Hi
I know this should be simple but I cant for the life of me work it out.
Trying to work out the code for this.
Imagine a wheel having a reed switch on it. Every revolution it would would give a pulse as the reed switch it activated.
Eg. Its doing 1 revolution ever 1 second. This would make make my digital POT to = 100k
2 revolution would = 200k 3 = 300k and so on.
when the wheel dropped back to 2 revolution it would = 200k and when dropped to 1 revolution it would = 100k..
Divide and conquer. There are two tasks here, detecting the rotation rate and programming the digital pot - tackle each separately.
For the first task you'll need to wire up the reed switch with a pull-up resistor (perhaps built-in pull up), and implement pulse debouncing and rate-counting - for such low pulse rates timing the pulses to measure period is perhaps the best method.
For the digital pot you'll have to provide the interface it needs - any particular digital pot in mind? Do you need a pot BTW - ie what is it controlling?
Basically the resister will swipe high and low with just pulsing a couple different pins.
This is how I was going to control the resistance by the speed of the pulse. (revolution of the wheel)
I'm trying to program a arduino to do this.
Before I create the circuit for the IC, im trying to get it to work first with virtual breadboard.
I can get the values to climb but not decrease. I don't know programming enough.
I want to do something similar to this
-skip to the end
But by controlling the resistance by the speed of the wheel.
My other IC Pot I might use is Digital Potentiometer 32POS 10KOhmdigital
