Can somebody tell me if this is the right way to FASTLY let your code halt until a certain pin (here pin D5) changes from LOW to HIGH ?
while (PIND & ( 1 << 5 )==false){
Kind regards,
Bart
Kind regards,
Bart
Its kind of strange (or I just don't understand how to do it), but I tried the following
In my setup code I set
pinMode(5, INPUT); // set pin to input
digitalWrite(5, HIGH); // turn on pullup resistors
Then in my loop I have
while (PIND & ( 1 << 5 )){
blablabla....
I thought that would make my code halt until I connect port D pin 5 (digital out 5 on arduino) to ground and only when I connect the pin to ground it will execute blablabla... ?
Or am I totally wrong?
Mea culpa
I was checking the wrong bit
it had to be
while (PIND & 0b00100000 ){
Two code snaps should be identical, could be compliler optimize "while" out, as there is nothing usefull in it. Checck in assembly, if there is any difference.
Magician:
If PIND is properly declared volatile, the compiler should not optimize the while out. If PIND is not declared volatile, then yes the compiler likely will optimize away the while.
I find it doesn't, I use that construct all the time.
