I have an IC I need to supply 3 Square waves to that have frequencies of ~1 MHz, ~62500 kHz, and ~31250 kHz.
I'm unsure exactly how to adjust the frequency of the Due and the one library I found won't accurately get any where near what you want after 40 kHz. Setting it to 61 kHz is giving me like 330kHz on my oscilloscope.
Can the due do ~1 MHz square wave? I'd imagine a divider for 84 MHz should be possible but not finding anything helpful with my weak google-fu.
OK I can get up to ~2MHz with pretty good quality then either my oscilloscope is ringing terribly or the quality of the signal gets pretty terrible.
I don't really understand how it works and if someone could give me some insight it would be much appreciated.
#include "Arduino.h"
const int freq1 = (1 << 23);
const int freq2 = 31250;
const int pin = 6;
pinMode(6,OUTPUT);
analogWriteResolution(12);
pmc_enable_periph_clk(PWM_INTERFACE_ID);
//Configure Clocks
PWMC_ConfigureClocks(freq1,freq2,VARIANT_MCK/8);
//Configure Pin
PIO_Configure(g_APinDescription[pin].pPort,
g_APinDescription[pin].ulPinType,
g_APinDescription[pin].ulPin,
g_APinDescription[pin].ulPinConfiguration);
//Set Pin to count off CLKA set at freq1
int chan = g_APinDescription[pin].ulPWMChannel;
PWMC_ConfigureChannel(PWM_INTERFACE,chan,PWM_CMR_CPRE_CLKA,0,0);
PWMC_SetPeriod(PWM_INTERFACE,chan,80);
PWMC_SetDutyCycle(PWM_INTERFACE,chan,40);
PWMC_EnableChannel(PWM_INTERFACE,chan);
//analogWrite(6,2048);
If you adjust the PWMC_SetPeriod value and PWMC_SetDutyCycle Function you will get the desired affect. However, the PWMC_ConfigureClocks function is required also. Increasing the VARIANT_MCK value slows it down and decreasing it increases the value. If someone can figure out how those values relate to each other I'll write a library for due but the 30 min. I've spent figuring this out isn't enough yet and have to go do a bunch of stuff will check back in when I have more time.
I just don't get what freq1 & freq2 actually do, the rest makes sense to me.
Ok, I've figured it, out for myself I can get any value between 641 Hz - 21000000 MHz but anything above about 1 MHz looks fairly questionable and above about 2 MHz is pretty bad. Anything in the kHz range looks pretty great even 500 kHz or so. Someone with a better oscilloscope / setup can test if it is the chip or my setup.
I know this thing can also do below 1 Hz : / just have to figure out how and I'll make a library that will get you to whatever Hz that is requested.
const int freq1 = 21000000;
const int freq2 = 21000000;
const int pin = 6;
const int minfreq1 = 641;
void SetPinFrequency(int pin,int frequency,int clock)
//Configure Pin
int clk = clock == 1 ? PWM_CMR_CPRE_CLKA : PWM_CMR_CPRE_CLKB;
PWMC_ConfigureChannel(PWM_INTERFACE,chan,clk,0,0);
int divider = 42000000/frequency;
PWMC_SetPeriod(PWM_INTERFACE,chan,divider);
PWMC_SetDutyCycle(PWM_INTERFACE,chan,divider/2);
pinMode(6,OUTPUT);
//Configure Clocks
PWMC_ConfigureClocks(freq1,freq2,2*freq1);
SetPinFrequency(6,31250,1);
SetPinFrequency(7,62500,2);
