Fast Led Code errors
im trying to merge the rainbow wave function in but getting an error, see below
void rainbow_wave() {
//  fill_rainbow (struct CHSV *targetArray, int numToFill, uint8_t initialhue, uint8_t deltahue=5)
fill_rainbow (struct CHSV *targetArray, int numToFill, uint8_t initialhue, uint8_t deltahue=5);
my code
// Written like 3 months ago
// im lazy.
// Bw ~ ncea lvl 1 tech lAMP
//        _ ^ _
//        O   O
//       <_____>
#include <FastLED.h>
#include <OneButton.h>
#define NUM_LEDS  86
#define LED_PIN   4
#define BTN_PIN   6
CRGB leds[NUM_LEDS];
uint8_t patternCounter = 0;
// Push button connected between pin 7 and GND (no resistor required)
OneButton btn = OneButton(BTN_PIN, true, true);
  FastLED.addLeds<WS2812B, LED_PIN, GRB>(leds, NUM_LEDS);
  FastLED.setBrightness(50);
  Serial.begin(57600);
  btn.attachClick(nextPattern);
  switch (patternCounter) {
    case 0:
      movingDots();
    case 1:
      rainbow_wave();
    case 2:
      White();
  FastLED.show();
  btn.tick();
void nextPattern() {
  patternCounter = (patternCounter + 1) % 3;           // Change the number after the % to the number of patterns you have
//------- patterns. -------//
void movingDots() {
  uint16_t posBeat  = beatsin16(30, 0, NUM_LEDS - 1, 0, 0);
  uint16_t posBeat2 = beatsin16(60, 0, NUM_LEDS - 1, 0, 0);
  uint16_t posBeat3 = beatsin16(30, 0, NUM_LEDS - 1, 0, 32767);
  uint16_t posBeat4 = beatsin16(60, 0, NUM_LEDS - 1, 0, 32767);
  // Wave for LED color
  uint8_t colBeat  = beatsin8(45, 0, 255, 0, 0);
  leds[(posBeat + posBeat2) / 2]  = CHSV(colBeat, 255, 255);
  leds[(posBeat3 + posBeat4) / 2]  = CHSV(colBeat, 255, 255);
  fadeToBlackBy(leds, NUM_LEDS, 10);
//void rainbowBeat() {
  //uint16_t beatA = beatsin16(30, 0, 255);
  //uint16_t beatB = beatsin16(20, 0, 255);
  //fill_rainbow(leds, NUM_LEDS, (beatA+beatB)/2, 8);
void White() {
fill_solid( leds, NUM_LEDS, CRGB(50,0,200));
errors
Arduino: 1.8.15 (Mac OS X), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
In file included from /Users/baileywilliams/Downloads/FastLED-basics-main 2/5. Multiple patterns/functionsButton/functionsButton.ino:12:0:
/Users/baileywilliams/Documents/Arduino/libraries/FastLED/src/FastLED.h:14:21: note: #pragma message: FastLED version 3.004.000
 #    pragma message "FastLED version 3.004.000"
/Users/baileywilliams/Downloads/FastLED-basics-main 2/5. Multiple patterns/functionsButton/functionsButton.ino: In function 'void rainbow_wave()':
functionsButton:77:15: error: expected primary-expression before 'struct'
functionsButton:77:41: error: expected primary-expression before 'int'
functionsButton:77:64: error: expected primary-expression before 'initialhue'
functionsButton:77:84: error: expected primary-expression before 'deltahue'
exit status 1
option enabled in File -> Preferences.
This is the function's declaration, it can't be inside another function.. If you want to call this function, you have to do it like a few lines below :
