I am trying to control 74595 Shift Registers via Ethernet..
I am sending commands with my visual basic application that sends bytes, Ex. 255000255000255000255000 to control 8 shifts
After buffering the command in a String I Split this code and convert it to integer, then use ShiftOut method .
After testing my code I can see that the code execution time on Arduino takes 7 - 9 milliseconds.
I need to make this faster as possible.
Here's my code :
// EZE Control v0.1
// By Kim
// include needed libs
#include <SPI.h>
#include <MyEthernet.h> // Thanks for David A. Mellis & Tom Igoe for this lib ..
// setup network
byte DefaultMac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte DefaultIP[] = {10,0,0,151 };
Server server(23);
Client client = 0;
boolean DebugMode = false;
String AccessPassword = "1234";
byte clientID;
boolean logged = false;
boolean connectFlag = 0;
// PIN Configrations
int connectedLedPin = 2;
int ErrorLedPin = 3;
int latchPin = 9;
int clockPin = 8;
int dataPin = 7;
if (DebugMode){Serial.begin(9600);}
pinMode(connectedLedPin, OUTPUT);
pinMode(ErrorLedPin, OUTPUT);
pinMode(latchPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
pinMode(10, OUTPUT);
startServer();
void startServer() {
Ethernet.begin(DefaultMac, DefaultIP);
server.begin();
if (server.available() && !connectFlag) {
connectFlag = 1;
client = server.available();
clientID = client.id();
else if (server.available()) {
Client badclient = server.available();
byte tempid = badclient.id();
if ( tempid != clientID) {
badclient.println("E1"); // only one connection
badclient.stop();
if (client.connected() && client.available()) getReceivedData();
if (connectFlag && !client.connected()) {
client.stop();
logged = false;
connectFlag = 0;
digitalWrite(connectedLedPin,LOW);
if (!logged){
digitalWrite(connectedLedPin,HIGH);
delay(250);
delay(250);
if (DebugMode){Serial.println("Waiting");}
void getReceivedData(){
unsigned long time = millis();
Client client = server.available();
String Command;
char c;
int isEnd = 0;
while (client.available() > 0 && isEnd == 0 ){
c = client.read();
if (c != 13){
Command.concat(c);
}else{
isEnd = 1;
if (DebugMode){
Serial.print("Command: [");
Serial.print(Command);
Serial.print("] Lenth : ");
Serial.println(Command.length());
switch (logged) {
case true:
// got a new command
digitalWrite(latchPin, LOW);
// shift out the bits:
for (int i = 0;i < 8;i++){
shiftOut(dataPin, clockPin, MSBFIRST,Command.substring(i*3,(i*3)+3).toInt());
digitalWrite(latchPin, HIGH);
client.println(millis() - time);
case false:
if (Command.equals(AccessPassword)) {
logged = true;
client.println("R"); // Ready
else{
client.println("E2"); // Wrong Access
client.stop();
Command = ""; // empty buffer
Sending data as a string and storing that in an String and extracting substrings from that and converting those to ints is not really compatible with speed.
What part of the code is taking 7 to 9 milliseconds? The whole receive, parse, shiftOut cycle?
The whole receive, I start counting by the first line (unsigned long time = millis()), And print the millis back to my visual basic app. (client.println(millis() - time))..
If there's a tweek for all code not just the receive function that give me more speed.. this will be great..
I used String function coz I am a new to the Arduino and I didn't understand the char & array functions yet ...
CrossRoads:
How long is this calculation taking?
Command.substring(i3,(i3)+3).toInt()
That time is with turned off too?
For the actual shifting out you could use this instead:
SPI.transfer (Command.substring(i3,(i3)+3).toInt()); // connect to arduino pins SCK & MOSI instead of 7 & 8
I already attached a Ethernet Shield to arduino, This shield used the SPI pins .. right ?
I tested the code without the shiftOut lines, I remarked them.. i got less 1 - 2 millis ..
The delay is not from the shiftOut process, Its from buffering & substring the commands .. is there's a better way ?
You really need to separate the time into three parts - collecting the data, parsing the data, and using the data. You've already isolated the third part, using the data, and determined that that part is not the slow bit. Now, the question is whether collecting the data or parsing the data is the slow part. I'm betting on the collection, via ethernet as strings, as the slow part, rather than the parsing of the data.
There's not going to be much you can do about that. The ethernet shield is not a particularly fast way of transferring data.
Ok, I used the Ethernet coz i want to control my device little away from the computer.. lets say about 100+ meters, The maximum USB cable length for full speed is 5 meters (From http://www.usb.org/about/faq/ans5 ), So I used Ethernet.. is there's a better way than Ethernet ?
