i'm working on a project that involves a MMA8451 3-axis accelerometer, a Arduino MEGA and a 3.2TFT Shield with SD card.
I only use the SD card part of the TFT screen.
I like to measure the sensors data every 50ms and write that to a text file on the SD Card.
For now i made a sketch but it's not working at 50ms, i think the opening an closing the file takes the longest so i need to figure something out to get it working. I read some on the net about alternative writing to the SD card using FIFO Buffers and such. Really like to implement that but don't know exactly how.
What i also need is since it is a portable solution, i have no serial output and i can not close the sketch on a nice way. I can only pull out the power, so i need the data not to get corrupt when losing power. I can loose some data but als long it is not 2minutes of data i don't care much.
The project is going to measure a couple of hours, 3 values (x,y,z) at 50ms. So there's not a lot of data, only one line: indexnumber (value), X(value), Y(value), Z(value).
Powered by a large powerbank.
#include <SPI.h>
#include <SD.h>
#include <Wire.h>
#include <Adafruit_MMA8451.h>
#include <Adafruit_Sensor.h>
Adafruit_MMA8451 mma = Adafruit_MMA8451();
File myFile;
int Counter = 0;
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
if (! mma.begin()) {
Serial.println("Couldnt start");
while (1);
Serial.println("MMA8451 found!");
mma.setRange(MMA8451_RANGE_4_G);
Serial.print("Range = "); Serial.print(2 << mma.getRange());
Serial.println("G");
Serial.print("Initializing SD card...");
SD.begin(53);
mma.read();
Serial.print(Counter);
Serial.print("\tX:\t"); Serial.print(mma.x);
Serial.print("\tY:\t"); Serial.print(mma.y);
Serial.print("\tZ:\t"); Serial.print(mma.z);
myFile = SD.open("test.txt", FILE_WRITE);
// if the file opened okay, write to it:
if (myFile) {
myFile.print(Counter);
myFile.print("\tX:\t");
myFile.print(mma.x);
myFile.print("\tY:\t");
myFile.print(mma.y);
myFile.print("\tZ:\t");
myFile.println(mma.z);
Counter ++;
myFile.close();
sensors_event_t event;
mma.getEvent(&event);
// if the file didn't open, print an error:
Serial.println("error opening test.txt");
delay(50);
Kind regards hopefully someone give me a solution to do this on a nice and clean way.
