Fast LED output is slow when using serial ultrasonic sensor
Hi
I am using a A02YYUW Waterproof Ultrasonic Sensor with a teensyLC. I would like to run a different pattern when someone is around 90cm away and then again when they are 5cm away. I am using fastLED and the uart serial pins 9 and 10 on a teensy LC (serial2)
I have it working to start with just filling the led strip with one colour. the colour changes when the sensor recognises the different distances. But when I change the strip to get an animation, it is really slow. I have tested the animations without the sensor and it is fine. This is my first time using serial and I am guessing that it is slowing things down but I am at a loss of why that is happening or how to go about fixing it. any help would be greatly appreciated. I feel a bit out of my depth using the serial, I am not very experienced with arduino code.
I am wondering if I should use the altserial library instead of the hardware serial AltSoftSerial Library, for an extra serial port
here is my code
#include <FastLED.h>
#define HWSERIAL Serial2 //setup pins 9 and 10 as hardware serial
//Led strip setup
#define DATA_PIN    2
#define LED_TYPE    WS2813
#define COLOR_ORDER GRB
#define NUM_LEDS    78
CRGB leds[NUM_LEDS];
#define BRIGHTNESS          125
byte data[4] = {};
float distance;
int distanceNoDec;
uint8_t gHue = 0; // rotating "base color" used by many of the patterns
uint8_t paletteIndex = 0;
DEFINE_GRADIENT_PALETTE (heatmap_gp) {
    0,   0,   0,   0,   //black
  128, 255,   0,   0,   //red
  200, 255, 255,   0,   //bright yellow
  255, 255, 255, 255    //full white
CRGBPalette16 myPal = heatmap_gp;
CRGB g_LEDs[NUM_LEDS] = {0};    // Frame buffer for FastLED
  HWSERIAL.begin(9600);
  delay(3000); // 3 second delay for recovery
  // tell FastLED about the LED strip configuration
  FastLED.addLeds<LED_TYPE,DATA_PIN,COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
  //FastLED.addLeds<LED_TYPE,DATA_PIN,CLK_PIN,COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
  // set master brightness control
  FastLED.setBrightness(BRIGHTNESS);
void sinelon()
  // a colored dot sweeping back and forth, with fading trails
  fadeToBlackBy( leds, NUM_LEDS, 20);
  int pos = beatsin16( gHue, 0, NUM_LEDS-1 );
  leds[pos] += CHSV( gHue, 255, 192);
  do {
    for (int i = 0; i < 4; i++)
      data[i] = HWSERIAL.read();
  } while (HWSERIAL.read() == 0xff);
  HWSERIAL.flush();
  if (data[0] == 0xff)
    int sum;
    sum = (data[0] + data[1] + data[2]) & 0x00FF;
    if(sum == data[3])
      distance = (data[1] << 8) + data[2];
      distanceNoDec = distance;
      if
      ((distanceNoDec < 900) && (distanceNoDec >50))
        Serial.println("person is recognised");
        fill_solid(leds,NUM_LEDS, 0);
        sinelon();
        FastLED.show();
      else if (distanceNoDec <50)
        Serial.println("person is very close");
         fill_palette(leds, NUM_LEDS, paletteIndex, 255 / NUM_LEDS, myPal, 255, LINEARBLEND);
          EVERY_N_MILLISECONDS(1){
          paletteIndex++;
  FastLED.show();
       else{
        Serial.println ("no person");
        fill_solid(leds, NUM_LEDS, 0);
        FastLED.show();
    }  else Serial.println("ERROR");
  delay(100);
Oh and i've just seen that altsoftserial won't work with the teensy LC
I have a teensy 3.2 I can switch to if altsoftserial would be the way to go
#define LED_TYPE    WS2813#define COLOR_ORDER GRBThis looks like a bit of a contradiction, not your issue but still…CRGB leds[NUM_LEDS];also this is set for RGB only.
This is not the way
do {
The normal way is to read() while HWSERIAL.available()
now you discard every 5th byte. Not only that, you may be reading bytes that are not actually in the buffer.
No. hwSerial is always the preferred option if you have a UART available.
Anyway the type of Serial is not the issue, it is the way you read data from it.
The message format seems to be:
0xFF, highByte, lowByte, checksum, 0xFF
The checksum is the sum of the first three bytes. The 16-bit distance (highByte, lowByte) is in mm.
