Fast way to run through a series of number compares
I'm doing a fan control project. I want to mimic something like the afterburner fan curve control. So far I've done the following:
double x [6] = {0,25,35,60,80,100};
double y [6] = {0,0,25,50,100,100};
  double yc[5];
  double xc[5];
  double k[5];
Serial.println("Started serial and entered the setup");
  for (int i=0 ; i<=4 ; i++ ){
    Serial.print("Calculating k for ");
    Serial.print(i);
    Serial.print(" line");
    yc[i]=(y[i+1]-y[i]);
    Serial.print("yc=");
    Serial.print(yc[i]);
    xc[i]=(x[i+1]-x[i]);
    Serial.print("xc=");
    Serial.print(xc[i]);
    if(yc[i]==0){
      Serial.print("Y is 0 for this point, so k is also");
      k[i]=0;
    if(xc[i]==0){
      Serial.print("We have a problem huston, I'm trying to devide by 0");
    k[i]=((yc[i])/(xc[i]));
    Serial.print("Calculated:");
    Serial.print(k[i]);
  Serial.print("Finished setup, entering loop");
    if (Serial.available() > 0) {
    int inputValue = Serial.read();
    Serial.println("I got this:")
    Serial.print(inputValue);
Quite basic so far. I need to now check if the inputted X is somewhere between X points to apply the correct upper bond and k and calculate the y. What would be the best approach to do this fast as to not strain the processor unnecessary with numerous if-s?
If anyone also has any experience with this and would like to pitch in with a better way to do this I'm all ears.
Please clarify your question and provide us with an example.
compare you input to each value in your x array until you find the array value that is greater. You then know you input is between that and the previous array value
Binary chop?
soki3008:
Quite basic so far. I need to now check if the inputted X is somewhere between X points ...
If I understand it correctly, you want to find the nearest value in the array that corresponds to an input value.
If so I think your first test should be with the value in the middle of the array (middle by position) then you only need to check one half of the array for a closer match. If you can check the middle of the half you can shorten the search even further.
...R
If you really don't want to "strain" the processor, then precalculate your k.
Sounds like you want piecewise linear interpolation. You can get that with the MultiMap function.
https://playground.arduino.cc/Main/MultiMap/
LightuC:
I'm already doing that. Take a look at the code. I'm doing that the setup process.
gcjr:
TheMemberFormerlyKnownAsAWOL:
Binary chop?
Thanks guys I'll do this like so. Seems I can really cut down on calculation time. I'm planning of doing this on ESP32 on dual cores so this should be fast enough.
