Floating point divisions are more expensive, around 34 usec, but I don't think you have to use them. I.e., to convert from degrees to radians instead of 2pid/360., just use 0.0174533*d.
So I gather since you want a speedup of a factor of three, you're looking for a total time of less than about 100 usec for the sin() call? It's an interesting exercise that might come in handy for my purposes too, so I gave it a whack. Here's some code that does a sin() function using table lookup in progmem:
#include <avr/pgmspace.h>
#define N 5000 // number of calls to make during test
#define NS 1024 // number of entries in sin table
#define MAXI 32768 // max integer value in table
#define I2F (1./MAXI) // conversion from integer to float
int i ;
long startTime, endTime ;
float dt ;
float d = 0.0 ; // argument to sin function, degrees
float s ; // result of sin function
// sin table
// values for first quadrant, other quadrants calculated by symmetry
PROGMEM prog_uint16_t sintab[NS] = {
0,
50,100,150,201,251,
301,351,402,452,502,
552,603,653,703,753,
804,854,904,954,1005,
1055,1105,1155,1206,1256,
1306,1356,1407,1457,1507,
1557,1607,1658,1708,1758,
1808,1858,1909,1959,2009,
2059,2109,2159,2210,2260,
2310,2360,2410,2460,2510,
2560,2611,2661,2711,2761,
2811,2861,2911,2961,3011,
3061,3111,3161,3211,3261,
3311,3361,3411,3461,3511,
3561,3611,3661,3711,3761,
3811,3861,3911,3961,4011,
4061,4110,4160,4210,4260,
4310,4360,4409,4459,4509,
4559,4609,4658,4708,4758,
4808,4857,4907,4957,5006,
5056,5106,5155,5205,5255,
5304,5354,5403,5453,5503,
5552,5602,5651,5701,5750,
5800,5849,5898,5948,5997,
6047,6096,6146,6195,6244,
6294,6343,6392,6442,6491,
6540,6589,6639,6688,6737,
6786,6835,6884,6934,6983,
7032,7081,7130,7179,7228,
7277,7326,7375,7424,7473,
7522,7571,7620,7669,7717,
7766,7815,7864,7913,7961,
8010,8059,8108,8156,8205,
8254,8302,8351,8400,8448,
8497,8545,8594,8642,8691,
8739,8788,8836,8884,8933,
8981,9029,9078,9126,9174,
9223,9271,9319,9367,9415,
9463,9512,9560,9608,9656,
9704,9752,9800,9848,9896,
9944,9991,10039,10087,10135,
10183,10230,10278,10326,10374,
10421,10469,10517,10564,10612,
10659,10707,10754,10802,10849,
10897,10944,10991,11039,11086,
11133,11181,11228,11275,11322,
11369,11416,11464,11511,11558,
11605,11652,11699,11746,11793,
11839,11886,11933,11980,12027,
12073,12120,12167,12213,12260,
12307,12353,12400,12446,12493,
12539,12586,12632,12678,12725,
12771,12817,12864,12910,12956,
13002,13048,13094,13140,13186,
13232,13278,13324,13370,13416,
13462,13508,13554,13599,13645,
13691,13736,13782,13828,13873,
13919,13964,14010,14055,14100,
14146,14191,14236,14282,14327,
14372,14417,14462,14507,14552,
14598,14642,14687,14732,14777,
14822,14867,14912,14956,15001,
15046,15090,15135,15180,15224,
15269,15313,15357,15402,15446,
15491,15535,15579,15623,15667,
15712,15756,15800,15844,15888,
15932,15976,16019,16063,16107,
16151,16195,16238,16282,16325,
16369,16413,16456,16499,16543,
16586,16630,16673,16716,16759,
16802,16846,16889,16932,16975,
17018,17061,17104,17146,17189,
17232,17275,17317,17360,17403,
17445,17488,17530,17573,17615,
17658,17700,17742,17784,17827,
17869,17911,17953,17995,18037,
18079,18121,18163,18204,18246,
18288,18330,18371,18413,18454,
18496,18537,18579,18620,18662,
18703,18744,18785,18826,18868,
18909,18950,18991,19032,19073,
19113,19154,19195,19236,19276,
19317,19358,19398,19439,19479,
19519,19560,19600,19640,19681,
19721,19761,19801,19841,19881,
19921,19961,20001,20040,20080,
20120,20159,20199,20239,20278,
20318,20357,20396,20436,20475,
20514,20553,20592,20631,20671,
20709,20748,20787,20826,20865,
20904,20942,20981,21020,21058,
21097,21135,21173,21212,21250,
21288,21326,21365,21403,21441,
21479,21517,21555,21592,21630,
21668,21706,21743,21781,21818,
21856,21893,21931,21968,22005,
22042,22080,22117,22154,22191,
22228,22265,22301,22338,22375,
22412,22448,22485,22521,22558,
22594,22631,22667,22703,22740,
22776,22812,22848,22884,22920,
22956,22992,23027,23063,23099,
23134,23170,23205,23241,23276,
23312,23347,23382,23417,23453,
23488,23523,23558,23593,23627,
23662,23697,23732,23766,23801,
23835,23870,23904,23939,23973,
24007,24041,24075,24109,24144,
24177,24211,24245,24279,24313,
24346,24380,24414,24447,24480,
24514,24547,24580,24614,24647,
24680,24713,24746,24779,24812,
24845,24877,24910,24943,24975,
25008,25040,25073,25105,25137,
25169,25201,25234,25266,25298,
25330,25361,25393,25425,25457,
25488,25520,25551,25583,25614,
25645,25677,25708,25739,25770,
25801,25832,25863,25894,25925,
25955,25986,26016,26047,26077,
26108,26138,26169,26199,26229,
26259,26289,26319,26349,26379,
26409,26438,26468,26498,26527,
26557,26586,26615,26645,26674,
26703,26732,26761,26790,26819,
26848,26877,26905,26934,26963,
26991,27020,27048,27076,27105,
27133,27161,27189,27217,27245,
27273,27301,27329,27356,27384,
27411,27439,27466,27494,27521,
27548,27576,27603,27630,27657,
27684,27711,27737,27764,27791,
27817,27844,27870,27897,27923,
27949,27976,28002,28028,28054,
28080,28106,28131,28157,28183,
28208,28234,28259,28285,28310,
28335,28361,28386,28411,28436,
28461,28486,28511,28535,28560,
28585,28609,28634,28658,28682,
28707,28731,28755,28779,28803,
28827,28851,28875,28898,28922,
28946,28969,28993,29016,29039,
29062,29086,29109,29132,29155,
29178,29201,29223,29246,29269,
29291,29314,29336,29359,29381,
29403,29425,29447,29469,29491,
29513,29535,29557,29578,29600,
29621,29643,29664,29686,29707,
29728,29749,29770,29791,29812,
29833,29854,29874,29895,29915,
29936,29956,29977,29997,30017,
30037,30057,30077,30097,30117,
30137,30156,30176,30196,30215,
30235,30254,30273,30292,30312,
30331,30350,30368,30387,30406,
30425,30443,30462,30480,30499,
30517,30535,30554,30572,30590,
30608,30626,30644,30661,30679,
30697,30714,30732,30749,30766,
30784,30801,30818,30835,30852,
30869,30886,30902,30919,30936,
30952,30969,30985,31001,31018,
31034,31050,31066,31082,31098,
31114,31129,31145,31161,31176,
31192,31207,31222,31237,31253,
31268,31283,31298,31312,31327,
31342,31357,31371,31386,31400,
31414,31429,31443,31457,31471,
31485,31499,31513,31526,31540,
31554,31567,31581,31594,31607,
31620,31634,31647,31660,31673,
31685,31698,31711,31723,31736,
31749,31761,31773,31785,31798,
31810,31822,31834,31846,31857,
31869,31881,31892,31904,31915,
31927,31938,31949,31960,31971,
31982,31993,32004,32015,32025,
32036,32047,32057,32067,32078,
32088,32098,32108,32118,32128,
32138,32148,32157,32167,32176,
32186,32195,32205,32214,32223,
32232,32241,32250,32259,32268,
32276,32285,32294,32302,32311,
32319,32327,32335,32343,32351,
32359,32367,32375,32383,32390,
32398,32405,32413,32420,32427,
32435,32442,32449,32456,32463,
32469,32476,32483,32489,32496,
32502,32509,32515,32521,32527,
32533,32539,32545,32551,32557,
32562,32568,32573,32579,32584,
32589,32595,32600,32605,32610,
32615,32619,32624,32629,32633,
32638,32642,32647,32651,32655,
32659,32663,32667,32671,32675,
32679,32682,32686,32689,32693,
32696,32700,32703,32706,32709,
32712,32715,32718,32720,32723,
32726,32728,32730,32733,32735,
32737,32739,32741,32743,32745,
32747,32749,32750,32752,32754,
32755,32756,32758,32759,32760,
32761,32762,32763,32764,32764,
32765,32766,32766,32767,32767,
32767,32767,32767
float romsin(float x) {
int ix ; // index into sin table
int is ; // value read from sin table
int q ; // quadrant number 0,1,2,3
int j ;
x *= 1./360. ;
x -= (int)x ;
if (x < 0)
x += 1.0 ; // x is now between 0 and 1, representing 0 to 360 degrees
q = x * 4 ; // get quadrant number
ix = (int)(x*4*NS) % NS ; // get index into table
switch(q) {
case 0: // 0-90
is = pgm_read_word_near(sintab + ix);
break ;
case 1: // 90-180
ix = NS - ix - 1 ; // reflect
is = pgm_read_word_near(sintab + ix); ;
break ;
case 2: // 180-270
is = -pgm_read_word_near(sintab + ix); ; // negate
break ;
case 3: // 270-360
ix = NS - ix - 1; // reflect
break ;
return((float)is*I2F) ;
Serial.begin(9600) ;
Serial.println("Sin in ROM test....") ;
startTime=millis() ;
for (i = 0 ; i < N ; i++)
s = romsin(d) ;
endTime=millis() ;
dt = 1000.*(float)(endTime - startTime)/N ; // time per call in usec
Serial.print("sin(") ;
Serial.print(d) ;
Serial.print(")=") ;
Serial.print(s) ;
Serial.print(", ") ;
Serial.print((int)dt) ;
Serial.println(" usec/call") ;
d += 1.0 ;
The results are around 80 usec per call. The error is at most 0.0016, near 0 and 180 degrees. That could be improved with a bigger table if necessary, and/or using interpolation although in the latter case there would be a time hit.
I'm not sure why people warn against the slowness of progmem access. From what I can see, a read takes less than a microsecond, so that's no worry in this context.
cos(), atan2() etc. are left as an exercise for the reader!
Joe
