d, 0xc0, 0x7f, 0xce,
0x00, 0x71, 0xe0, 0x0e, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0c, 0xc0,
0x02, 0x8c, 0x00, 0x0d, 0xc0, 0x3f, 0xd8, 0x00, 0x70, 0xa0, 0x0e, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x0c, 0xe0, 0x02, 0x98, 0x00, 0x09, 0xc0, 0x01, 0xf0, 0x00, 0x71,
0xa0, 0x1f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0xc0, 0x02, 0xcc,
0x00, 0x18, 0xc0, 0x01, 0xf0, 0x00, 0x70, 0xe0, 0x33, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x18, 0xe4, 0x06, 0xc6, 0x00, 0x18, 0xcc, 0x01, 0xe0, 0x00, 0x71, 0xc0, 0x23,
0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xfc, 0x07, 0xc3, 0x00, 0xff,
0xf8, 0x01, 0xf0, 0x00, 0x61, 0xc0, 0x61, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x0f, 0x90, 0x60, 0x07, 0xc3, 0x1f, 0xb0, 0xe0, 0x03, 0xb8, 0x00, 0x61, 0xc0, 0xc1, 0xc0, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0xb0, 0x60, 0x03, 0xc3, 0x1f, 0x20, 0xe0, 0x03,
0x39, 0xc0, 0xe1, 0x80, 0xbc, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0xb0,
0x70, 0x02, 0xc3, 0xbd, 0x60, 0x60, 0x03, 0x1d, 0xe0, 0x61, 0x81, 0xa6, 0xc0, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x1b, 0x60, 0x3e, 0x03, 0xe3, 0x37, 0xe0, 0x7e, 0x03, 0x0f, 0xe0,
0x61, 0x93, 0x6e, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0xe0, 0x3e, 0x03,
0xc6, 0x18, 0xc0, 0x7e, 0x07, 0x07, 0xc0, 0x63, 0xba, 0x7f, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x07, 0xc0, 0x1e, 0x03, 0xee, 0x0f, 0x80, 0x3e, 0x07, 0x00, 0x00, 0x24, 0xde,
0x3f, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x04, 0x1f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07,
0x00, 0x00, 0x0e, 0x00, 0x00, 0x00, 0x1f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0x80, 0x00, 0x00, 0x3f, 0xe0, 0x00,
0x7f, 0xc0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x03, 0x80,
0x00, 0x00, 0x00, 0x00, 0x01, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1c, 0x00, 0x00, 0xff, 0xe0,
0x00, 0x00, 0x7f, 0xf0, 0x00, 0x0f, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x03, 0xf0, 0x00, 0x00, 0x00,
0x00, 0x00, 0x7f, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x1f, 0xf8, 0x00, 0x00,
0x00, 0x00, 0x0f, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0x80, 0x00, 0xff, 0xe0, 0x00, 0x00,
0x7f, 0xf0, 0x00, 0x1f, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x01,
0xff, 0xc0, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x3f, 0xfc, 0x00, 0x00, 0x00, 0x00,
0x1f, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x01, 0xff, 0xc0, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0,
0x00, 0x3f, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x1f, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x01, 0xff, 0xe0,
0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x3f, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x1f, 0xfe,
0x00, 0x00, 0x00, 0x00, 0x01, 0xff, 0xe0, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x3f,
0xfc, 0x00, 0x00, 0x00, 0x00, 0x1f, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x01, 0xff, 0xe0, 0x00, 0xff,
0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x3f, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x1f, 0xfe, 0x00, 0x00,
0x00, 0x00, 0x01, 0xff, 0xe0, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x3f, 0xfc, 0x00,
0x00, 0x00, 0x00, 0x1f, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x01, 0xff, 0xe0, 0x00, 0xff, 0xe0, 0x00,
0x00, 0x7f, 0xf0, 0x00, 0x3f, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x1f, 0xfe, 0x00, 0x00, 0x00, 0x00,
0x01, 0xff, 0xe0, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf3, 0xff, 0x3f, 0xf8, 0xff, 0xff, 0xff,
0xff, 0x9f, 0xfe, 0x7f, 0xff, 0xff, 0xff, 0xf9, 0xff, 0xc7, 0xfc, 0xff, 0xe0, 0x00, 0x00, 0x78,
0xf3, 0xff, 0x3f, 0xf9, 0xff, 0xff, 0xff, 0xff, 0x8f, 0xfe, 0x7f, 0xff, 0xff, 0xff, 0xf9, 0xff,
0xcf, 0xfc, 0xf1, 0xe0, 0x00, 0x00, 0x78, 0xf3, 0xff, 0x3f, 0xf8, 0xff, 0xff, 0xff, 0xff, 0x8f,
0xfe, 0x7f, 0xff, 0xff, 0xff, 0xf9, 0xff, 0xcf, 0xfc, 0xf1, 0xe0, 0x00, 0x00, 0x78, 0xf3, 0xff,
0x3f, 0xf8, 0xff, 0xff, 0xff, 0xff, 0x8f, 0xfe, 0x7f, 0xff, 0xff, 0xff, 0xf9, 0xff, 0xcf, 0xfc,
0xf1, 0xe0, 0x00, 0x00, 0x7f, 0xf3, 0xff, 0x3f, 0xf8, 0xff, 0xff, 0xff, 0xff, 0x9f, 0xfe, 0x7f,
0xff, 0xff, 0xff, 0xf9, 0xff, 0xcf, 0xfc, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf1, 0x02, 0x3f, 0xfc,
0x40, 0x00, 0x00, 0x01, 0x1f, 0xfe, 0x20, 0x00, 0x00, 0x00, 0x21, 0xff, 0xe2, 0x08, 0xff, 0xe0,
0x00, 0x00, 0x7f, 0xf0, 0x00, 0x3f, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x1f, 0xfe, 0x00, 0x00, 0x00,
0x00, 0x01, 0xff, 0xe0, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x3f, 0xfc, 0x00, 0x00,
0x00, 0x00, 0x1f, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x01, 0xff, 0xe0, 0x00, 0xff, 0xe0, 0x00, 0x00,
0x7f, 0xf0, 0x00, 0x3f, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x1f, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x01,
0xff, 0xe0, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x3f, 0xfc, 0x00, 0x00, 0x00, 0x00,
0x1f, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x01, 0xff, 0xe0, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0,
0xf8, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x01, 0xff, 0xc0, 0x00, 0xff,
0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x1f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xfc, 0x00, 0x00,
0x00, 0x00, 0x00, 0xff, 0x80, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x0f, 0xe0, 0x00,
0x00, 0x00, 0x00, 0x07, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0x00, 0x00, 0xff, 0xe0, 0x00,
0x00, 0x7f, 0xf0, 0x00, 0x03, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x01, 0xe0, 0x00, 0x00, 0x00, 0x00,
0x00, 0x1c, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f,
0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00,
0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x07, 0xe0, 0x00, 0x00, 0x01, 0xf8, 0x00, 0x00, 0x00,
0x00, 0x3f, 0x80, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x0f, 0xf0,
0x00, 0x00, 0x03, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x7f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0,
0x00, 0x00, 0x7f, 0xf0, 0x00, 0x1f, 0xf8, 0x00, 0x00, 0x07, 0xfe, 0x00, 0x00, 0x00, 0x00, 0xff,
0xe0, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x3f, 0xf8, 0x00, 0x00,
0x07, 0xff, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00,
0x7f, 0xf0, 0x00, 0x3f, 0xfc, 0x00, 0x00, 0x0f, 0xff, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00,
0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x3f, 0xfc, 0x00, 0x00, 0x0f, 0xff,
0x00, 0x00, 0x00, 0x01, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0,
0x00, 0x3f, 0xfc, 0x00, 0x00, 0x0f, 0xff, 0x00, 0x00, 0x00, 0x01, 0xff, 0xe0, 0x00, 0x00, 0x00,
0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x3f, 0xfc, 0x00, 0x00, 0x0f, 0xff, 0x00, 0x00,
0x00, 0x01, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x3f,
0xfc, 0x00, 0x00, 0x0f, 0xff, 0x00, 0x00, 0x00, 0x01, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x00, 0xff,
0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x3f, 0xfc, 0x00, 0x00, 0x0f, 0xff, 0x00, 0x00, 0x00, 0x00,
0xff, 0xe0, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf3, 0xff, 0x3f, 0xfc, 0xff,
0xff, 0xc7, 0xff, 0x3f, 0xff, 0xff, 0xf8, 0xff, 0xe3, 0xff, 0xff, 0xff, 0xfc, 0xff, 0xe0, 0x00,
0x00, 0x78, 0xf3, 0xff, 0x3f, 0xf9, 0xff, 0xff, 0xe7, 0xff, 0x3f, 0xff, 0xff, 0xfc, 0xff, 0xe7,
0xff, 0xff, 0xff, 0xfc, 0xf1, 0xe0, 0x00, 0x00, 0x78, 0xf3, 0xff, 0x3f, 0xf8, 0xff, 0xff, 0xe7,
0xff, 0x3f, 0xff, 0xff, 0xfc, 0xff, 0xe7, 0xff, 0xff, 0xff, 0xfc, 0xf1, 0xe0, 0x00, 0x00, 0x78,
0xf3, 0xff, 0x3f, 0xf8, 0xff, 0xff, 0xe7, 0xff, 0x3f, 0xff, 0xff, 0xfc, 0xff, 0xe7, 0xff, 0xff,
0xff, 0xfc, 0xf1, 0xe0, 0x00, 0x00, 0x79, 0xf3, 0xff, 0x3f, 0xf8, 0xff, 0xff, 0xc7, 0xff, 0x3f,
0xff, 0xff, 0xfc, 0xff, 0xe7, 0xff, 0xff, 0xff, 0xfc, 0xf9, 0xe0, 0x00, 0x00, 0x7f, 0xf1, 0xfe,
0x3f, 0xfc, 0xff, 0xff, 0xcf, 0xff, 0x1f, 0xff, 0xff, 0xf8, 0xff, 0xe3, 0xff, 0xff, 0xff, 0xf8,
0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x3f, 0xfc, 0x00, 0x00, 0x0f, 0xff, 0x00, 0x00, 0x00,
0x00, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x3f, 0xfc,
0x00, 0x00, 0x0f, 0xff, 0x00, 0x00, 0x00, 0x01, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0,
0x00, 0x00, 0x7f, 0xf0, 0x00, 0x3f, 0xfc, 0x00, 0x00, 0x0f, 0xff, 0x00, 0x00, 0x00, 0x01, 0xff,
0xe0, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x3f, 0xfc, 0x00, 0x00,
0x0f, 0xff, 0x00, 0x00, 0x00, 0x01, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00,
0x7f, 0xf0, 0x00, 0x3f, 0xfc, 0x00, 0x00, 0x0f, 0xff, 0x00, 0x00, 0x00, 0x01, 0xff, 0xe0, 0x00,
0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0,
0x00, 0x3f, 0xf8, 0x00, 0x00, 0x07, 0xff, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x00,
0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x1f, 0xf8, 0x00, 0x00, 0x07, 0xfe, 0x00, 0x00,
0x00, 0x00, 0x7f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x0f,
0xf0, 0x00, 0x00, 0x03, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x7f, 0x80, 0x00, 0x00, 0x00, 0x00, 0xff,
0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x07, 0xc0, 0x00, 0x00, 0x00, 0xf8, 0x00, 0x00, 0x00, 0x00,
0x1f, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00,
0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x07, 0xc0, 0x00, 0x00, 0x00,
0x01, 0xf8, 0x00, 0x00, 0x00, 0x07, 0xe0, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00,
0x00, 0x00, 0x1f, 0xf0, 0x00, 0x00, 0x00, 0x03, 0xfc, 0x00, 0x00, 0x00, 0x0f, 0xf0, 0x00, 0x00,
0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x07, 0xfe,
0x00, 0x00, 0x00, 0x1f, 0xf8, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00,
0x3f, 0xf8, 0x00, 0x00, 0x00, 0x07, 0xff, 0x00, 0x00, 0x00, 0x1f, 0xfc, 0x00, 0x00, 0xff, 0xe0,
0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x3f, 0xf8, 0x00, 0x00, 0x00, 0x0f, 0xff, 0x00, 0x00,
0x00, 0x3f, 0xfc, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x7f, 0xf8,
0x00, 0x00, 0x00, 0x0f, 0xff, 0x00, 0x00, 0x00, 0x3f, 0xfc, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00,
0x7f, 0xf0, 0x00, 0x00, 0x00, 0x7f, 0xf8, 0x00, 0x00, 0x00, 0x0f, 0xff, 0x00, 0x00, 0x00, 0x3f,
0xfc, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x7f, 0xf8, 0x00, 0x00,
0x00, 0x0f, 0xff, 0x00, 0x00, 0x00, 0x3f, 0xfc, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0,
0x00, 0x00, 0x00, 0x7f, 0xf8, 0x00, 0x00, 0x00, 0x0f, 0xff, 0x00, 0x00, 0x00, 0x3f, 0xfc, 0x00,
0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x3f, 0xf8, 0x00, 0x00, 0x00, 0x0f,
0xff, 0x00, 0x00, 0x00, 0x3f, 0xfc, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf1, 0xff, 0xff,
0xfe, 0x3f, 0xf8, 0xff, 0xff, 0xff, 0xc7, 0xff, 0x1f, 0xff, 0xff, 0x1f, 0xfc, 0x7f, 0xf8, 0xff,
0xe0, 0x00, 0x00, 0x7d, 0xf3, 0xff, 0xff, 0xff, 0x3f, 0xf9, 0xff, 0xff, 0xff, 0xe7, 0xff, 0x3f,
0xff, 0xff, 0x9f, 0xfc, 0xff, 0xfc, 0xfb, 0xe0, 0x00, 0x00, 0x78, 0xf3, 0xff, 0xff, 0xff, 0x3f,
0xf9, 0xff, 0xff, 0xff, 0xe7, 0xff, 0x3f, 0xff, 0xff, 0x9f, 0xfc, 0xff, 0xfc, 0xf1, 0xe0, 0x00,
0x00, 0x78, 0xf3, 0xff, 0xff, 0xff, 0x3f, 0xf9, 0xff, 0xff, 0xff, 0xe7, 0xff, 0x3f, 0xff, 0xff,
0x9f, 0xfc, 0xff, 0xfc, 0xf1, 0xe0, 0x00, 0x00, 0x78, 0xf3, 0xff, 0xff, 0xff, 0x3f, 0xf9, 0xff,
0xff, 0xff, 0xe7, 0xff, 0x3f, 0xff, 0xff, 0x9f, 0xfc, 0xff, 0xfc, 0xf1, 0xe0, 0x00, 0x00, 0x7f,
0xf3, 0xff, 0xff, 0xfe, 0x3f, 0xf9, 0xff, 0xff, 0xff, 0xc7, 0xff, 0x3f, 0xff, 0xff, 0x1f, 0xfc,
0xff, 0xfc, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x3f, 0xf8, 0x00, 0x00, 0x00,
0x0f, 0xff, 0x00, 0x00, 0x00, 0x3f, 0xfc, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00,
0x00, 0x00, 0x7f, 0xf8, 0x00, 0x00, 0x00, 0x0f, 0xff, 0x00, 0x00, 0x00, 0x3f, 0xfc, 0x00, 0x00,
0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x7f, 0xf8, 0x00, 0x00, 0x00, 0x0f, 0xff,
0x00, 0x00, 0x00, 0x3f, 0xfc, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00,
0x7f, 0xf8, 0x00, 0x00, 0x00, 0x0f, 0xff, 0x00, 0x00, 0x00, 0x3f, 0xfc, 0x00, 0x00, 0xff, 0xe0,
0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x7f, 0xf8, 0x00, 0x00, 0x00, 0x0f, 0xff, 0x00, 0x00,
0x00, 0x3f, 0xfc, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x3f, 0xf8,
0x7f, 0xf0, 0x00, 0x00, 0x00, 0x3f, 0xf8, 0x00, 0x00, 0x00, 0x07, 0xff, 0x00, 0x00, 0x00, 0x1f,
0xfc, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x3f, 0xf0, 0x00, 0x00,
0x00, 0x07, 0xfe, 0x00, 0x00, 0x00, 0x1f, 0xf8, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0,
0x00, 0x00, 0x00, 0x1f, 0xf0, 0x00, 0x00, 0x00, 0x03, 0xfe, 0x00, 0x00, 0x00, 0x0f, 0xf0, 0x00,
0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x07, 0xc0, 0x00, 0x00, 0x00, 0x01,
0xf8, 0x00, 0x00, 0x00, 0x07, 0xe0, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff,
0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x03, 0xc0, 0x00, 0x00, 0x00,
0x03, 0xe0, 0x00, 0x00, 0x01, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f,
0xf0, 0x00, 0x0f, 0xf0, 0x00, 0x00, 0x00, 0x0f, 0xf0, 0x00, 0x00, 0x07, 0xf8, 0x00, 0x00, 0x00,
0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x1f, 0xf8, 0x00, 0x00, 0x00, 0x1f, 0xf8,
0x00, 0x00, 0x0f, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00,
0x3f, 0xf8, 0x00, 0x00, 0x00, 0x1f, 0xfc, 0x00, 0x00, 0x0f, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00,
0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x3f, 0xfc, 0x00, 0x00, 0x00, 0x3f, 0xfc, 0x00, 0x00,
0x1f, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x3f, 0xfc,
0x00, 0x00, 0x00, 0x3f, 0xfc, 0x00, 0x00, 0x1f, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0,
0x00, 0x00, 0x7f, 0xf0, 0x00, 0x3f, 0xfc, 0x00, 0x00, 0x00, 0x3f, 0xfc, 0x00, 0x00, 0x1f, 0xfe,
0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x3f, 0xfc, 0x00, 0x00,
0x00, 0x3f, 0xfc, 0x00, 0x00, 0x1f, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00,
0x7f, 0xf0, 0x00, 0x3f, 0xfc, 0x00, 0x00, 0x00, 0x3f, 0xfc, 0x00, 0x00, 0x1f, 0xfe, 0x00, 0x00,
0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x3f, 0xfc, 0x00, 0x00, 0x00, 0x3f,
0xfc, 0x00, 0x00, 0x1f, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf1,
0x86, 0x3f, 0xfc, 0x40, 0x00, 0x07, 0x3f, 0xfc, 0x60, 0x01, 0x8f, 0xfe, 0x30, 0x00, 0x00, 0x00,
0x18, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf3, 0xff, 0x3f, 0xf8, 0xff, 0xff, 0xff, 0x3f, 0xfc, 0xff,
0xff, 0x8f, 0xfe, 0x7f, 0xff, 0xff, 0xff, 0xfc, 0xff, 0xe0, 0x00, 0x00, 0x78, 0xf3, 0xff, 0x3f,
0xf8, 0xff, 0xff, 0xff, 0x3f, 0xfc, 0xff, 0xff, 0xcf, 0xfe, 0x7f, 0xff, 0xff, 0xff, 0xfc, 0xf1,
0xe0, 0x00, 0x00, 0x78, 0xf3, 0xff, 0x3f, 0xf8, 0xff, 0xff, 0xff, 0x3f, 0xfc, 0xff, 0xff, 0xcf,
0xfe, 0x7f, 0xff, 0xff, 0xff, 0xfc, 0xf0, 0xe0, 0x00, 0x00, 0x78, 0xf3, 0xff, 0x3f, 0xf8, 0xff,
0xff, 0xff, 0x3f, 0xfc, 0xff, 0xff, 0xcf, 0xfe, 0x7f, 0xff, 0xff, 0xff, 0xfc, 0xf1, 0xe0, 0x00,
0x00, 0x7f, 0xf3, 0xff, 0x3f, 0xf8, 0xff, 0xff, 0xff, 0x3f, 0xfc, 0xff, 0xff, 0x8f, 0xfe, 0x7f,
0xff, 0xff, 0xff, 0xfc, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x3f, 0xfc, 0x00, 0x00, 0x00,
0x3f, 0xfc, 0x00, 0x00, 0x1f, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f,
0xf0, 0x00, 0x3f, 0xfc, 0x00, 0x00, 0x00, 0x3f, 0xfc, 0x00, 0x00, 0x1f, 0xfe, 0x00, 0x00, 0x00,
0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x3f, 0xfc, 0x00, 0x00, 0x00, 0x3f, 0xfc,
0x00, 0x00, 0x1f, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00,
0x3f, 0xfc, 0x00, 0x00, 0x00, 0x3f, 0xfc, 0x00, 0x00, 0x1f, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x7f, 0xf0, 0x00, 0x3f, 0xf8, 0x00, 0x00, 0x00, 0x1f, 0xfc, 0x00, 0x00, 0x0f, 0xfe,
0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x1f, 0xf8, 0x00, 0x00,
0x00, 0x1f, 0xf8, 0x00, 0x00, 0x0f, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00,
0x7f, 0xf0, 0x00, 0x1f, 0xf0, 0x00, 0x00, 0x00, 0x0f, 0xf8, 0x00, 0x00, 0x07, 0xfc, 0x00, 0x00,
0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x07, 0xe0, 0x00, 0x00, 0x00, 0x07,
0xe0, 0x00, 0x00, 0x03, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0,
0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x00,
0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00,
0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0,
0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00,
0x7f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf0,
0x00, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
// ST7789 TFT module connections, can be anything
// Some pins are static, can not be changed - look inside the library for the pin connection
#define TFT_CS 6 // define chip select pin
#define TFT_DC 5 // define data/command pin
#define TFT_RST 8 // define reset pin, or set to -1 and connect to Arduino RESET pin
//Analog read-out of temperature with variables for better calculating
int temp_pin_1 = A2;
int temp_pin_2 = A0;
int temp_pin_3 = A1;
float temp_val = 0; // variable to store the value coming from the sensor
int temperature_const = 15;
int difference_temp = 0;
// Initialize Adafruit ST7789 TFT library
Adafruit_ST7789 tft = Adafruit_ST7789(TFT_CS, TFT_DC, TFT_RST);
//Variables for pulse counting, RMP
unsigned long previousRPMMillis;
unsigned long previousMillis;
unsigned long RPM_calculated = 1000;
unsigned long interval = 1000;
byte pwmValue = 255;
byte pwmInterval = 5;
const byte pwmMax = 255;
const byte pwmMin = 0;
const int reedPin = 2; //read-out pin for RMP
//const int sparePin = 3; //turn-off pin for RMP
const int fanPin = 9; //Use PIN9 with PWM 25kHz
const int pot_Pin = A6; // select the input pin for the potentiometer
float pot_Val = 0;
float pwmValue_f = 0;
volatile unsigned long pulses = 0;
unsigned long lastRPMmillis = 0;
void countPulse() {
// just count each pulse we see
// ISRs should be short, not like
// these comments, which are long.
pulses++;
//configure Timer 1 (pins 9,10) to output 25kHz PWM
//both pins are unavailable, only for PWM FAN
void setupTimer1() {
//Set PWM frequency to about 25khz on pins 9,10 (timer 1 mode 10, no prescale, count to 320)
TCCR1A = (1 << COM1A1) | (1 << COM1B1) | (1 << WGM11);
TCCR1B = (1 << CS10) | (1 << WGM13);
ICR1 = 320;
OCR1A = 0;
OCR1B = 0;
//equivalent of analogWrite on pin 9
void setPWM1A(float f) {
f = f < 0 ? 0 : f > 1 ? 1 : f;
OCR1A = (uint16_t)(320 * f);
Serial.begin(9600); //fire up the serial watch :)
pinMode(reedPin, INPUT_PULLUP); //RPM pin
//pinMode(sparePin, OUTPUT); //RPM pin
//digitalWrite(sparePin,LOW);
attachInterrupt(digitalPinToInterrupt(reedPin), countPulse, FALLING);
pinMode(fanPin, OUTPUT); // probably PWM
setupTimer1();
setPWM1A(0.8f); //set duty to 80% on pin 3, just random value
// if the display has CS pin try with SPI_MODE0
tft.init(240, 240, SPI_MODE2); // Init ST7789 display 240x240 pixel
// if the screen is flipped, remove this command
tft.setRotation(2);
tft.fillScreen(ST77XX_WHITE);
//startup, draw Abakus logo an wait, than fill with wait
tft.drawBitmap(30, 30, logoabakus, 180, 180, ST77XX_BLACK, ST77XX_WHITE);
delay(3000);
//progress bar, START
tft.setTextColor(ST77XX_BLUE, ST77XX_WHITE);
tft.setTextWrap(true);
tft.setTextSize(2);
tft.drawRoundRect(35 , 105, 170, 30, 10, ST77XX_BLUE);
tft.setCursor (70, 80);
tft.print("Loading...");
for (int i = 0; i <= 160; i++) {
tft.drawFastVLine(40 + i, 110, 20, ST77XX_RED);
tft.setCursor (80, 150);
tft.print(i * 0.625);
tft.print("%");
delay(30);
tft.setCursor (80, 175);
tft.print("Status:");
tft.setTextColor(ST77XX_GREEN, ST77XX_WHITE);
tft.print("OK");
delay(100);
//progress bar, END
//startup
tft.drawRoundRect(10, 10, 220, 220, 10, ST77XX_BLUE);
//tft.setFont(&FreeMonoBoldOblique12pt7b);
//thermometer, draw by lines
tft.drawCircle(38, 90, 15, ST77XX_BLUE);
tft.drawRoundRect(30, 25, 16, 55, 5, ST77XX_BLUE);
tft.fillCircle(38, 90, 14, ST77XX_WHITE);
tft.fillRect(31, 35, 14, 50, ST77XX_WHITE);
tft.fillCircle(38, 90, 13.5, ST77XX_RED);
tft.fillCircle(43, 85, 3, ST77XX_WHITE);
tft.fillRect(32, 65, 12, 17, ST77XX_RED);
//animation of the cursor
for (int i = 0; i <= 4; i++) {
tft.drawFastHLine(50, 30 + (10 * i), 10, ST77XX_BLUE);
tft.drawFastHLine(50, 35 + (10 * i), 5, ST77XX_BLUE);
tft.fillTriangle(65, 65, 70, 60, 70, 70, ST77XX_BLACK);
//calculate RPM function
unsigned long calculateRPM() {
unsigned long RPM;
noInterrupts();
float elapsedMS = (millis() - lastRPMmillis) / 1000.0;
unsigned long revolutions = pulses / 2;
float revPerMS = revolutions / elapsedMS;
RPM = revPerMS * 60.0;
lastRPMmillis = millis();
pulses = 0;
interrupts();
/* Serial.print(F("elpasedMS = ")); Serial.println(elapsedMS);
Serial.print(F("revolutions = ")); Serial.println(revolutions);
Serial.print(F("revPerMS = ")); Serial.println(revPerMS); */
return RPM;
handleSerial();
if (millis() - previousMillis > interval) {
Serial.print ("Potentiometer: ");
Serial.print(pot_Val);
Serial.println("");
Serial.print("RPM=");
RPM_calculated = calculateRPM();
Serial.print(RPM_calculated);
Serial.print(F(" @ PWM="));
Serial.println(pwmValue);
previousMillis = millis();
temp_val = read_potentiometer(pot_Pin); //950
pot_Val = temp_val; //302
if (pot_Val < 0) {
pot_Val = 0;
pot_Val = pot_Val * 0.25; // transfer to 0-255 range
if (pot_Val < 3) {
pot_Val = 0;
if (pot_Val > 253) {
pot_Val = 255;
pwmValue = pot_Val; //asign the value from the potentiomer
//analogWrite(fanPin, pwmValue); //set the PWM
pwmValue_f = float(pwmValue) / 255;
Serial.println("PWM real: ");
Serial.print(pwmValue_f);
setPWM1A(pwmValue_f); //set duty to custom on pin 9
tft.setTextSize(2);
// tft.drawBitmap(25, 25, thermometer_icon, 24, 36, ST77XX_BLACK);
tft.setCursor(90, 35);
temp_val = read_temp(temp_pin_1) - 1.6;
tft.print(temp_val);
tft.print(char(247));
tft.print("C");
//tft.fillCircle(150, 60, 10, ST77XX_WHITE);
//tft.drawCircle(150, 60, 6, ST77XX_BLUE);
tft.setCursor(90, 55);
temp_val = read_temp(temp_pin_2) - 1;
tft.print("C");
tft.setCursor(90, 75);
temp_val = read_temp(temp_pin_3) - 1.7;
tft.print("C");
//Thermometer animation
for (int j = 0; j <= difference_temp + 1; j++ ) {
tft.drawFastHLine(32, 65 - j, 12, ST77XX_WHITE);
for (int i = 0; i <= ((int)temp_val - temperature_const); i++ ) {
tft.drawFastHLine(32, 65 - i, 12, ST77XX_RED);
tft.fillTriangle(65, 65 - difference_temp, 70, 60 - difference_temp, 70, 70 - difference_temp, ST77XX_WHITE);
tft.fillTriangle(65, 65, 70, 60, 70, 70, ST77XX_WHITE);
tft.fillTriangle(65, 65 - ((int)temp_val - temperature_const), 70, 60 - ((int)temp_val - temperature_const), 70, 70 - ((int)temp_val - temperature_const), ST77XX_BLACK);
difference_temp = ((int)temp_val - temperature_const);
if (difference_temp > 25) {
difference_temp = 25;
//draw fan
tft.drawBitmap(20, 150, fanfan, 70, 70, ST77XX_BLACK, ST77XX_WHITE);
tft.drawBitmap(20, 150, fan_propeler1_7 , 70, 70, ST77XX_BLACK, ST77XX_WHITE);
tft.drawBitmap(20, 150, fan_15propeler1_15 , 70, 70, ST77XX_BLACK, ST77XX_WHITE);
tft.drawBitmap(20, 150, fan_propeler1_22 , 70, 70, ST77XX_BLACK, ST77XX_WHITE);
tft.drawBitmap(20, 150, fan_30propeler1_30 , 70, 70, ST77XX_BLACK, ST77XX_WHITE);
tft.drawBitmap(20, 150, fan_propeler1_37 , 70, 70, ST77XX_BLACK, ST77XX_WHITE);
tft.setTextSize(1);
tft.setCursor(130, 210);
tft.print("0%");
if (pot_Val >= 0 && pot_Val <= 50) {
tft.fillRect(100, 210, 25, 10, ST77XX_BLACK);
tft.fillRect(100, 195, 25, 10, ST77XX_WHITE);
tft.fillRect(100, 180, 25, 10, ST77XX_WHITE);
tft.fillRect(100, 165, 25, 10, ST77XX_WHITE);
tft.fillRect(100, 150, 25, 10, ST77XX_WHITE);
tft.setTextColor(ST77XX_WHITE, ST77XX_WHITE);
tft.setCursor(130, 150);
tft.print("100%");
} else if (pot_Val > 50 && pot_Val <= 100) {
tft.fillRect(100, 195, 25, 10, ST77XX_BLACK);
tft.print("100%");
} else if (pot_Val > 100 && pot_Val <= 150) {
tft.fillRect(100, 180, 25, 10, ST77XX_BLACK);
tft.print("100%");
} else if (pot_Val > 150 && pot_Val <= 200) {
tft.fillRect(100, 165, 25, 10, ST77XX_BLACK);
tft.print("100%");
} else if (pot_Val > 200 && pot_Val <= 255) {
tft.fillRect(100, 150, 25, 10, ST77XX_BLACK);
tft.setTextColor(ST77XX_BLACK, ST77XX_WHITE);
tft.print("100%");
tft.setTextSize(2);
// tft.drawRGBBitmap(15, 160, NF_P14, 50, 52);
tft.setCursor(130, 165);
tft.print("RPM:");
//RPM_calculated = constrain(RPM_calculated, 0, 3000);
RPM_calculated = map((int)pot_Val,0,255,0,1500);
tft.print(RPM_calculated);
if ((RPM_calculated < 1000) && (RPM_calculated > 100))
tft.fillRect(213, 163, 16, 20, ST77XX_WHITE);
} else if ((RPM_calculated < 100) && (RPM_calculated > 10)) {
tft.fillRect(199, 163, 25, 20, ST77XX_WHITE);
} else if (RPM_calculated < 10) {
tft.fillRect(189, 163, 25, 20, ST77XX_WHITE);
tft.setCursor(130, 190);
tft.print("PWM:");
if ((int)pot_Val < 100)
tft.fillRect(190, 188, 30, 20, ST77XX_WHITE);
tft.print((int)pot_Val);
void handleSerial() {
boolean printValue = false;
while (Serial.available()) {
switch (Serial.read()) {
case '+':
pwmValue = pwmValue + pwmInterval;
printValue = true;
case '-':
pwmValue = pwmValue - pwmInterval;
printValue = true;
case '!':
pwmValue = pwmMax;
printValue = true;
case '=':
pwmValue = 125;
printValue = true;
case '0':
case '@':
pwmValue = pwmMin;
printValue = true;
case '?':
Serial.println(F("+ Increase"));
Serial.println(F("- Decrease"));
Serial.print(F("! PWM to ")); Serial.println(pwmMax);
Serial.print(F("@ PWM to ")); Serial.println(pwmMin);
Serial.println(F("= PWM to 125"));
printValue = true;
if (printValue) {
Serial.print(F("Current PWM = "));
Serial.flush();
float read_temp(int pin) { //function to average the read-out of the thermometer
float temperature = 0;
float average = 0;
float cel = 0;
for (int i = 0; i <= 9; i++) {
temperature = analogRead(pin);
delay(10);
float mv = ( temperature / 1024.0) * 5000;
cel = mv / 10;
average = average + cel;
cel = average / 10;
return cel;
float read_potentiometer(int pin) { //function to average the read-out of the potentiometer
float potentiometer = 0;
float average = 0;
float cel = 0;
potentiometer = analogRead(pin);
delay(10);
average = average + potentiometer;
cel = average / 5;
return cel;
void drawBitmap(int16_t x, int16_t y, const uint8_t *bitmap, int16_t w, int16_t h, uint16_t color) {
int16_t i, j, byteWidth = (w + 7) / 8;
uint8_t byte;
for (j = 0; j < h; j++) {
for (i = 0; i < w; i++) {
if (i & 7) byte <<= 1;
else byte = pgm_read_byte(bitmap + j * byteWidth + i / 8);
if (byte & 0x80) tft.drawPixel(x + i, y + j, color);
